On Mar 12, 9:41*am, Robert Moore wrote:
" *wrote It's pretty clear that we're not supposed to go below the published MDA on a non-precision approach, unless we can see enough to descend and land. The MAP has nothing to do with it except that we can't continue the approach to land after reaching the MAP. Bob, Bear with me on this. Are you suggesting or saying it's ok to go below MDA BEFORE the MAP???? I was taught NEVER to descend below DH for the ILS or MDA before the MAP for non precision approaches such as VOR alpha or LOC. My point to Sam was that timing alone with wind consideration is not enough to descend below MDA which again I was taught never descend below BEFORE the MAP. DME is the constant factor to finding MAP on this approach, not timing since there are no intersecting radials to identify MAP. Timing helps but since GS will vary based on wind conditions, timing ALONE shouldn't be used to determine MAP. This is what I was taught for what it's worth. |
VOR-DME wrote:
For what it is worth, I am instrument rated, and current, and I am with Sam on this one. You are indeed expected to know what your ground speed is on final, within a reasonable margin of error, and the timing table (or your own time/speed calculation) is the correct way to determine the MAP. There are plenty of LOC approaches without DME, and not that many that actually require it. The minimums applied here, along with the penalties for no local altimeter etc are plenty conservative to make this a safe LOC approach without DME. It could simply be a charting mistake. If they really meant for DME to be required it would likely be in the name; ILS or LOC/DME RWY 9. No, that is not correct. Several years ago the naming convention was changed to include DME in the title only when it is required for the final approach segment. If it is required for the intermediate segment, or all of initial approach segments (if there is more than one) or the missed approach segment, it will be a note. In the case of the procedure that started this thread, DME is required for the missed approach holding fix, because the crossing radial does not pass flight inspection below 6,000. The crossing radial should not be shown in that case, but the procedures staff keeps it on there hoping that maintenance will eventually get it fixed so they remove the DME note. Yes, convoluted and confusing. |
Direct Air Executive BAe 125-800B @ Edinburgh | Drew Malcolm | Aviation Photos | 0 | August 18th 09 11:14 AM |
Neoconservatives have taken over the Executive Branch | NOMOREWARFORISRAEL[_2_] | Naval Aviation | 0 | October 8th 08 11:57 PM |
Boeing DreamLifter at the Charleston Air Show 4-26-08 | Jim Austin | Aviation Photos | 0 | April 27th 08 07:48 PM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
flying clubs in Charleston, SC | Guillermo | Piloting | 1 | June 22nd 05 02:50 PM |
