Pawnee problems
Old April 30th 10, 12:20 PM posted to rec.aviation.soaring
Guy Byars[_2_]
Default Pawnee problems
On Apr 29, 9:44*pm, lanebush wrote:
It sounds like a prop governor issue to me. *A constant speed prop
will keep the RPM's constant until the engine power is reduced so
severely that the prop pitch has hit the limits. *Surging RPM's on a
constant speed prop are usually the result of a bad prop governor or
fluctuating engine oil pressure (which the prop governor uses to
function). *For example run the engine at 23" manifold pressure and
2400 RPM's. *Reduce the manifold pressure to 20" and the RPM's will
remain constant. *Continue reducing the engine power and eventually
when the engine is nearing idle the RPM's will start reducing (the
prop pitch has hit its limit of movement).
Pawnees have fixed pitch propellers. This could not be the problem.
Old April 30th 10, 03:47 PM posted to rec.aviation.soaring
vontresc
Pawnees have fixed pitch propellers. *This could not be the problem.
Depends on the Pawnee. IIRC the 150 and 235 have a FP prop, and the
260 (like the one in our club) has a constant speed prop.
Pete
Old April 29th 10, 06:55 PM posted to rec.aviation.soaring
Andy[_1_]
What do you mean by a power surge? To me a surge is a momentary
increase in something. Are you experiencing a momentary power
increase, or a momentary power reduction?
The PA28-180 I used to be a partner in experienced a few 200 rpm drops
at the most inconvenient times. It scared off 3 of the partners and
it took several years for me to find the problem. I became more
motivated after it happened to me during a high density altitude
takeoff.
It was caused by a P lead contact being shorter than spec. The P lead
contact pushes against the contact spring mounted on the mag
capacitor. The short contact didn't push the spring contact far
enough away from the rear mag cover and allowed it to sometimes arc to
the case. Dismantled the P lead contact and replaced the spacer tube
with a longer one from a spare P lead (same length as the other mag)
and the power loss problem has not been seen in the last 3 or more
years.
New mags, or even a complete engine rebuild, would not have fixed the
problem unless the P leads were also replaced. This wouldn't normally
be done since they are part of the aircraft wiring harness.
Really bad mag design since if the P lead comes unscrewed the mag is
shorted internally and behaves just as if the P lead is grounded.
Andy (GY)
Old April 29th 10, 08:18 PM posted to rec.aviation.soaring
BDS
"Andy" wrote in message
takeoff.
years.
Andy (GY)
Sorry - it is a sudden loss, not a sudden increase. Poor wording.
Thanks for the tip - we will take a look at this this weekend.
Bruce
Old April 30th 10, 12:56 AM posted to rec.aviation.soaring
BT[_3_]
"bds" wrote in message
takeoff.
years.
Andy (GY)
Bruce
To follow up on the P-Lead issue.. any short (break) in the old wire will
cause the problem as a bad P connector.
We traced one "mag" problem to the mag switch on the panel. Our PA-25-235
has two independent flip switches on the panel for the mags, one was bad.
We rebuilt one Mag 3 times in one day, it could not hold an internal timing.
We replaced the whole case.
BT
Old April 30th 10, 06:22 PM posted to rec.aviation.soaring
Andy[_1_]
That's confusing to me perhaps because I think short and break are
opposite conditions. Maybe you meant a break in the P lead insulation?
A short to ground in the P lead will disable the mag, an open circuit
P lead will leave the mag hot but will not make any difference to how
the engine runs. Similarly an intermittent open in the P lead will
have no effect on engine performance. An intermittent short in the P
lead could cause the problems described by the OP.
In the case of my PA28-180 an incorrectly fabricated P lead connector
allowed the P lead circuit to intermittently short inside the mag
case.
Andy
Old May 1st 10, 12:34 AM posted to rec.aviation.soaring
BT[_3_]
exactly... as you stated.. an intermittent short in the P-lead, in our case
it was in the switch on the panel.
caused intermittent engine rpm power loss.. and when happening within a
short span of elapsed time..
a sense of "engine roughness" and 150rpm drop/fluctuation
Most older Pawnee's have two separate switches on the panel, not a keyed
rotary switch.
case.
Andy
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 56 March 24th 14 06:21 AM
Looking for Pawnee [email protected] Soaring 1 July 13th 08 12:35 AM
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 4 October 17th 07 01:31 PM
PA-25 PAWNEE Rafgsa Centre Soaring 2 March 3rd 05 03:13 AM
Pawnee Damien Dyer Soaring 2 November 2nd 04 05:35 PM
