Herb wrote:
Another useful approach is start at about 66% aft using manufacturer's CG range. When making the tightest turn you normally do, if you run out of elevator, you need to shift CG back a bit. You will probably end up around 75%.There isn't a huge benefit in having the CG way back, but there is a significant deterioration of handling which requires better pilot skills to offset.The last little bit of glider performance costs quite a bit in pilot workload until you are very proficient. I usually take a couple pounds out of the tail in the Spring and put it back in when my skills are back up to snuff. FWIW UH Here's another gem piece of advice: With my 3D model airplanes I roll inverted and check if I need down elevator to stay level. If so, the cg needs to be moved further back. A well set up model will happily fly inverted without elevator movement! Haven't tried that in my LS8, though. Seriously, Hanks and Eric's methods will both work well. As long as inside the book range, find the cg that gives you good handling and enough up elevator to stall the plane in a steep turn. It'll be at 75%-90% aft. Why is the ability to stall in a steep turn a useful criteria? It sounds like a safety problem to me. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly |
Herb wrote:
...find the cg that gives you good handling and enough up elevator to stall the plane in a steep turn. It'll be at 75%-90% aft. Herb, J7 Reminds me of the old rule of thumb, if you could call it that: CG too far forward, can't pull the nose up for takeoff. CG too far aft, can't recover from a stall/spin. This method can be expensive in airplanes though... :-) Brian W |
Thanks, guys - I've read all your responses, thought about them and
have been Googling to learn more. It looks to me like Bob W's "rant" was correct, and that JJ's method is the best way to go. Brian said "there is a known range of allowable CofG's in terms of %MAC which is similar across a wide range of airframes", so I decided to see what that might be. The best I could tell a reasonable range was 15% to 35% of MAC. However, it's really a loosey, goosey "range" - the HP-18 Bob K referenced has a 25% to 40% of MAC actual range, while a DC8 has a 8% to 18% of MAC actual range! I did discover that by using the 15% to 35% of MAC range Frank Irving's optimal CG is 75% to 100% of the allowed CG range (where 0% is the fwd limit and 100% is the aft limit). It isn't very precise, though, and it doesn't agree with the Akaflieg Braunschweig findings. I then calculated the arithmetic mean chord of the LS8 wing by dividing span by aspect ratio, and got 700mm. This looks about right, since the root chord is 900mm, and yes, I know it's not the MAC. Then, I found a scale drawing of the LS8 at: http://www.dg-flugzeugbau.de/Data/3s-ls8-s.pdf If I'm reading it right, the 25% MAC will be located 225mm behind the wing LE. Using the arithmetic mean chord of 700mm and the allowed CG range of 280mm to 400mm behind the wing LE, I calculated that the LS8 has a CG range on the order of 33% to 50% of MAC. That seems wrong enough that it isn't worth the bother of actually going through the geometric excercise of calculating the MAC on the triple tapered LS8 wing. I cheerfully admit there's a possibility that I don't know what I'm doing, but at this point I'm going to drop Irving's approach. This gets me to JJs advice. I'll follow the 2001 Akaflieg Braunschweig method, and use the tail tank to set the CG to 65% of the allowable range. Once I'm familiar with how she flies there, I'll move it back 5 to 10% at a time until I either reach 90% or get to JJ's criteria point (I have to trim forward when entering a thermal), whereupon I'll bring it forward 5%. I'd be grateful for any further comments or suggestions. -John |
On Dec 13, 1:34 pm, jcarlyle wrote:
...I then calculated the arithmetic mean chord of the LS8 wing by dividing span by aspect ratio, and got 700mm. This looks about right, since the root chord is 900mm, and yes, I know it's not the MAC. Then, I found a scale drawing of the LS8 at: http://www.dg-flugzeugbau.de/Data/3s-ls8-s.pdf If I'm reading it right, the 25% MAC will be located 225mm behind the wing LE... Hmm... That doesn't seem right. Using the DJ Aerotech graphical MAC method, the same LS8 drawing, and information on the LS8 from Thomas' Fundamentals of Sailplane Design (thanks again, Judah!) that places the planform break at 0.6 semispan, I got: * MAC length of ~736mm * MAC LE location of ~41mm aft of the wing LE at side of body _or_ * MAC LE location of ~45mm aft of the intersection of the projected leading edge and the plane of symmetry (yeah, who uses that?) Given that the LS8's double-trapezoid planform gives it more MAC per unit area than the HP-18's eminently buildable single trapezoid planform, and that the LS8's wing is unswept along the 25% chord line as opposed to the HP-18 being unswept along the 41.25% chord, the MAC and MAC LE numbers I got sound about right to me. But, hey, I'm a college dropout with no engineering training, what do I know? As regards the suggested CG location for the HP-series, Dick Schreder typically suggested 25% to 40% MAC as the allowable range. Based on an analysis of the margin of static stability of the HP-18 done by Steve Smith (that's Dr. Smith to you Mythbusters fans), and based on my own experience flying an HP-18 with CG back around 40%, I currently recommend that HP operators limit their operation to 25% to 35% MAC. For an extra 245 Europes, I will be glad to translate that into a dimensional range aft of the wing leading edge at side-of-body. For 245 Australias, I will do all the above and throw in a wisecracking reality-show cameraman. We are not accepting any other continents at this time. Thanks, and best regards to all Bob K. www.hpaircraft.com ---- now with 245% less ondulation! |
On Dec 13, 9:30*pm, Bob Kuykendall wrote:
For an extra 245 Europes, I will be glad to translate that into a dimensional range aft of the wing leading edge at side-of-body. For 245 Australias, I will do all the above and throw in a wisecracking reality-show cameraman. We are not accepting any other continents at this time. Thanks, and best regards to all Bob K.www.hpaircraft.com---- now with 245% less ondulation! So, Bob, does this mean you are only accepting two out of continent offers, and no in-continent offers at this time? Will this now qualify me as the wisecracking reality show cameraman? I have various manuals on various planes that say anything and everything from X% to Y% of the root chord, to X% to y% of the chord . 5 meters outboard of the side of the fuselage. Best reference that can be given for the average pilot is a set of dimensions from an easy to identify point. Forward face of the forward drag spar in the fuselage on an HP-18 is an excellent datum. Steve Leonard :-) |
Bob, thanks for figuring out the MAC of the LS8. I wasn’t clear on
how to “fudge” (DJ Aerotech’s term) the winglet and the wing root to get the required area for use in their graphical calculation of MAC. Your values of 736 mm for MAC, with a MAC LE of 41 mm aft of the LE of the wing root, jibe quite well with my arithmetic chord of 700 mm and my arithmetic chord LE of 50 mm aft of the LE of the wing root. I’m not clear why you said it didn’t seem right. But thanks to you I can now calculate the LS8 CG limits in terms of MAC. The fwd CG limit is 280 mm aft of the LE of the wing root, and the aft CG limit is 400 mm aft of the LE of the wing root (both values from TCDS G14CE). So: Fwd CG limit = 100 * (280 - 41) / 736 = 32% MAC Aft CG limit = 100 * (400 - 41) / 736 = 49% MAC This result (a) makes the LS8 odd from the perspective of SE light aircraft (typical CG range from 15% to 35% of MAC) and the HP-18 (was 25% to 40%, now 25% to 35%), and (b) means that the 1981 Frank Irving optimum CG guideline of 30% to 35% of MAC isn’t useful. So that answers my original questions. -John On Dec 13, 10:30 pm, Bob Kuykendall wrote: Hmm... That doesn't seem right. Using the DJ Aerotech graphical MAC method, the same LS8 drawing, and information on the LS8 from Thomas' Fundamentals of Sailplane Design (thanks again, Judah!) that places the planform break at 0.6 semispan, I got: * MAC length of ~736mm * MAC LE location of ~41mm aft of the wing LE at side of body _or_ * MAC LE location of ~45mm aft of the intersection of the projected leading edge and the plane of symmetry (yeah, who uses that?) Given that the LS8's double-trapezoid planform gives it more MAC per unit area than the HP-18's eminently buildable single trapezoid planform, and that the LS8's wing is unswept along the 25% chord line as opposed to the HP-18 being unswept along the 41.25% chord, the MAC and MAC LE numbers I got sound about right to me. But, hey, I'm a college dropout with no engineering training, what do I know? As regards the suggested CG location for the HP-series, Dick Schreder typically suggested 25% to 40% MAC as the allowable range. Based on an analysis of the margin of static stability of the HP-18 done by Steve Smith (that's Dr. Smith to you Mythbusters fans), and based on my own experience flying an HP-18 with CG back around 40%, I currently recommend that HP operators limit their operation to 25% to 35% MAC. |
![]() jcarlyle wrote: Fwd CG limit = 100 * (280 - 41) / 736 = 32% MAC Aft CG limit = 100 * (400 - 41) / 736 = 49% MAC John, My experience and judgement tell me your figures are way too far aft. I suspect the distance aft of the leading edge to the zero MAC is in error. One sure way to check this is to mark the MAC on both wings then assemble the wing without the fuselage on saw-horses. Then snap a string from both zero MAC's and measure the distance from the string to the leading edge at root rib. Cheers, JJ |
JJ, I place great weight on your experience and judgement! I agree,
what I calculated is way far back. But I've looked over my figures very carefully a number of times, and if there's an error I sure can't find it. As for the LE to zero MAC dimension causing the problem, we can get a figure of merit by calculating the CG limits for the root chord: Fwd CG limit = 100 * 280 / 900 = 31% root chord Aft CG limit = 100 * 400 / 900 = 44% root chord Of course it's different from the 32% to 49% MAC, or the 33% to 50% for the arithmetic chord, but all three result are in the same ball park. Measuring the actual wings as per your write-up is a good suggestion, but due to available work area and the weather I won't be able to try that for about 5 months at the earliest. -John On Dec 15, 10:49 am, JJ Sinclair wrote: jcarlyle wrote: Fwd CG limit = 100 * (280 - 41) / 736 = 32% MAC Aft CG limit = 100 * (400 - 41) / 736 = 49% MAC John, My experience and judgement tell me your figures are way too far aft. I suspect the distance aft of the leading edge to the zero MAC is in error. One sure way to check this is to mark the MAC on both wings then assemble the wing without the fuselage on saw-horses. Then snap a string from both zero MAC's and measure the distance from the string to the leading edge at root rib. Cheers, JJ |
Need a little more range for your 304S jet? | Marc Ramsey[_2_] | Soaring | 1 | July 22nd 07 01:39 PM |
VOR volume range | kevmor | Instrument Flight Rules | 7 | February 7th 07 10:46 PM |
Long range Wx | Paul kgyy | Piloting | 4 | December 31st 04 04:25 PM |
What is the range of the B-1B? | user | Military Aviation | 10 | December 24th 03 04:15 AM |
Fuel Range | Toks Desalu | Home Built | 2 | November 14th 03 12:51 PM |
