Get rid of the 4-way connector. They are unreliable, sometimes
causing cross-talk between paths. For peace of mind, use separate connectors. Bob - then traced my original TE troubles to a leak in the 4-way connector at the panel. *Replaced the connector this year. |
Get rid of the 4-way connector. *They are unreliable, sometimes
causing cross-talk between paths. *For peace of mind, use separate connectors. He mentioned it's a 5 way (although only 4 ports are currently being used) in another post, which I mean to take is a Winter unit. I've personally had good luck with those but I still prefer the positive locking threaded compression connection of my 4 way PZL version. I've had no leaks with either though, nor any crosstalk (ahem- well just be sure you didn't x-thread the PZL unit back together on after you show it off just before takeoff... heh.) Only problems I've heard of with the quick connects are leaks when the stock O-rings are old/crusty, which is an easy inspection/replacement (spend the extra $.12 on Viton!). While crosstalk is possible on the PZL 4-way with it's compression loaded seals, on the Winter 5-way there is no *real chance of it as the o-rings form a male seal at least 1/4" into the female sockets, effectively isolating the individual lines from each other in case of seal failure, even with dual seal failure. Rubber is not ageless... and again, silicone (spray, applied via cotton swab) is your friend, same for the probe/socket... It's also unlikely a probe connection problem since it is not a double- probe and I feel safe to assume the probe gets taped at each assembly of course. Borrowing a probe from another ship will help isolate any problems with the probe itself it It winds up being suspect. I may just have tunnelvision but really I think an old vario (with aged internal seals...) that has pitot and TE seems more suspect of crosstalk issues than a new Winter quick connect or probe performance issues... Slightly OT, I like to use these to seal pneumatic instrument hoses on barbs: http://www.jollygerman.com/products/goats/rings.shtml cheap, last bout 5yrs and gives a uniform 360deg seal (UNlike zipties...) that is easily future-accessed with no damage to hose/barb. Got idea from Borgelt but it took me a while to figure out what these little green rubber Cheerio things were *really* used for... OUCHY!!! -Paul |
![]() It's also unlikely a probe connection problem since it is not a double- probe and I feel safe to assume the probe gets taped at each assembly of course. Borrowing a probe from another ship will help isolate any problems with the probe itself it It winds up being suspect. The Brunswick socket won't have any internal seals. Just one tube inside another. Tape is unreliable. A short length of silicon tube tightly fitted over the joint is better. If the tube can stay in situ in the trailer then wire it or castrate it with a couple of Cheerios and leave it well alone. I may just have tunnelvision but really I think an old vario (with aged internal seals...) that has pitot and TE seems more suspect of crosstalk issues than a new Winter quick connect or probe performance issues... Seems the first port of call for an elimination exercise. I await some more real data with fascination. |
On May 24, 9:32*pm, jsbrake wrote:
Hi All, Whenever I accelerate, my varios bump up and tell me I'm climbing, then settle back to reality. *Any idea of what I need to look for to fix this? My setup: Kestrel 19, two static ports in the tail boom, pitot and TE in the fin. *The TE line is split under the seat using a Y connector and then travels to two varios (a Winter mechanical and a 1990-era audio/final- glide called a VariCalc). *Pitot and static lines are split behind the panel using T connectors. I replaced all the non-permanent tubing last year and they all seemed to be leak-free. Thanks! -John Next question is do they go down when you pull up. If both events occur, you are somewhat over compensated. Depending on the type of probe, this may be able to be tuned. UH |
On 25 May, 15:13, wrote:
On May 24, 9:32*pm, jsbrake wrote: Hi All, Whenever I accelerate, my varios bump up and tell me I'm climbing, then settle back to reality. *Any idea of what I need to look for to fix this? My setup: Kestrel 19, two static ports in the tail boom, pitot and TE in the fin. *The TE line is split under the seat using a Y connector and then travels to two varios (a Winter mechanical and a 1990-era audio/final- glide called a VariCalc). *Pitot and static lines are split behind the panel using T connectors. I replaced all the non-permanent tubing last year and they all seemed to be leak-free. Thanks! -John Next question is do they go down when you pull up. If both events occur, you are somewhat over compensated. Depending on the type of probe, this may be able to be tuned. UH To be pedantic what uncle Hank is saying is that in that case the compensation is spot on and for comfort you need to be a tads under compensated. Your tube is a Braunschweig type commonly known amongst Anglo-Saxon pilots as a Brunswick tube. They can be accurate but that is very difficult to achieve by machining to a drawing. They usually need calibrating by adjusting the length of tube distal to the lower slot. The shape of the end is critical as it needs to be square and sharp cornered. Not easy and devising the test bed be it bench or flight test is pretty tedious. The Brunswick is somewhat prone to yaw error. An Irving tube - the one with two holes each facing 50 degrees away from the aft centre line is less prone to yaw error and if accurately made to Frank Irving's drawing will give the right amount of under-compensation without calibration. If the degree of compensation proves to be your problem I recommend you buy a commercially made Irving tube. You could spend all summer messing around with a basically inferior tube. On no account put in a Nick's tube with only one hole as they even more prone to yaw error and poor compensation. Slingsbys may have supplied commercially made Brunswick tubes so you might have a good one if it is original. Another source of confusing error is the use of long lengths of soft silicon rubber tubing. (more than a few inches). Under varying 'G' it deforms and causes air movement within the plumbing. PVC with a little silicone grease and twist-wired at the joints is better if less sexy and tedious to connect. A well made PVC joint left alone will last for years. If you want a bit of bed-time reading try "The influence of acceleration on the sink rate of a sailplane and on the indication of the variometer" by Frank Brozel; Technical Soaring; Vol X No1 p10. Also anything you find by Frank Irving is always worth reading but I'd have to do some deep research to give you any references so you are on your own on that one. |
UH: When I pull up, the varios go up... both of 'em.
There's about 2' of silcon tubing in the circuit, all of it at the panel end. The second line of TE is silicon from the Y splitter that I installed, so call that about 4' long. The pvc lines end at the central pedestal where the hood and panel are removable, so there's silicon, then a 5-way quick-connector and then silicon to the instruments. I could probably remove about 4-6" of extra silicon, but it gives me some "play" for being able to get at the quick-connect without needing extra joints in my arms. I'm not doing heavy g manoevers, maybe 1.5 g on a pull-up, perhaps 0.75 g on a push-over. The most g I normally pull is during thermalling turns. I think I recall reading in the aircraft notes about a Brunswick tube. It appears to be factory made and the slots are well-defined. |
On 25 May, 17:29, jsbrake wrote:
UH: When I pull up, the varios go up... both of 'em. There's about 2' of silcon tubing in the circuit, all of it at the panel end. *The second line of TE is silicon from the Y splitter that I installed, so call that about 4' long. *The pvc lines end at the central pedestal where the hood and panel are removable, so there's silicon, then a 5-way quick-connector and then silicon to the instruments. *I could probably remove about 4-6" of extra silicon, but it gives me some "play" for being able to get at the quick-connect without needing extra joints in my arms. I'm not doing heavy g manoevers, maybe 1.5 g on a pull-up, perhaps 0.75 g on a push-over. *The most g I normally pull is during thermalling turns. I think I recall reading in the aircraft notes about a Brunswick tube. *It appears to be factory made and the slots are well-defined. An up indication no matter which way you push or pull isn't a matter of degree of compensation. A few inches of squashy tube won't make a difference and it sounds like you have relatively modest quantities. I am puzzled why different manoeuvres have the same effect. It somewhat suggests multiple pathology. Two questions ref egg sucking. Pneumatic netto was common in the seventies, presumably there is no cruise/climb switch in the plumbing to the Winter? When you did your leak test did you connect to the Brunswick tube? If so did you remember to put a piece of wire (about .020") up the slots and into the plastic test pipe to stop the pipe sealing around the end of the probe? Make an exact diagram of all the plumbing. It helps enormously in keeping track and thinking about what effect a leak at any position will have. |
On May 25, 1:23*pm, Peter Gray wrote:
On 25 May, 17:29, jsbrake wrote: UH: When I pull up, the varios go up... both of 'em. There's about 2' of silcon tubing in the circuit, all of it at the panel end. *The second line of TE is silicon from the Y splitter that I installed, so call that about 4' long. *The pvc lines end at the central pedestal where the hood and panel are removable, so there's silicon, then a 5-way quick-connector and then silicon to the instruments. *I could probably remove about 4-6" of extra silicon, but it gives me some "play" for being able to get at the quick-connect without needing extra joints in my arms. I'm not doing heavy g manoevers, maybe 1.5 g on a pull-up, perhaps 0.75 g on a push-over. *The most g I normally pull is during thermalling turns. I think I recall reading in the aircraft notes about a Brunswick tube. *It appears to be factory made and the slots are well-defined. An up indication no matter which way you push or pull isn't a matter of degree of compensation. A few inches of squashy tube won't make a difference and it sounds like you have relatively modest quantities. I am puzzled why different manoeuvres have the same effect. It somewhat suggests multiple pathology. Two questions ref egg sucking. Pneumatic netto was common in the seventies, presumably there is no cruise/climb switch in the plumbing to the Winter? It did have pneumatic netto, but the plumbing was removed before I got the ship. I still have the brass fitting. When you did your leak test did you connect to the Brunswick tube? If so did you remember to put a piece of wire (about .020") up the slots and into the plastic test pipe to stop the pipe sealing around the end of the probe? I removed the Brunswick and connected directly to the stub sticking out of the fin. Air flows easily through the Brunswick. Make an exact diagram of all the plumbing. It helps enormously in keeping track and thinking about what effect a leak at any position will have. Straight runs from point of opening (fin for TE/pitot, 2 in boom for static) to the pedestal. From there, it's silicon to the quick- connect and then to the instruments. Pitot and Static are both T- split in the panel, the TE is Y-split under the seat. Nothing else in the circuit. Pitot goes to ASI and VariCalc; Static goes to ASI and Alt; TE to the varios; Capacity to the mech vario. Basic setup, matches what I found on W&W and Winter websites about connecting plumbing to instruments. |
I've gone over the tubing looking for leaks and it all seems patent.
I pulled everything apart, lubed and reconnected and it's looking good (including the much-maligned quick-connector). Unfortunately, I haven't had a chance to fly it to find out if the tubing was my problem or if it's the instruments (but BOTH varios behaving badly the same way seems to indicate that it's not the instruments). On the plus side, one off my club's members is a licenced instrument mechanic and he's said he'll take a look at my setup when we can get together. Hopefully that'll get it fixed. Now, is there some way that I can use this as an excuse to convince my wife that the "mistress" needs a panel upgrade? |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question re CNX-80 | ROBIN FLY | Instrument Flight Rules | 6 | April 15th 04 04:05 PM |
Question about KLN-89B | Casey Wilson | Instrument Flight Rules | 9 | March 8th 04 08:07 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
