Fat boy wants to soar...
Old March 20th 10, 02:41 PM posted to rec.aviation.soaring
delboy
Default Fat boy wants to soar...
On Mar 20, 2:15*pm, bildan wrote:
On Mar 18, 2:23*pm, Guy Byars wrote:
On Mar 18, 12:43*am, "BT" wrote:
Knowing flying over the MTOW or out of the CG range can cause an insurance
company to deny a claim.
Can anyone anywhere cite a single example of an insurance company
denying a claim due to flying outside MTOW or CG ranges?
The insurance issue isn't getting a settlement for the first accident
related to an over gross flight - you will get paid. *However, a
problem may arise at renewal time.
There is really no excuse for operating outside the CG envelope. *The
JAR 110 Kg seat limit is a little restrictive for us chubby Americans
but, hey, it's an incentive to cut back on the bacon burgers and
fries.
The idea that the gross weight limit isn't a hard rule is just wrong.
Aircraft manufacturers gain nothing by understating load capacity.
The certificated max weight is as high as can be safely allowed.
It may only be my impression but it seems to me that gliders that are
habitually operated over gross suffer undue wear and damage to the
landing gear, seats and cockpit area. *I've noticed that some POH's
call for tire pressure above the max pressure on the tire sidewall.
I wouldn't think operating those gliders over gross is a good idea.
You could always suggest that Mr McFarley cuts down on the Burgers,
French fries and beer, and does a bit of exercise. Or is that not
'American'?
Derek C
Old March 21st 10, 08:05 AM posted to rec.aviation.soaring
Bruce Hoult
That is clearly not true. A lot of aircraft design is trading off one
desirable feature against another.
In the case of powered aircraft the MTOW is the weight used to
establish the published takeoff run, the distance to clear a 50'
obstacle, the rate of climb, the service ceiling, and probably others.
If you're operating out of short strips then you want to know how much
load you can carry. If you're operating a cessna off a 4 km runway at
sea level with no obstructions then it will be perfectly safe to
operate somewhat over MTOW, especially if the extra weight is carried
in the wings.
In the case of, for example, our club's DG1000 basic trainers, the
aircraft is permitted to do unlimited aerobatics with a +7/-5 G rating
at MTOW. If that's not a requirement on a particular flight and you're
happy with the +5/-3 G like most other gliders then you could operate
at some higher weight.
fries.
Seat weight is one thing, CofG is quite another. With the tail ballast
box full, those same DG1000's are within the published CofG limit even
with two pilots well over 110 kg each.
Horney to Soar! GARY BOGGS Soaring 5 January 9th 10 04:15 PM
XC-Soar [email protected] Soaring 4 January 26th 09 04:06 PM
Get out of the Cold and SOAR! Mike Schumann Soaring 4 January 22nd 09 06:03 AM
XC Soar and iPaq 310? Brad[_2_] Soaring 4 November 19th 08 12:30 PM
why do you soar? Mark James Boyd Soaring 27 October 21st 03 07:48 PM
