How to find someone to inspect a sailplane in New York?
Old August 28th 10, 06:11 AM posted to rec.aviation.soaring
Frank Whiteley
Default How to find someone to inspect a sailplane in New York?
On Aug 27, 9:24*pm, Jeff Casto
I'm considering buying a wood sailplane in New York and want to hire
someone knowledgeable to inspect it. How do I go about locating someone
trustworthy and qualified to do the job?
Thanks,
Jeff
Must be the Std Austria. Been a long time since I owned an SHK, which
was the 17m version.
Not sure if the glues were casien or resorcinol based. If the joins
are black, it's resorcinol.
I've heard of a very few tail mount frames coming unglued or needing
re-gluing. Of course, landing the tail wheel over a runway berm puts
a lot of stress on that frame and storage counts also.
They were among the best of the wood gliders, but the Dart 17R just
might be tops. I could never out climb one with the SHK.
Frank Whiteley
Old August 28th 10, 06:34 AM posted to rec.aviation.soaring
mike malis
It has been said of the SHK, "You can trust a tree", but wooden
gliders are made up of tree bits. The spar laminations are not
resorcinal, but modified casien glue typically. I have seen clear
adhesive failures in one case.
Knowledgeable wood and fabric mechanics do not grow on, ahem, trees
Would you consider a nice two seat metal ship instead?
Old August 28th 10, 07:21 AM posted to rec.aviation.soaring
Frank Whiteley
On Aug 27, 10:34*pm, mike malis wrote:
It has been said of the SHK, *"You can trust a tree", *but wooden
Casein glues are known to fail after about 25 years. When I was in
the UK, the Duxford museum was re-gluing a de Havilland Mosquito.
From another (dated) thread
quote
Recently, I restored a 1939 British glider.
It was casein.
There was not one glue failure in the entire project.
Not one.
It had been maintained in a proper manner. Varnish and such.
I have found that if the Casein is bad , the wood is bad too. If it
has had
such poor care, the entire project should be in a museum and not
flown.
Regards,
Bob Gaines
Marietta, GA
/unquote
Resorcinol and urea formaldehyde glues are regarded as superior, but I
recall some comments that early resorcinols were showing some
mechanical losses.
My recommendation would be to ask Uncle Hank. Use the SSA Member
Locator and search Henry Nixon. He'll know who's qualified in the
area. Second choice would be to contact M&H or the Soaring Museum.
Peter Smith might know who to ask.
Good luck,
Frank Whiteley
Navy Grounds 104 Hornets To Inspect For Airframe Cracking Mike Naval Aviation 0 March 14th 10 02:56 AM
"Navy Grounds 104 Hornets To Inspect For Airframe Cracking" mike Naval Aviation 0 March 14th 10 12:04 AM
DG AD Note - Just Inspect or Must Fix? ContestID67 Soaring 2 February 20th 06 08:40 PM
ME-262 in New York? Bob Kuykendall Home Built 2 July 18th 03 06:04 AM
