On Mar 26, 12:12*pm, KevinFinke wrote:
Anybody use Vaseline? It seems to me that this stuff would be perfect. It's odorless, translucent and doesn't leave difficult stains on your clothing. Acid free, repeals moisture, doesn't oxidize, protects from UV rays, reacts with very few materials, and stays consistent over a wide range of temperatures. Porsche even recommended the stuff for maintenance of seals and corrosion protection for wheels. I can't stand how messy typical grease and white lithium are. When I bought my Austria years ago, the guy I bought it from gave me a tube of the stuff, said he used it for years on the pins and fittings. Worked for me! Brad |
KevinFinke wrote:
Anybody use Vaseline? It seems to me that this stuff would be perfect. It's odorless, translucent and doesn't leave difficult stains on your clothing. Acid free, repeals moisture, doesn't oxidize, protects from UV rays, reacts with very few materials, and stays consistent over a wide range of temperatures. Porsche even recommended the stuff for maintenance of seals and corrosion protection for wheels. I'm about 30% of the way into the large jar purchased in 1977 for my HP-14. That's ~650 riggings (of it and a Zuni) in the years since. Just don't store it sideways or upsidedown in hot temperatures... The only kinda-sorta engineering-based knock ever uttered in my presence was to the effect that - compared to (say) engineered/pricier greases - it had unknown pressure-loading properties. FWIW neither ship has ever developed slop in any of their main pins == good enough for this engineer! Besides - and be honest here - raise your hand if you've ever actually sought out that sort of engineering data; raise your other hand if you've ever measured the cyclic bearing loads on your ship's main pins. :-) Bob W. |
PDA recommendation | alex8735 | Soaring | 8 | March 22nd 08 08:29 AM |
HSI Recommendation? | randall g | Owning | 6 | June 13th 07 09:22 PM |
2.4 hours - no oil/grease on prop/windshield | Jay Honeck | Owning | 8 | September 30th 06 01:25 PM |
ELT Recommendation | Dean | Owning | 3 | April 26th 06 09:08 AM |
ASW 20 Recommendation? | Eric Greenwell | Soaring | 1 | August 11th 03 06:56 AM |
