taller battery holder/clips for Ventus 2?
Old October 2nd 10, 03:15 PM posted to rec.aviation.soaring
Tim Taylor
Default taller battery holder/clips for Ventus 2?
On Oct 1, 5:05*pm, Frank wrote:
I'm considering the addition of a PowerFlarm and probably a
transponder (TTG21/22) to my Ventus 2bx, and am wondering if anyone
has modified the forward and/or aft battery restraints to accommodate
taller batteries. *The restraints in my ship are set up for the
typical 7-9AH SLA with dimensions 5.94"L x 2.56"W x 3.94"H. *The next
standard size up (literally) has the same length and width dimensions
but a height of 4.61". *There is plenty of room for the additional
3/4" or so, but current molded restraint clips won't work.
Does Schemp-Hirth make molded clips/restraints that will fit the
taller batteries, or am I on my own?
Regards,
Frank (TA)
Frank,
To answer your question directly. No factory replacenment that I know
of, but pretty easy to mod the factory box. Either cut and extend the
current tabs or put outside tabs and use a bungie doughnut.
Old October 3rd 10, 01:09 AM posted to rec.aviation.soaring
Todd
Larger batteries means a change in weight.
Do not forget to update the W&B.
You never know when you will get ramped by some FAA guy who will
notice the non-factory issued battery straps. It can be a very
slippery slope from there
Old October 3rd 10, 02:37 PM posted to rec.aviation.soaring
Andy[_1_]
Well that's an interesting observation. Do you update your basic
weight and balance data when you load water? Is your weight and
balance then invalid when you dump before landing?
My official weight and balance data does not include the batteries
since they are not required equipment. I consider batteries to be
optional/variable as are pilot mass and arm, water ballast mass and
arm, drinking water, and trim disks. All these are calculated on
page 2 of my W/B spreadsheet and do not appear in the weight and
balance data that was submitted for airworthiness inspection and
carried in the cockpit.
Page 2 of my weight and balance spread sheets allows selection of 1,
or 2, or zero batteries. If I change the battery type and mass I
would update the protected battery mass data on that sheet, but no FAA
inspected data would change.
I understand the situation may be different in countries ruled by
EASA.
Andy
Old October 9th 10, 04:57 AM posted to rec.aviation.soaring
Larry Goddard
"Frank" wrote in message
taller batteries. The restraints in my ship are set up for the
typical 7-9AH SLA with dimensions 5.94"L x 2.56"W x 3.94"H. The next
but a height of 4.61". There is plenty of room for the additional
Regards,
Frank (TA)
Hey Frank,
When I bought my 2bx I modified the battery holder to accommodate the
taller batteries. I actually fabbed up a strap just like the factory
one -- only taller. Made it out of a few layers of fiberglass and
re-assembled the unit just like it had been before. Now the taller
batteries slip in easily. Piece of cake.
Larry
L13A Type certificate holder Bruce Soaring 7 August 19th 10 07:01 PM
Wave Alert and record holder caught cheating? bumper Soaring 2 March 15th 09 09:23 AM
FA: Beech aircraft yoke chart holder (Garhawk) Karl Geng, N1DL Products 0 January 28th 05 08:07 PM
New Video Clips To Watch P.Naton Soaring 1 April 30th 04 11:26 PM
