visualisation of the lift distribution over a wing
Old December 7th 09, 12:56 AM posted to rec.aviation.homebuilt
Beryl[_3_]
Default visualisation of the lift distribution over a wing
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Jim Logajan wrote:
Alan Baker wrote:
If there is no downwash, it will not fly. No.
You are arguing a point not under contention (at least with respect to
heavier-than-air aircraft.)
See everyone: this is why understanding of the actual facts is
required.
The ground isn't required. Air has inertia, and it's just as much a part
of the earth as dirt and rocks are. So why are you fixated on the
earth's solid surface? It compresses too, you know. You could argue that
the downforce travels through the whole planet and back into the
atmosphere in China.
You simply haven't really read anyone else's posts to understand what
they
are stating.
The previous poster just said:
"Let's talk about helicopters. We can replace that rotor with a squirrel
cage fan. Air is drawn down into the fan as before, and most of the
pressure differential is due to lowering pressure above the fan. As
before... except that now the air is exhausted out the periphery of the
centrifugal-flow squirrel cage fan, not down as it was with the old
axial-flow rotor. Will it fly? Where's the downwash?"
She ("Beryl"?)
A mineral
is clearly implying that such an hypothetical craft could remain airborne
without downwash.
No, I only asked.
How else can it be read?
Read it as a question.
So what is your answer? Can the postulated craft fly if there is no
downdraft?
The inflow strikes the underside of the conventional rotor disk, but
strikes the topside of the centrifugal fan disk. That's all!
I'm betting you'll find a way to avoid answering...
I did.
No surprise there.
So where are we? Your downward accelerated air might continue traveling
until it's stopped by the earth's surface, which is the only thing that
can stop it. But it isn't simply thrown down. Much of the finite energy
put into to the air is "wasted" in spinning it. Kinetic energy becomes heat.
And now you're just ducking.
Like you do, every time it's pointed out that when air is pushed down,
an equal volume of air must go UP? You then avoid saying "air flow" and
start grasping for other terms.
So how far down do you think air can flow before the ground is out of
reach? Forever?
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
