L13 Blanik Mandatory Bulletin
Old June 28th 10, 07:27 PM posted to rec.aviation.soaring
Walter[_2_]
Default L13 Blanik Mandatory Bulletin
Blanik owners and pilots might want to read this call for help from the home
of the Red Bull Blanix team:
http://www.streckenflug.at/popup.php...hilfe.pdf&xy=J
and this question from the author of the above PDF:
Hello,
Does anyone know Detail Information on Blaník which have been modified to
L-13 Type A1, the so called "Llewellyn Modification"?
Even information on the Aeroclub that does this Modification or contact
data, also the name of the Aeroclub would be very helpful for me !
Happy landings and Best Regards!
Walter
Old July 13th 10, 03:39 AM
Ronald Locke Ronald Locke is offline
Junior Member
First recorded activity by AviationBanter: Jul 2010
Quote:
Originally Posted by Ernst View Post
After a fatal accident in Austria LET issued a Mandatory Bulletin:
http://www.let.cz/files/bulletines/M...9a_english.pdf
EASA issued an Emergency Airworthiness Directive:
http://www.caa.co.uk/docs/33/easa_ad_2010_0119_E.pdf
Could anyone advise the current situation in USA, Canada and Europe regarding the grounding of L13 Blaniks ?
Have many been put back into service as a result of satisfactory wing spar inspections, or do most remain grounded due to the fact that the required average usage statistics required by LET cannot be met, and with respect seem most unreasonable.
For instance – what two seater training glider (or for that matter any two seater glider) would have an average of 35% dual and 65% solo usage! More likely, greater than 80% dual would be a more realistic figure I would have thought.
Old July 13th 10, 03:18 PM posted to rec.aviation.soaring
Tony[_5_]
On Jul 12, 9:39*pm, Ronald Locke Ronald.Locke.
More likely, greater than 80% dual *would be a more realistic figure I
would have thought.
Ronald Locke
I haven't heard that the FAA has issued an airworthiness directive
yet, so no L-13's in the USA should be grounded.
Old July 13th 10, 05:03 PM posted to rec.aviation.soaring
John Scott[_3_]
Ours was inspected per the bulletinby 2 IAs (concurrently), deemed
airworthy, and signed off. We're flying it.
It had just been down for an annual when the bulletin was released.
John
Old July 13th 10, 05:23 PM posted to rec.aviation.soaring
Bob McKellar
"John Scott" wrote in message
John
Same story for my club, almost.
We pulled the wings and inspected everything and it went fine. Ours is
heading into annual next month, but we didn't want to wait.
Bob McKellar
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
Mandatory ELT [email protected] Soaring 9 March 8th 05 03:01 PM
ELT Mandatory ? Jim Culp Soaring 20 June 19th 04 06:40 PM
New security bulletin gatt Piloting 28 June 9th 04 10:33 PM
Grob 103 bulletin becomes AD Mike Borgelt Soaring 0 October 3rd 03 12:47 AM
