John Doe wrote: How far-fetched is the idea, to use a propeller or jet engine (radio controlled type?) to push an in-line skater? How does aircraft takeoff thrust compare to using a conventional motor and wheel to push oneself along the ground? What sort of incline would be achievable at say a skater weight of about 160 pounds? I think the rolling resistance can be assumed to be zero or maybe the same as a small aircraft. Years ago (maybe late 1990s) one of those 'whacky invention' type TV shows featured a guy with jet engines mounted on the tails of his skis. No need for a chair lift, he'd just ski uphill. So it has been done, just make sure your life insurance is paid up. John -- John Clear - http://www.clear-prop.org/ |
usenet jac.users.panix.com (John Clear) wrote:
John Doe jdoe usenetlove.invalid wrote: How far-fetched is the idea, to use a propeller or jet engine (radio controlled type?) to push an in-line skater? How does aircraft takeoff thrust compare to using a conventional motor and wheel to push oneself along the ground? What sort of incline would be achievable at say a skater weight of about 160 pounds? I think the rolling resistance can be assumed to be zero or maybe the same as a small aircraft. Years ago (maybe late 1990s) one of those 'whacky invention' type TV shows featured a guy with jet engines mounted on the tails of his skis. No need for a chair lift, he'd just ski uphill. Inline skating is like a combination of different sports, including skiing. One unique difference is that in-line skating requires man-made terrain. So it has been done, just make sure your life insurance is paid up. If you wear lots of protective gear and consider the risks, safety should not be a concern. On TV, you see skaters and cyclists who do not wear protective gear, apparently many people enjoy seeing the accidents, but I just change the channel. Carelessly riding a large displacement motorcycle years ago makes anything I do now days pale in comparison. This Still researching the issue, but by the lack of detailed comment, I get the impression that propeller power is nowhere near efficient as conventional motor and wheel on the ground propulsion. That is the question. -- John -- John Clear - jac panix.com http://www.clear-prop.org/ |
![]() "John Doe" wrote in message ... usenet jac.users.panix.com (John Clear) wrote: John Doe jdoe usenetlove.invalid wrote: How far-fetched is the idea, to use a propeller or jet engine (radio controlled type?) to push an in-line skater? How does aircraft takeoff thrust compare to using a conventional motor and wheel to push oneself along the ground? What sort of incline would be achievable at say a skater weight of about 160 pounds? I think the rolling resistance can be assumed to be zero or maybe the same as a small aircraft. Years ago (maybe late 1990s) one of those 'whacky invention' type TV shows featured a guy with jet engines mounted on the tails of his skis. No need for a chair lift, he'd just ski uphill. Inline skating is like a combination of different sports, including skiing. One unique difference is that in-line skating requires man-made terrain. So it has been done, just make sure your life insurance is paid up. If you wear lots of protective gear and consider the risks, safety should not be a concern. On TV, you see skaters and cyclists who do not wear protective gear, apparently many people enjoy seeing the accidents, but I just change the channel. Carelessly riding a large displacement motorcycle years ago makes anything I do now days pale in comparison. This Still researching the issue, but by the lack of detailed comment, I get the impression that propeller power is nowhere near efficient as conventional motor and wheel on the ground propulsion. That is the question. -- No that is the answer. Keith |
On 23/07/2010 09:01, Keith Willshaw wrote:
"John Doe" wrote in message ... usenet jac.users.panix.com (John Clear) wrote: John Doe jdoe usenetlove.invalid wrote: How far-fetched is the idea, to use a propeller or jet engine (radio controlled type?) to push an in-line skater? How does aircraft takeoff thrust compare to using a conventional motor and wheel to push oneself along the ground? What sort of incline would be achievable at say a skater weight of about 160 pounds? I think the rolling resistance can be assumed to be zero or maybe the same as a small aircraft. Years ago (maybe late 1990s) one of those 'whacky invention' type TV shows featured a guy with jet engines mounted on the tails of his skis. No need for a chair lift, he'd just ski uphill. Inline skating is like a combination of different sports, including skiing. One unique difference is that in-line skating requires man-made terrain. So it has been done, just make sure your life insurance is paid up. If you wear lots of protective gear and consider the risks, safety should not be a concern. On TV, you see skaters and cyclists who do not wear protective gear, apparently many people enjoy seeing the accidents, but I just change the channel. Carelessly riding a large displacement motorcycle years ago makes anything I do now days pale in comparison. This Still researching the issue, but by the lack of detailed comment, I get the impression that propeller power is nowhere near efficient as conventional motor and wheel on the ground propulsion. That is the question. -- No that is the answer. Keith Jet / Propellor / rubber band. It doesnt mallet what the power supply is. Work out where the center of thrust/pull is - Probably if on a skater approx 1.2metres up. When the skater hit a bump to large for the front to quickly rise over, the skater kisses the ground. Think water skiing - It is a challenge to get up o the skiis, and then the second you relax, and let the ski dig it, you are in the water |
Giles Ayling giles tvp.ltd.uk wrote:
Keith Willshaw wrote: "John Doe" wrote in message .... I get the impression that propeller power is nowhere near efficient as conventional motor and wheel on the ground propulsion. That is the question. No that is the answer. Jet / Propellor / rubber band. It doesnt mallet what the power supply is. Are you using speech recognition? Or were you drunk? Just curious. Work out where the center of thrust/pull is - Probably if on a skater approx 1.2metres up. When the skater hit a bump to large for the front to quickly rise over, the skater kisses the ground. Skating is extremely flexible. One way to cope is to step over the obstacle. Another way is by keeping your weight on your rear wheels. And yet another way to cope with larger obstacles is called "scissoring". And of course you can do stuff in combination. If none of the above works, when you hit a bump that radically slows one skate, you can quickly put all of your weight on the other skate and simultaneously steer inwards with that good skate to maintain your balance. You learn to do that stuff without thinking. But, coincidentally, large unexpected obstacles is exactly why I made big front wheel skates, a 140 mm front wheel with 80 mm trailing wheels. Love them and use them for rough street skating regularly. http://www.flickr.com/photos/27532210@N04/3056505603/ http://www.flickr.com/photos/27532210 N04/3056505603/ By the way... If anyone here (young enough to run or at least to remember doing fun things) has never heard of "powered paragliding", check it out! It is (lighter than) ultra light powered flight. Amazing stuff IMO. Dozens of videos on YouTube. -- Think water skiing - It is a challenge to get up o the skiis, and then the second you relax, and let the ski dig it, you are in the water |
Jim Yanik wrote:
(John Clear) wrote in John Doe wrote: How far-fetched is the idea, to use a propeller or jet engine (radio controlled type?) to push an in-line skater? How does aircraft takeoff thrust compare to using a conventional motor and wheel to push oneself along the ground? What sort of incline would be achievable at say a skater weight of about 160 pounds? I think the rolling resistance can be assumed to be zero or maybe the same as a small aircraft. Years ago (maybe late 1990s) one of those 'whacky invention' type TV shows featured a guy with jet engines mounted on the tails of his skis. No need for a chair lift, he'd just ski uphill. So it has been done, just make sure your life insurance is paid up. how did he -not- fall on his behind? get on some skates,tie a rope to your ankles,and have someone tow you,and see if you can stay upright. You need the center of pressure to be in the center of your mass. Ideally, Yes. Also, putting a motor on skates weighs it down and destroys most of the quality of skating. However, I have put a motor on my skates, powering the center two wheels on one skate, and it worked very well propulsion wise. The problem was with the weight and the motor being too close to the ground. |
On Jul 21, 8:57*pm, John Doe wrote:
How far-fetched is the idea, to use a propeller or jet engine (radio controlled type?) to push an in-line skater? How does aircraft takeoff thrust compare to using a conventional motor and wheel to push oneself along the ground? What sort of incline would be achievable at say a skater weight of about 160 pounds? I think the rolling resistance can be assumed to be zero or maybe the same as a small aircraft. Anybody know about Everglades/marsh air powered boats? Maybe I should do a little research on that one. One thing for sure, if there ever is such a thing as a jetpack, it will very easily push an in-line skater before it will lift a person off of the ground. Thanks. -- (Crossposted, please feel free to remove the other group) One thing is for sure it can't be too high or low relative to center of gravity. |
"David E. Powell" David_Powell3006 msn.com wrote:
One thing is for sure it can't be too high or low relative to center of gravity. That may be less critical than you think. Propeller propulsion would be the freest form since it would not depend on the ground, the full benefit of skating depends on freedom of movement. Push stick based propulsion (a bulky prototype is currently being used here) is stable, even when being pushed from knee level. I get a third wheel effect, and stroking with my legs is not required. Pushing/stroking is a HUGE source of instability while inline street skating. |
Just push the blue button! | Darkwing | Piloting | 71 | October 20th 08 04:12 PM |
PUSH START | stanley adelson | Aviation Photos | 0 | July 15th 08 01:16 AM |
Push to Talk Switch | Jackal24 | Piloting | 23 | December 26th 04 10:01 PM |
Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 05:57 PM |
Young Eagles push (USA) | John H. Campbell | Soaring | 0 | September 22nd 03 03:48 PM |
