On Feb 7, 7:26*am, wrote:
On Feb 6, 7:57*pm, bildan wrote: On Feb 6, 10:54*am, LS3 Pilot wrote: Trying to do some work on my ship. *Does anyone that reads this forum have experience in the best way to remove gelcoat? *I've got an area thats too big to hand sand on the wing that needs some work. *A friend suggested I buy a water sander that continuously feeds water to the sander (similar to a pneumatic powered straight line sander). What's the best tools to safely and effectively removing the old gel? There's a thing called an "air file" auto body shops use. http://www.pivco.net/index.php?main_...roducts_id=171... It's a linear oscillating compressed air driven sander about 18" long and 2.25" inches wide. *I've been told they work pretty well with 80 grit and they have less chance of digging into the fiberglass than a rotary grinder. *Since it's air driven, I suppose you could safely use wet sanding and avoid the dust. I have used the following in order to find the "best"(for us) tools fo gelcoat removal. 3 inch air rotary disc sander.- Too small- blows dust all over- noisy 7 inch electric disc sander. Too harsh for us and not easy to control. Quick but likely to do damage easily. 18 inch air powered linear sander. Noisy. Not good except single contour. Blows dust around. Need big compressor. 4 inch belt sander. Fast. tricky to use. 4 inch grinder with disc sanding attachment. Fast, fairly easy to control. inexpensive. Slings dust everywhere. 5 inch electric orbital sander. Very uniform controllable removal. Lowest dust generation in room. Easiest to use by unskilled or learning helpers. Only ones we use now are last 2 with last one doing 90% of the work. Feel free to relearn the lessons already learned- we all seem tempted to find the better way that nobody has found. Understand from the get- go, there is no easy way to do this job. Have "fun". UH It's still early and I'm working on my first cup of coffee but... Might it be possible to make a support block that would limit the "exposure" of the cutting surface on more aggressive sanders so as to prevent it digging in? It would work sort of like a block plane. The idea is to use a fast cutting tool but limited to a very shallow cut. |
On Feb 7, 10:54*am, bildan wrote:
On Feb 7, 7:26*am, wrote: On Feb 6, 7:57*pm, bildan wrote: On Feb 6, 10:54*am, LS3 Pilot wrote: Trying to do some work on my ship. *Does anyone that reads this forum have experience in the best way to remove gelcoat? *I've got an area thats too big to hand sand on the wing that needs some work. *A friend suggested I buy a water sander that continuously feeds water to the sander (similar to a pneumatic powered straight line sander). What's the best tools to safely and effectively removing the old gel? There's a thing called an "air file" auto body shops use. http://www.pivco.net/index.php?main_...roducts_id=171... It's a linear oscillating compressed air driven sander about 18" long and 2.25" inches wide. *I've been told they work pretty well with 80 grit and they have less chance of digging into the fiberglass than a rotary grinder. *Since it's air driven, I suppose you could safely use wet sanding and avoid the dust. I have used the following in order to find the "best"(for us) tools fo gelcoat removal. 3 inch air rotary disc sander.- Too small- blows dust all over- noisy 7 inch electric disc sander. Too harsh for us and not easy to control. Quick but likely to do damage easily. 18 inch air powered linear sander. Noisy. Not good except single contour. Blows dust around. Need big compressor. 4 inch belt sander. Fast. tricky to use. 4 inch grinder with disc sanding attachment. Fast, fairly easy to control. inexpensive. Slings dust everywhere. 5 inch electric orbital sander. Very uniform controllable removal. Lowest dust generation in room. Easiest to use by unskilled or learning helpers. Only ones we use now are last 2 with last one doing 90% of the work. Feel free to relearn the lessons already learned- we all seem tempted to find the better way that nobody has found. Understand from the get- go, there is no easy way to do this job. Have "fun". UH It's still early and I'm working on my first cup of coffee but... Might it be possible to make a support block that would limit the "exposure" of the cutting surface on more aggressive sanders so as to prevent it digging in? *It would work sort of like a block plane. The idea is to use a fast cutting tool but limited to a very shallow cut.- Hide quoted text - - Show quoted text - Might work if the surface we are sanding is straight and uniform over significant distance. And the surface we are sanding to is straight and uniform. And the abrasive medium doesn't wear. None of these occurs on the projects I work on. Finding the "easy" way that all the folks that have done this before is seriously tempting. By the time you develop and test the tool, you can learn how to use the proven tools pretty effectively. Well known shop scenario- voice is the worker: This whizbang (grinder, sander insert tool here) really does much better than the hard way I keep reading about. Goin' pretty good- this isn't so tough. One more pass and it'll be just right. Damn! RAS- How do I fix a hole in my(substitute part) skin? Another thread! Been there- done that. You can't buy experience, but you DO pay for it. FWIW UH |
On Feb 8, 12:05*pm, wrote:
On Feb 7, 10:54*am, bildan wrote: On Feb 7, 7:26*am, wrote: On Feb 6, 7:57*pm, bildan wrote: On Feb 6, 10:54*am, LS3 Pilot wrote: Trying to do some work on my ship. *Does anyone that reads this forum have experience in the best way to remove gelcoat? *I've got an area thats too big to hand sand on the wing that needs some work. *A friend suggested I buy a water sander that continuously feeds water to the sander (similar to a pneumatic powered straight line sander). What's the best tools to safely and effectively removing the old gel? There's a thing called an "air file" auto body shops use. http://www.pivco.net/index.php?main_...roducts_id=171... It's a linear oscillating compressed air driven sander about 18" long and 2.25" inches wide. *I've been told they work pretty well with 80 grit and they have less chance of digging into the fiberglass than a rotary grinder. *Since it's air driven, I suppose you could safely use wet sanding and avoid the dust. I have used the following in order to find the "best"(for us) tools fo gelcoat removal. 3 inch air rotary disc sander.- Too small- blows dust all over- noisy 7 inch electric disc sander. Too harsh for us and not easy to control.. Quick but likely to do damage easily. 18 inch air powered linear sander. Noisy. Not good except single contour. Blows dust around. Need big compressor. 4 inch belt sander. Fast. tricky to use. 4 inch grinder with disc sanding attachment. Fast, fairly easy to control. inexpensive. Slings dust everywhere. 5 inch electric orbital sander. Very uniform controllable removal. Lowest dust generation in room. Easiest to use by unskilled or learning helpers. Only ones we use now are last 2 with last one doing 90% of the work. Feel free to relearn the lessons already learned- we all seem tempted to find the better way that nobody has found. Understand from the get- go, there is no easy way to do this job. Have "fun". UH It's still early and I'm working on my first cup of coffee but... Might it be possible to make a support block that would limit the "exposure" of the cutting surface on more aggressive sanders so as to prevent it digging in? *It would work sort of like a block plane. The idea is to use a fast cutting tool but limited to a very shallow cut.- Hide quoted text - - Show quoted text - Might work if the surface we are sanding is straight and uniform over significant distance. And the surface we are sanding to is straight and uniform. And the abrasive medium doesn't wear. None of these occurs on the projects I work on. Finding the "easy" way that all the folks that have done this before is seriously tempting. By the time you develop and test the tool, you can learn how to use the proven tools pretty effectively. Well known shop scenario- voice is the worker: This whizbang (grinder, sander insert tool here) really does much better than the hard way I keep reading about. Goin' pretty good- this isn't so tough. One more pass and it'll be just right. Damn! RAS- How do I fix a hole in my(substitute part) skin? Another thread! Been there- done that. You can't buy experience, but you DO pay for it. FWIW UH Yep, I'm sure it takes a lot of experience. Another thought struck me. Are you familiar with "rivet shavers" that cut countersunk rivets flush with an aluminum skin? They have a sharp rotary cutter inside a micrometer adjustable housing that lets the user adjust the depth of the cut to produce a perfectly smooth rivet 'shave'. Maybe something like that.... I expect the idea would be to quickly and accurately remove all but a few thousandths of gelcoat which would then be removed with the 5" orbital sander. |
On Feb 6, 9:54*am, LS3 Pilot wrote:
What's the best tools to safely and effectively removing the old gel? Sawzall |
On Feb 6, 12:54*pm, LS3 Pilot wrote:
What's the best tools to safely and effectively removing the old gel? Junior club members. |
What's the best tools to safely and effectively removing the old gel? Checkbook ! :-) |
Sanding of plywood before epoxy | [email protected] | Home Built | 6 | July 15th 08 01:21 PM |
Sanding or Waxing - PIK 20 Question | culverflyer | Soaring | 22 | September 22nd 05 09:01 PM |
Advice on sanding fibreglass | [email protected] | Home Built | 12 | April 28th 05 10:39 PM |
Sanding composites | [email protected] | Home Built | 12 | January 31st 05 06:47 AM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
