On Thu, 30 Oct 2003 23:56:10 GMT, "Blueskies" wrote:
I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... Roger, what did you seal/paint the floor with? I need to do that soon before it gets too cold or wait 'till spring... First I pressure washed it, then acid etch followed by another wash. Gave it 3 days to dry with the heat on, and then gave it three coats of 2-part epoxy from Lowe's. Other than that I used no sealers. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) |
![]() "Roger Halstead" wrote in message ... On Thu, 30 Oct 2003 23:56:10 GMT, "Blueskies" wrote: I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... Roger, what did you seal/paint the floor with? I need to do that soon before it gets too cold or wait 'till spring... First I pressure washed it, then acid etch followed by another wash. Gave it 3 days to dry with the heat on, and then gave it three coats of 2-part epoxy from Lowe's. Other than that I used no sealers. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Right. Make sure to use no sealer, as that could interfere with the epoxy. Best to wait 30 days to put down any epoxy, to let the concrete finish 99% of its cure. -- Jim in NC |
("Roger Halstead" wrote)
First I pressure washed it, then acid etch followed by another wash. Gave it 3 days to dry with the heat on, and then gave it three coats of 2-part epoxy from Lowe's. Other than that I used no sealers. We etched Margene's sister's garage floor with muric(sp?) acid after scrubbing it clean, by hand. Our problem was humidity. I don't think we let the floor get dry enough. It was hot and muggy out when we poured the paint out of the can and rolled it out/on - the floor was trying to be a little damp anyway. The other mistake was, Margene's sister drove on it too soon - next day IIRC. Long story short, it wasn't our best effort. Paint pulled up in high traffic areas after a year. Dry floor, low humidity, let things dry like Roger said. You'll be glad you did. We used Sears garage floor paint. It was us, not the paint, that was the problem with our project. Same amount of effort doing it wrong as doing it right - wish we had done it right. -- Montblack |
On 30 Oct 2003 02:56 PM, Blueskies posted the following:
I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... If you make it 2 feet wider, you will be able to get a DeHavilland Beaver through the door without any diagonal monkey motion (should the need ever arise). 8^) ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
![]() "Del Rawlins" wrote in message ... On 30 Oct 2003 02:56 PM, Blueskies posted the following: I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... If you make it 2 feet wider, you will be able to get a DeHavilland Beaver through the door without any diagonal monkey motion (should the need ever arise). 8^) ---------------------------------------------------- Del Rawlins- If I built the 48', and got a Beaver, I would gladly go through any necessary gyrations! g -- Jim in NC |
Del Rawlins wrote: On 30 Oct 2003 02:56 PM, Blueskies posted the following: I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... If you make it 2 feet wider, you will be able to get a DeHavilland Beaver through the door without any diagonal monkey motion (should the need ever arise). And if that DeHavilland'll fit, it _otter_ be adequate for anything else! |
I was wishing for 62 x 40, but $$$ got in the way, or should I say lack of $$$. I wanted to be sure the PT17 would fit,
if I ever find one. For now it is just a big open space - room of dreams! -- Dan D. .. "Del Rawlins" wrote in message ... On 30 Oct 2003 02:56 PM, Blueskies posted the following: I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... If you make it 2 feet wider, you will be able to get a DeHavilland Beaver through the door without any diagonal monkey motion (should the need ever arise). 8^) ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Hi Dan,
What radiant system did you use ?? I am also building up in NH. Moving from FL back to the snowbelt. My hangar here is 46 x 60 x 12 and I used muriac acid to etch and then used a product from Home Depot (can't remember what it was and I have never had a problem with it. Never got the tire marks like other owners here had. My hangar in NH will be 48x60x14 with radiant heat. Just finished the foundation walls yesterday and laying the insulation next week. Merle "Blueskies" wrote in message .com... I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... Roger, what did you seal/paint the floor with? I need to do that soon before it gets too cold or wait 'till spring... -- Dan D. . "Roger Halstead" wrote in message ... On Wed, 29 Oct 2003 02:38:48 GMT, "Blueskies" wrote: Pole barn is the way to go here in MI. The stick built version was 2x the cost of the poles.... I built a 28 by 40 foot shop. The floor is high strength concrete with a rat wall type foundation. (I wish I had gone with a standard foundation although no problems with the rat wall). We used stick built,, with one inch styrofoam over the outside covered with vinyl siding. The inside is barn metal which is what most use on the outside. The walls are filled with roll insulation while the ceiling has 16 inches of cellulose blown in. If condensation is not a problem I'd use the cellulose for insulation although the foam seals "tight". I also have one inch of styrofoam under the concrete. The cost (using a contractor) was little different than had I gone with a pole type construction finished in the same manner. The only reason I wish I had gone with a conventional foundation which would not have added more than a couple hundred dollars over the rat wall is thermal isolation. I'd put a thermal barrier between the floor and the outside wall/foundation using either half inch bead board or styrofoam. Even with the two big doors plus the man door it's quite economical to heat and I can keep it comfortable with a little window air conditioner in the hot summer. The shop is just north of my garage, but I'm based at 3BS (Midland) which is about 11.3 on the 337 radial from MBS. The second page of my G-III construction diary has some photos of the construction at http://www.rogerhalstead.com/glasair2.htm Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) |
Durapex (http://www.durapex.com/heating.asp), from Menards here in MI. I will use a 70,000 BTU water heater for the heat source.
I figured out how to put some pix up on my Yahoo account. See: http://f1.pg.briefcase.yahoo.com/bc/...ase.yahoo.com/ -- Dan D. .. "Merle Wagner" wrote in message link.net... Hi Dan, What radiant system did you use ?? I am also building up in NH. Moving from FL back to the snowbelt. My hangar here is 46 x 60 x 12 and I used muriac acid to etch and then used a product from Home Depot (can't remember what it was and I have never had a problem with it. Never got the tire marks like other owners here had. My hangar in NH will be 48x60x14 with radiant heat. Just finished the foundation walls yesterday and laying the insulation next week. Merle "Blueskies" wrote in message .com... I am putting up a 48x48 'hanger' with radiant heat floor. Just now getting to the wiring stage. I've got pictures of the construction but no where to post them... Roger, what did you seal/paint the floor with? I need to do that soon before it gets too cold or wait 'till spring... -- Dan D. . "Roger Halstead" wrote in message ... On Wed, 29 Oct 2003 02:38:48 GMT, "Blueskies" wrote: Pole barn is the way to go here in MI. The stick built version was 2x the cost of the poles.... I built a 28 by 40 foot shop. The floor is high strength concrete with a rat wall type foundation. (I wish I had gone with a standard foundation although no problems with the rat wall). We used stick built,, with one inch styrofoam over the outside covered with vinyl siding. The inside is barn metal which is what most use on the outside. The walls are filled with roll insulation while the ceiling has 16 inches of cellulose blown in. If condensation is not a problem I'd use the cellulose for insulation although the foam seals "tight". I also have one inch of styrofoam under the concrete. The cost (using a contractor) was little different than had I gone with a pole type construction finished in the same manner. The only reason I wish I had gone with a conventional foundation which would not have added more than a couple hundred dollars over the rat wall is thermal isolation. I'd put a thermal barrier between the floor and the outside wall/foundation using either half inch bead board or styrofoam. Even with the two big doors plus the man door it's quite economical to heat and I can keep it comfortable with a little window air conditioner in the hot summer. The shop is just north of my garage, but I'm based at 3BS (Midland) which is about 11.3 on the 337 radial from MBS. The second page of my G-III construction diary has some photos of the construction at http://www.rogerhalstead.com/glasair2.htm Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) |
On Sat, 01 Nov 2003 00:21:56 GMT, "Merle Wagner"
wrote: Hi Dan, What radiant system did you use ?? I am also building up in NH. Moving from FL back to the snowbelt. My hangar here is 46 x 60 x 12 and I used muriac acid to etch and then used a product from Home Depot (can't remember what it was and I have never had a problem with it. Never got the tire marks like other owners here had. My hangar in NH will be 48x60x14 with radiant heat. Just finished the foundation walls yesterday and laying the insulation next week. I put in a 75,000 BTU IR tube heater. It heats all the objects in the room. You open the door in the winter, drive in, shut the doors and it's warm ... Tools are comfortable to handle in the mornings. Costs less than half to heat as my house even with the two big garage doors. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Worthy EAA Construction Books | Brock | Home Built | 5 | September 16th 03 07:48 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
