On Jan 5, 11:31*am, Sandy Stevenson wrote:
On Jan 5, 11:08*am, Papa3 wrote: On Jan 5, 8:51*am, "Ken Kochanski (KK)" wrote: Morning, I'm reviewing some STF topics to correct some fallacies that seem to have crept into my understanding of STF theory and application ... I though I knew this stuff ... or maybe I forgot ... I am a senior now, you know ... :-)) So, if I have MC set at 3 ... and I am crusing XC to the next three knotter ... should I slow in lift and speed up in sink ... *or will I have a faster average speed if I just hold speed steady ... i.e. at the velocity appropriate for MC = 3 in still air. I see pilots doing both ... Also, do all flight computers compute inter-thermal STF with the formula that does not include a wind component - as identified in Reichmann's texts, for example. Anybody have an excel program that will plot polars ... including the tangent to the shifted origin you get when *when you change airmass sink ... or tail/head winds .. Gracias, Happy new Year ... KK Yo KK, Is this all just theory for you or did you pick up a new chariot? Anyway, *I did a lot of the number crunching and spreadsheet stuff years ago when I was teaching a lot of XC groundschools. * Then, John Cochrane came along and ruined everything - I mean I can't even spell "sto-kas-tick"... *:-) So, here's what I've been leaning toward lately. * *I've adopted a "high gear", "low gear" approach. *For your standard east coast conditions, I'll set and fly McCready up high (say above 4,000 feet), which typically will mean cruising around 80kts dry on your 3-4kt day in my LS8. * But, as soon as I get below that, I'll back off by at least 10-15kts to make sure that I don't have to take a crappy thermal just to survive. I've also taken to the "whifferdill" approach when cruising - ie. if I sense some lift I'll slow up and "explore" to see if I hit a good pulse, but I'm really trying to avoid the 360 turn unless it really feels solid. * *I've flown with CG a few times and watched how much of the air he explores without doing a full turn - it's pretty amazing. P3 As someone who is just starting to fly cross country, this is one of the best discussions I've read here in the last few years. Thanks for your posts, guys.- Hide quoted text - - Show quoted text - As someone who has been flailing around at XC for only a few years..... Thanks! |
Sandy,
If you are just starting, be sure to spend time at John Cochrane's web page: http://faculty.chicagobooth.edu/john...Papers/#corner There you will find the "Just a Little Faster, Please" article that Mike the Strike mentioned. The thing to take away from the article is that small differences in your ability to pick the best lift have a far greater impact on your x/c performance than what you do with your STF decisions. Or you can do what I do and follow 9B! 2NO |
On Tue, 5 Jan 2010 11:31:38 -0800 (PST), Sandy Stevenson
wrote: As someone who is just starting to fly cross country, this is one of the best discussions I've read here in the last few years. Thanks for your posts, guys. Better stop reading now, Sandy. ![]() Otherwise I guarantee that you'll be completely puzzled by the variety of techniques and opinions you are going to read here over the next week. vbg Here's a method that is very simple yet makes champions. Invented by Ingo Renner who became three time world gliding champion using it. First, and most important, set the *correct* McCready setting. A 3 kt thermal is usually only 2 kts if you count the time you need to center it, therefore always use a lower McCready setting than the average climb rate your variometer is showing you. Between thermals fly a *constant speed* depending on the McCready setting. Do not adjust speed to the current sink rate, only pull back and climb into a thermal if it is really strong. Keep the AoA constant - fly smooooooooth. Set McCready to half your chosen value once you get below 50 percent of the cloud base, and only fly with best glide speed if you really desperately need a thermal in order to avoid an outlanding. The same method is used by the pilots who have been dominating German 15m class for the last 6 years (... and by the guy writing this posting). Works like a charm, and is very simple to use. |
On Jan 5, 11:01*pm, Andreas Maurer wrote:
On Tue, 5 Jan 2010 11:31:38 -0800 (PST), Sandy Stevenson wrote: As someone who is just starting to fly cross country, this is one of the best discussions I've read here in the last few years. Thanks for your posts, guys. Better stop reading now, Sandy. ![]() Otherwise I guarantee that you'll be completely puzzled by the variety of techniques and opinions you are going to read here over the next week. vbg Here's a method that is very simple yet makes champions. Invented by Ingo Renner who became three time world gliding champion using it. First, and most important, set the *correct* McCready setting. A 3 kt thermal is usually only 2 kts if you count the time you need to center it, therefore always use a lower McCready setting than the average climb rate your variometer is showing you. Between thermals fly a *constant speed* depending on the McCready setting. Do not adjust speed to the current sink rate, only pull back and climb into a thermal if it is really strong. Keep the AoA constant - fly smooooooooth. Set McCready to half your chosen value once you get below 50 percent of the cloud base, and only fly with best glide speed if you really desperately need a thermal in order to avoid an outlanding. The same method is used by the pilots who have been dominating German 15m class for the last 6 years (... and by the guy writing this posting). Works like a charm, and is very simple to use. That sounds about right. The John Cochrane paper suggests a similar technique. Since he's on the US international team now I guess it works! In RL flying I have a PDA that measures the actual climb rate from when you start turning to when you leave, so I know my achieved climbs to base my MC setting. I set MC on my s2f vario independently from what my PDA suggests (since my vario doesn't listen to the PDA anyway) based on how aggressive I feel about getting to the next thermal. That feeling is based on the suggested speed to fly, altitude, time of day, look of the clouds ahead, whatever. I'll fiddle with it as I get lower, down to around MC=1 (Reichmann notes that your glide range at MC=0 and MC=1 is really very similar, and MC=1 gets you to that thermal more quickly). For that matter I almost always fly dry so there's not a lot of difference in speed to fly at different settings anyway. I try to find lines of clouds more or less in the direction of where I'm going so I can try a bunch before settling on the right thermal. It was interesting looking at one of my fastest days during contest flying. I was flying Sports class and found some amazing thermals that day. If I'd been able to carry the 1 when adding the task time to my start time I would have flown nearly 60mph on course (I came in about 10 minutes early so only got 54mph). However, I saw a certain standard class plane a couple of times up close. Out of curiosity I pulled his trace later on and compared it to my own. Mine had several really good thermals that day, but almost ALL of his thermals were really good! That alone is a good reason he's on the national team and I'm just cannon fodder. -- Matt |
On Tue, 5 Jan 2010 11:31:38 -0800 (PST), Sandy Stevenson wrote: As someone who is just starting to fly cross country, this is one of the best discussions I've read here in the last few years. Thanks for your posts, guys. Better stop reading now, Sandy. ![]() Otherwise I guarantee that you'll be completely puzzled by the variety of techniques and opinions you are going to read here over the next week. vbg Here's a method that is very simple yet makes champions. Invented by Ingo Renner who became three time world gliding champion using it. First, and most important, set the *correct* McCready setting. A 3 kt thermal is usually only 2 kts if you count the time you need to center it, therefore always use a lower McCready setting than the average climb rate your variometer is showing you. Between thermals fly a *constant speed* depending on the McCready setting. Do not adjust speed to the current sink rate, only pull back and climb into a thermal if it is really strong. Keep the AoA constant - fly smooooooooth. Set McCready to half your chosen value once you get below 50 percent of the cloud base, and only fly with best glide speed if you really desperately need a thermal in order to avoid an outlanding. The same method is used by the pilots who have been dominating German 15m class for the last 6 years (... and by the guy writing this posting). Works like a charm, and is very simple to use. More Ingo: http://www.sac.ca/index2.php?option=...13 &Itemid=52 "Soaring with the Master" -T8 |
On Jan 5, 10:08*am, Papa3 wrote:
I've also taken to the "whifferdill" approach when cruising - ie. if I sense some lift I'll slow up and "explore" to see if I hit a good pulse, but I'm really trying to avoid the 360 turn unless it really feels solid. * *I've flown with CG a few times and watched how much of the air he explores without doing a full turn - it's pretty amazing. A lot of pilots do this - it serves two useful purposes: 1) it keeps you in rising air longer without ever giving ground by doing a 360, and 2) It allows you to search for the strong core. I did some calculations on course deviations versus expected climb rates - it's junior high school trigonometry. Conclusion: If you have any good reason to believe that the lift will be stronger - course deviations of 45 degrees and several miles make perfect sense. The guys who are really fast on course are the ones who only settle for the strongest lift along the way. The key skills are 1) being able to use all available cues to go to where the lift is likely to be best - in a micro and macro sense - clouds, terrain features, wind direction and velocity, macro weather patterns, other gliders, etc, 2) knowing how low to go before lowering you expectations for lift - or being able to anticipate a change and adjust accordingly. 9B |
On Jan 5, 4:48*pm, Andy wrote:
On Jan 5, 10:08*am, Papa3 wrote: I did some calculations on course deviations versus expected climb rates - it's junior high school trigonometry. Conclusion: If you have any good reason to believe that the lift will be stronger - course deviations of 45 degrees and several miles make perfect sense. 9B Steve Sliwa wrote his thesis on this topic sometime back in the 1970s IIRC. He used a bit more than junior high trig, but the conclusions were similar. The secret was deciding sooner than later that "street b" would work better than "street a", which is exactly what we see qualitatively in contests. |
On Jan 6, 12:26*pm, Papa3 wrote:
On Jan 5, 4:48*pm, Andy wrote: On Jan 5, 10:08*am, Papa3 wrote: I did some calculations on course deviations versus expected climb rates - it's junior high school trigonometry. Conclusion: If you have any good reason to believe that the lift will be stronger - course deviations of 45 degrees and several miles make perfect sense. 9B Steve Sliwa wrote his thesis on this topic sometime back in the 1970s IIRC. * *He used a bit more than junior high trig, but the conclusions were similar. * The secret was deciding sooner than later that "street b" would work better than "street a", which is exactly what we see qualitatively in contests. Turns out the article was published in the April 1981 Soaring magazine. I have a complete set of Soaring from late 1960s ... with the exception of .... April 1981??!! Well, it's probably in one of the "reading rooms" in the house, but don't have the energy to sort through the stacks right now. If anyone has an electronic copy of the article I'd love to re-read it; it's been years. |
On Tue, 5 Jan 2010 05:51:14 -0800 (PST), "Ken Kochanski (KK)"
wrote: Morning, I'm reviewing some STF topics to correct some fallacies that seem to have crept into my understanding.. There's a lot of interesting thinking in Karel Termaat's soaring page http://home.planet.nl/~kpt9/ in particular, on the topic of how to handle a positive air gust during the glide: http://home.planet.nl/~kpt9/positive.htm Aldo Cernezzi |
On Jan 5, 2:19*pm, cernauta wrote:
On Tue, 5 Jan 2010 05:51:14 -0800 (PST), "Ken Kochanski (KK)" wrote: Morning, I'm reviewing some STF topics to correct some fallacies that seem to have crept into my understanding.. There's a lot of interesting thinking in Karel Termaat's soaring pagehttp://home.planet.nl/~kpt9/ in particular, on the topic of how *to handle a positive air gust during the glide:http://home.planet.nl/~kpt9/positive.htm Aldo Cernezzi Another aspect of the best speed is the selection of the line to follow. Like the comment above on course deviations. In one contest I offset just 1/4 mile left of track into a real nice lift street (blue day). The best pilots are integrating all the information from terrain, clouds and previous climbs. Also looking in all directions to select their course to fly. I know from previous experience in model XC soaring that sometimes it all comes together. You look over that direction and say "The thermal is right THERE!" and it is. Phillip Wills also said something similar in his book (don't remember which one). There are days that you fly that you just know where to go for the lift. I can't do it all the time but I'm getting better! Mike |
Inter-thermal cruise speeds? | Frank[_1_] | Soaring | 25 | February 25th 08 12:55 AM |
ENvironmentally Friendly Inter City Aircraft powered by Fuel Cells | Larry Dighera | Piloting | 83 | June 11th 07 11:07 PM |
Thermal Data Files Thermal Mapping Project Australia | Mal | Soaring | 0 | December 2nd 05 11:14 PM |
Inter Club Competition (US NE Node) | Ken Kochanski (KK) | Soaring | 1 | January 22nd 05 05:46 PM |
Inter Club Competition (US NE Node) | Ken Kochanski (KK) | Soaring | 0 | January 22nd 05 04:09 PM |
