B-17 with V-1 Missile Pic
Old January 23rd 04, 07:48 PM
Bruce Simpson
On Fri, 23 Jan 2004 10:08:59 -0500, "Kevin Brooks"
Too bad they are wrong in using that particular choice of verbage, since we
KNOW the Loon's engine could indeed operate and produce thrust in a static
mode; the catapult just shortens the required take-off length to a
manageable amount (there is no doubt that if you fired one up on a
long-enough runway that it could accelerate to a speed sufficient to get it
airborne, but then you'd have to have an undercarriage of sorts, etc.). As
has been pointed out to you by many posters, some of whom have demonstrated
one hell of a lot more expertise in the subject matter than you have, the
pulse jet can indeed operate and produce thrust in a static mount, and some
can even be started without any external forced air supply. Why you are
being so hard-headed in the face of proof, both verbal and visual, that your
rants are wrong is beyond me.
Perhaps we should all remember that the Tomahawk crusie missile is
usually either air-droopped or launched using a solid rocket booster
-- is this because the gas-turbine engine that powers it is incapable
of operating without forward airspeed? Hell no -- its because it's
not only dangerous but quite impractical for a cruise missile (V1 or
Tomahawk) to take off like a conventional aircraft using a runway.
The V1 catapault served the same purpose as the Tomahawk's SRB --
simply a method of getting the entire craft up to flying speed in the
shortest amount of time and distance.
you can contact me via http://aardvark.co.nz/contact/
Old January 23rd 04, 11:27 AM
Cub Driver
Nice pic, but that's not a V-1. It's a USAF Loon which was U.S. made.
I haven't read the earlier posts, but if the question is whether a
B-17 ever carried a V-1, the answer is yes.
Glen Edwards was the test pilot in Utah on this project. The B-17
carried a captured V-1 under each wing. See Glen Edwards: Diary of a
Bomber Pilot www.warbirdforum.com/order.htm
all the best -- Dan Ford
email:
see the Warbird's Forum at
and the Piper Cub Forum at www.pipercubforum.com
V-4 Missile Possibilities robert arndt Military Aviation 42 January 23rd 04 05:40 AM
Australia to participate in US missile defence program David Bromage Military Aviation 40 December 13th 03 01:52 PM
Titor's Time Machine... USAF Missile Box??? Jason Strong Military Aviation 8 November 28th 03 12:51 AM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 09:47 PM
Surface to Air Missile threat PlanetJ Instrument Flight Rules 1 August 14th 03 02:13 PM
