visualisation of the lift distribution over a wing
Old December 1st 09, 12:12 PM posted to rec.aviation.homebuilt
Scott[_7_]
Default visualisation of the lift distribution over a wing
Alan Baker wrote:
Observation can lead you astray: and that is clearly the case here if
you actually think that air can *pull* on a surface.
Why can't air PULL on a surface? Air is made up of molecules.
Molecules have mass. Anything with mass can attract anything else with
mass, can't it?
Old November 30th 09, 12:48 PM posted to rec.aviation.homebuilt
Brian Whatcott
Alan Baker wrote:
Nope.
I'm making the point that the upper surface contributes absolutely *no*
lifting force.
None.
Zero.
In fact, it provides a downward force. Every time.
....and you are making the point that when you are breathing in, you are
not SUCKING air at all. It's atmospheric pressure on your chest that
inspires the air. Wow! Who would have guessed? :-)
Brian W
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
