On Sep 19, 11:52*am, "kirk.stant" wrote:
On Sep 18, 5:53*pm, ray conlon wrote: Having flown a number of different gliders and power planes over the years, no two of them handle or land the same, different aircraft take different methods of landing, what works for a Cessna 150 may not do so well in a Bonanza, or what works in a 2-33 wont wor'k *well in a Blanik,Lark,ASK21, etc. Thats why we have instructors to work us throught the transistion. Orvile and Willber were the only guys who had a valid reson to teach themselves to fly.. Having flown a number of gliders and power planes over the years, they are all pretty much landed the same - at the slowest possible speed allowed by the configuration of the landing gear (and the conditions at hand - for example a strong gusty crosswind may require a different technique than a calm day on a short field). *It's that gear configuration that requires different techniques for different airplanes, not aerodynamics. That gear configuration is a driving factor in how 2-33s and Blaniks are landed vs how most modern gliders are landed (I say most because the PW-5 & 6 may be different, but I have no first hand experience in those two). If a student isn't taught the REASON for the specific landing technique (fixed attitude, slightly tail low, "flown-on" in 2-33s and Blaniks, due to weak tail vs tail and main at same time, min energy in glass such as K-21 or G-103) they will probably think that the first technique they are taught will apply to all future gliders. *That can get very expensive. Kirk 2-33 should NOT be "flown on" as you suggest above............ Yes, bottom line is "low energy landing" in ANY aircraft..........Low energy means "slow"....but not "slow a possible" it means slow as practical..........this leads to the nuances. But any glider landed in a low energy configuration will not tear itself into pieces as the 2-33 trained grob pilot did in the scenerio referred to in the earlier post. Thousands of pilots have been properly trained in 2-33 and progress seccessfully to all kinds of "more advanced" gliders without issue.......... True that a poorly trained 2-33 pilot, or one who has degenerated into bad habbits, may take those problems with him into the more advanced gliders.........but this is a training / pilot problem, not an aircraft problem. I see plenty of pilots, airplane and glider, who have developed some bad landing habits and have never set foti n a 2-33. The 2-33 will withstand less than perfect landings by beginners because it is designed to do so as a TRAINER. We are all allowed to make mistakes.........The idea is for the student / instructor to work out all these problems early in the program. Once consistant good landings are made in the 2-33 the pilot can then easily adapt to any glider. If poor landing technique is tolerated in the 2-33 then the less forgiving gliders will show this defeciency. But this is all the more arguement for the 2-33 as a trainer, and not using Grob or ASK as a trainer....... Cookie |
On Sep 18, 11:50*am, "kirk.stant" wrote:
On Sep 18, 3:04*am, " wrote: A 2-33 should be landed just like any other "nose dragger glider" (G-103 II or ASK 21 etc) Really? *The correct landing procedure for a 2-33 (and Blanik) is a recipe for high energy landings in K-21s or G-103s (or worse case, a high sink rate bounced landing leading to the infamous "galloping Grob"!). *I hope you have a long runway and a big budget for brake pads! Kirk Please explain further........how is the correct landing procedure for a 2-33 going to result in a high energy landing in a Grob? IMHO....the correct landing procedure for a 2-33 (low energy, slow speed, nose high, tail low, etc) will result in a similar low energy landing in a Grob..........this would be a short runway landing, with little or no need for brakes...... Cookie |
On Sep 18, 7:52*pm, "
wrote: On Sep 18, 11:50*am, "kirk.stant" wrote: On Sep 18, 3:04*am, " wrote: A 2-33 should be landed just like any other "nose dragger glider" (G-103 II or ASK 21 etc) Really? *The correct landing procedure for a 2-33 (and Blanik) is a recipe for high energy landings in K-21s or G-103s (or worse case, a high sink rate bounced landing leading to the infamous "galloping Grob"!). *I hope you have a long runway and a big budget for brake pads! Kirk Please explain further........how is the correct landing procedure for a 2-33 going to result in a high energy landing in a Grob? IMHO....the correct landing procedure for a 2-33 (low energy, slow speed, nose high, tail low, etc) will result in a similar low energy landing in a Grob..........this would be a short runway landing, with little or no need for brakes...... Cookie That is exactly correct. However, regardless of instructor efforts to prevent it, students will learn on their own a 2-33 stops really well with the skid on the runway and the more weight on the skid, the faster it stops. Trying to teach a student not to use this very useful trick is fruitless. This primary learning will transfer to a Grob and other gliders where it puts the new pilot at risk of a damaging accident. When a new pilot really, really needs to stop, it's going to be hard for him not to push the nose down. |
On Sep 20, 2:26*am, bildan wrote:
This primary learning will transfer to a Grob and other gliders where it puts the new pilot at risk of a damaging accident. *When a new pilot really, really needs to stop, it's going to be hard for him not to push the nose down. When you really really need to stop, pushing the nose down hard works well on anything that doesn't have a nose wheel. We were taught to do it in an emergency in the Blanik L13 and I've seen it done in a Grob. By "really really need to stop" I mean that you're going to die or be seriously injured if you don't stop and you don't care about damaging the nose skin and structure or slamming the tail back down afterwards. Incidentally, someone landed their Cirrus on a suburban street here on Sunday morning. They reportedly deliberately used the poles on either side of a pedestrian crossing to slow down. I believe my instructors mentioned tree trunks in this context, but whatever... http://tvnz.co.nz/national-news/glid...-alive-3785681 http://www.stuff.co.nz/national/4144...g-and-a-prayer http://www.nzherald.co.nz/nz/news/ar...ectid=10674749 |
On Sep 18, 6:52*pm, "
wrote: Please explain further........how is the correct landing procedure for a 2-33 going to result in a high energy landing in a Grob? IMHO....the correct landing procedure for a 2-33 (low energy, slow speed, nose high, tail low, etc) will result in a similar low energy landing in a Grob..........this would be a short runway landing, with little or no need for brakes...... Cookie So, when you are teaching landings to a student in a 2-33, do you first sit him in the front seat, level the wings, then hold the nose up until the tailwheel is on the ground and say "this is your landing attitude"? Do you do that in a G-103? Didn't think so. Where that tailwheel is relative to the ground is the difference. The landing angle of attack is probably about the same, but a student who learns to land on the main in a 2-33, nice and slow, but never touching the tailwheel, then who transfers that technique to the G-103, is a prime candidate for high energy landing problems. It's not a killer problem - but it needs to be taught correctly! Kirk |
At 16:07 19 September 2010, kirk.stant wrote:
On Sep 18, 6:52=A0pm, " wrote: Please explain further........how is the correct landing procedure for a 2-33 going to result in a high energy landing in a Grob? IMHO....the correct landing procedure for a 2-33 (low energy, slow speed, nose high, tail low, etc) will result in a similar low energy landing in a Grob..........this would be a short runway landing, with little or no need for brakes...... Cookie So, when you are teaching landings to a student in a 2-33, do you first sit him in the front seat, level the wings, then hold the nose up until the tailwheel is on the ground and say "this is your landing attitude"? Do you do that in a G-103? Didn't think so. Where that tailwheel is relative to the ground is the difference. The landing angle of attack is probably about the same, but a student who learns to land on the main in a 2-33, nice and slow, but never touching the tailwheel, then who transfers that technique to the G-103, is a prime candidate for high energy landing problems. It's not a killer problem - but it needs to be taught correctly! Kirk I did exactly that when teaching students to land a G103 except I would push down on the tail so that they could see the picture in front of them. The correct attitude is that where the main wheel and tailwheel touch the ground at the same time. The glider should then be kept running on the main and tailwheel for as long as possible, directional control is lost when the glider goes nosewheel down. |
On Sep 19, 12:07*pm, "kirk.stant" wrote:
On Sep 18, 6:52*pm, " wrote: Please explain further........how is the correct landing procedure for a 2-33 going to result in a high energy landing in a Grob? IMHO....the correct landing procedure for a 2-33 (low energy, slow speed, nose high, tail low, etc) will result in a similar low energy landing in a Grob..........this would be a short runway landing, with little or no need for brakes...... Cookie So, when you are teaching landings to a student in a 2-33, do you first sit him in the front seat, level the wings, then hold the nose up until the tailwheel is on the ground and say "this is your landing attitude"? *Do you do that in a G-103? *Didn't think so. *Where that tailwheel is relative to the ground is the difference. *The landing angle of attack is probably about the same, but a student who learns to land on the main in a 2-33, nice and slow, but never touching the tailwheel, then who transfers that technique to the G-103, is a prime candidate for high energy landing problems. *It's not a killer problem - but it needs to be taught correctly! Kirk Correct landing attitude in a 2-33 is NOT tail all the way down..........this comes under the category of "too slow" 2-33 should be landed tail low, nose high, low energy, slow a practical, not slow as possible, and the skid kept off the ground as long as possible during ground roll. 2-33 has a unique shape in that the main wheel is mounted low on the bulbus belly, and the tail wheel is mounted high on the up swept fuselage tail. Grob should be landed nose high, tail low, as slow as practical (tail first is OK if subtle), nose wheel held off during ground taxi as long as possible So tell me agian how a proper low energy 2-33 landing relates to making a high energy Grob landing??? Cookie |
On Sep 18, 3:04*am, " wrote: A 2-33 should be landed just like any other "nose dragger glider" (G-103 II or ASK 21 etc) Really? *The correct landing procedure for a 2-33 (and Blanik) is a recipe for high energy landings in K-21s or G-103s (or worse case, a high sink rate bounced landing leading to the infamous "galloping Grob"!). *I hope you have a long runway and a big budget for brake pads! Some older gliders (and not all nose draggers) require a flown on landing - tail low, but on the main wheel - due to the tail wheel not being stressed for landing forces. *Examples are the 2-33 and Blanik (note, one is a nose dragger, one a tail dragger). *This is similar in concept to a wheel landing in a taildragger airplane - or a somewhat flat normal landing in a tricycle-geared airplane. *The trick is that once you have established the pitch attitude for touchdown, you can't continue to increase the angle of attack to slow down or you will touch the weak tail wheel/skid too early, so some judgement and skill is required. The later generation of trainers, whether nose draggers (k-21, g-103) Suggested reading: Derek Piggot "Beginning Gliding" Chapter 4 Cookie or tail draggers (DG-500/1000, Duo) are designed to land main and tail at the same time - minimum energy landings - the equivalent of a 3- point landing in a taildragger airplane. *This is also the way almost all current single seat gliders are designed to be landed, for obvious reasons - gliders are now heavier and land faster, and need to be landed at the slowest possible speed in an off-field landing. That is one of the reasons the 2-33 is a poor trainer for today's glider pilots (assuming they intend to move on to something more interesting than a 1-26). *If all training is done in a 2-33 (or Blanik, to be fair), then a careful checkout in a modern glider is essential to properly prepare the transitioning pilot for the landing characteristics of most modern gliders. Just to keep this discussion interesting, we can now argue whether a low energy tailwheel-first landing is OK or bad for a modern glider (assuming a reasonable sink rate at touchdown)... Kirk |
Just to keep this discussion interesting, we can now argue whether a low energy tailwheel-first landing is OK or bad for a modern glider (assuming a reasonable sink rate at touchdown)... Kirk Ok....I'll start.........on a tail dragger glider.... landing "ever so slightly" tail first touch down is a good thing..........if the approach is stable, and the sink rate is reasonable at touch down..........by touching the tail first, the main gear will come to the ground next, lowering the angle of attack on the wing, making it not likely for the glider to "bounce". Landing slightly tail first will also indicate that the glider is in the "low energy" state.....i.e. as slow as practical..(not as slow as possible, just as slow as practical) Landing slightly tail first should not put any undue stress on the airframe, tailwheel/skid etc, because the "weight" at the tail is very light..........the CG is far forward of the tail...........the glider will soon settle (softly) on the main gear, where the majority of the weight is taken by the robust structure / shock absorber etc there..... Note............this technique does not mean ....get close to the ground and jerk the stick back......this would cause the tail to slam into the ground with consideral impact......not good. Landing tail high in a taildragger glider is not a good thing........It indicates excess speed.......since the CG is behind the main gear, there is a tendancy of the tail to drop after main touch down, increasing the angle of attack, and possibly resulting in a "bounce". Yes, a "wheel type" landing can be done successfully in a taildragger glider, but in requires a slight stick forward pressure after touch down to prevent bouncing, (by lowering the angle of attack.....) and excessive speed, onger ground roll etc. Landing tail first in a nose dragger glider is not a good thing................. Landing tail first in a nose dragger will result in the main gear next touching down, but since the CG is in FRONT of this wheel, the tendancy is for the glider to continue to pitch forward (nose down) and contact the skid /nosewheel immediately..........as I mentioned earlier, the nose wheel or skid is not a "landing gear"...... IMHO......a nose dragger glider should be landed with "low energy" (slow airspeed), but not so slow that the tail touches first (too slow)......The nose skid/ wheel should be held off the ground during the ground taxi, as long as elevator authority allows......when the nose finally drops, the ground speed is very slow........ Same technique works for 2-33, 1-26, ASK-21, Grob 103...... This is far different from a "wheel type landing" and far different form "flying the glider on" Cookie |
On Sep 18, 8:23*pm, "
wrote: . Just to keep this discussion interesting, we can now argue whether a low energy tailwheel-first landing is OK or bad for a modern glider (assuming a reasonable sink rate at touchdown)... Kirk Ok....I'll start.........on a tail dragger glider.... landing *"ever so slightly" tail first touch down is a good thing..........if the approach is stable, and the sink rate is reasonable at touch down..........by touching the tail first, the main gear will come to the ground next, lowering the angle of attack on the wing, making it not likely for the glider to "bounce". Landing slightly tail first will also indicate that the glider is in the "low energy" state.....i.e. as slow as practical..(not as slow as possible, just as slow as practical) Landing slightly tail first should not put any undue stress on the airframe, tailwheel/skid etc, because the "weight" at the tail is very light..........the CG is far forward of the tail...........the glider will soon settle (softly) on the main gear, where the majority of the weight is taken by the robust structure / shock absorber etc there..... Note............this technique does not mean ....get close to the ground and jerk the stick back......this would cause the tail to slam into the ground with consideral impact......not good. Landing tail high in a taildragger glider is not a good thing........It indicates excess speed.......since the CG is behind the main gear, there is a tendancy of the tail to drop after main touch down, increasing the angle of attack, and possibly resulting in a *"bounce". Yes, a "wheel type" landing can be done successfully in a taildragger glider, but in requires a slight stick forward pressure after touch down to prevent bouncing, (by lowering the angle of attack.....) * and excessive speed, onger ground roll etc. Landing tail first in a nose dragger glider is not a good thing................. Landing tail first in a nose dragger will result in the main gear next touching down, but since the CG is in FRONT of this wheel, the tendancy is for the glider to continue to pitch forward (nose down) and contact the skid /nosewheel immediately..........as I mentioned earlier, the nose wheel or skid is not a "landing gear"...... IMHO......a nose dragger glider should be landed with "low energy" *(slow airspeed), but not so slow that the tail touches first (too slow)......The nose skid/ wheel should be held off the ground during the ground taxi, as long as elevator authority allows......when the nose finally drops, the ground speed is very slow........ Same technique works for 2-33, 1-26, *ASK-21, Grob 103...... This is far different from a "wheel type landing" and far different form "flying the glider on" Cookie Well said. I would differ a tiny bit in that a very slight tail low touchdown in a nose wheel glider isn't going to be a problem - but nothing more than a couple of inches low. |
Club Class Gliders | Sam Giltner[_1_] | Soaring | 4 | December 3rd 08 03:28 AM |
Basic Training Gliders | Derek Copeland | Soaring | 35 | December 26th 05 02:19 PM |
Basic Training Gliders | Justin Craig | Soaring | 0 | December 6th 05 10:07 PM |
Soaring club close to NYC, with high-performance gliders | City Dweller | Soaring | 9 | September 29th 05 11:55 AM |
