Peter Dohm wrote:
But, that reduced difference in cruise performand was gained at the expense of nowe wheel steering. So what we are really comparing on the RV-6, 7, 8, and 9 models is a fully faired and free castering nosewheel versus an unfaired and fully steerable tailwheel. So the ground handling advantage does not automatically go to the nosewheel version. Nosewheel RV-6A has a higher rate of pilot loss of control than the taildragger RV-6. Ron Wanttaja |
"Peter Dohm" wrote:
On a more apples for apples comparison, when the lowly and "draggy" Cessna 150 and 152 are converted from a steerable oleo strut type nosewheel to a steerable tailwheel, they are reputed to gain at least 8 knots. I can believe that - and for anything with tires large enough for bush flying I can see nosewheel reducing the performance much more than the RV series, which do have more svelt nose gear and struts. Also, I know that some other experimentals (like Kitfox) can be built in either nosewheel or conventional gear, but I haven't searched for any performance comparisons between two such planes that differ only in gear. Besides, builders tend to make other changes in their homebuilts that muddle direct comparisions. Those are the reasons that I find myself willing to advocate for the tailwheel. So far I've only flown and landed an aircraft with one tire (glider) but when loaded the CG moves forward of the tire, but with no one on board the SGS 2-33 settles back on its tail, indicating the CG moves aft of the tire. (Okay okay - technically the 2-33 has 4 wheels! Two small rollers near the wingtips and a small one on the tail, plus the main tire. And there is a skid forward of the main tire.) |
Capt. Geoffrey Thorpe wrote:
"Peter Dohm" wrote in message ... With the quest for efficiency, in recent years, most of the newer tri-gear designs have featured free castering nose wheels. That has certainly reduced the aerodynamic drag of the nose wheel; Moving it to the back and reducing the size by a factor of 4 would do even more... Not to mention...even the venerable C150 disengaged the nosewheel in flight to free caster. Brian W |
"brian whatcott" wrote in message
... Capt. Geoffrey Thorpe wrote: "Peter Dohm" wrote in message ... With the quest for efficiency, in recent years, most of the newer tri-gear designs have featured free castering nose wheels. That has certainly reduced the aerodynamic drag of the nose wheel; Moving it to the back and reducing the size by a factor of 4 would do even more... Not to mention...even the venerable C150 disengaged the nosewheel in flight to free caster. Brian W Not the ones that I flew. On the 150 and 152 models with which I was familiar, the scissor link engaged a cam on the oleo casing when the nose strut was fully extended--which forced the nosewheel into its straight ahead position. Since the nosewheel steering force was applied through a pair of springs, the rudder operated normally with only a little more pressure; but, due to the limited nosewheel steering force which was available, tight turns on the ramp did require assistance from the brakes. Peter |
Peter Dohm wrote:
"brian whatcott" wrote in message ... Capt. Geoffrey Thorpe wrote: "Peter Dohm" wrote in message ... With the quest for efficiency, in recent years, most of the newer tri-gear designs have featured free castering nose wheels. That has certainly reduced the aerodynamic drag of the nose wheel; Moving it to the back and reducing the size by a factor of 4 would do even more... Not to mention...even the venerable C150 disengaged the nosewheel in flight to free caster. Brian W Not the ones that I flew. On the 150 and 152 models with which I was familiar, the scissor link engaged a cam on the oleo casing when the nose strut was fully extended--which forced the nosewheel into its straight ahead position. Since the nosewheel steering force was applied through a pair of springs, the rudder operated normally with only a little more pressure; but, due to the limited nosewheel steering force which was available, tight turns on the ramp did require assistance from the brakes. Peter This is a way more accurate description of the mechanism by which C-150s have nosewheels that point ahead in flight. I do agree! Does "Free-castoring" constitute something more effective than this for flight drag reduction? :-) Brian W |
![]() "brian whatcott" wrote in message ... Peter Dohm wrote: "brian whatcott" wrote in message ... Capt. Geoffrey Thorpe wrote: "Peter Dohm" wrote in message ... With the quest for efficiency, in recent years, most of the newer tri-gear designs have featured free castering nose wheels. That has certainly reduced the aerodynamic drag of the nose wheel; Moving it to the back and reducing the size by a factor of 4 would do even more... Not to mention...even the venerable C150 disengaged the nosewheel in flight to free caster. Brian W Not the ones that I flew. On the 150 and 152 models with which I was familiar, the scissor link engaged a cam on the oleo casing when the nose strut was fully extended--which forced the nosewheel into its straight ahead position. Since the nosewheel steering force was applied through a pair of springs, the rudder operated normally with only a little more pressure; but, due to the limited nosewheel steering force which was available, tight turns on the ramp did require assistance from the brakes. Peter This is a way more accurate description of the mechanism by which C-150s have nosewheels that point ahead in flight. I do agree! Does "Free-castoring" constitute something more effective than this for flight drag reduction? :-) Brian W Only in so much as the mechanism is smaller and much easier to fully enclose in a fairing that allows both vertical and yawing movement of the nosewheel. There was an STC'd speed modification offered for the Cessna 182, around 25 years ago, which included a telescoping fairing for the front oleo and steering mechanism. As far as I can recall, the modicication was extremely successfull in reducing drag; but it was expensive. In addition, there were possible safety concerns--in that it placed considerable aerodynamic side area farther forward (which would have increased the risk of an unrecoverable spin) and also may have made a preflight inspection of the steering mechanism much more dificult. Peter |
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote in message
... "Peter Dohm" wrote in message ... With the quest for efficiency, in recent years, most of the newer tri-gear designs have featured free castering nose wheels. That has certainly reduced the aerodynamic drag of the nose wheel; Moving it to the back and reducing the size by a factor of 4 would do even more... -- Not quite as much as I had personally supposed, but still a usefull amount. All the same, I'm learning to love the tailwheels. |
Why can't the tailwheel be faired? Maybe with something flexible, like
silicone rubber. |
On May 13, 3:34*pm, "Jon Woellhaf" wrote:
Why can't the tailwheel be faired? Maybe with something flexible, like silicone rubber. Yes, that or just pay the $43.60. http://www.vansaircraft.com/cgi-bin/...sc&product=twf --- Mark |
Jon Woellhaf wrote:
Why can't the tailwheel be faired? Maybe with something flexible, like silicone rubber. Some vintage tailwheels WERE faired or retracted. Brian W |
Off-topic Q | D Ramapriya | Piloting | 17 | July 23rd 09 04:30 AM |
Off-topic, but in need of help | Alan Erskine | Aviation Photos | 20 | January 5th 07 06:21 AM |
Almost on topic... | Richard Lamb | Home Built | 22 | January 30th 06 06:55 PM |
off topic, just a little--maybe? | L.D. | Home Built | 5 | August 27th 05 04:56 PM |
off topic | Randall Robertson | Simulators | 0 | January 2nd 04 01:29 PM |
