On Oct 19, 5:04*pm, Bruno wrote:
On Oct 19, 7:44*am, wrote: On Oct 18, 2:08*pm, mattm wrote: On Oct 18, 2:03*pm, mattm wrote: On Oct 18, 1:03*pm, Bruno wrote: Hey everyone. We had a fun weekend up in Utah with many gliders up in the air enjoying the amazing fall colors and mountain scenery. *At the end of Friday's flight I decided to extend the flight and go play out in the weak wave lift in the valley northeast of the Logan airport. It was fun until it stopped being fun... ![]() For those of you who have not yet enjoyed an off-field landing, this video shows the final 6 minutes before the landout and then landing in the farmer's alfalfa field. It does a good job of showing the desire to try to stretch and make it home but in the end making the correct decision and landing safely short of the airport in a good field. Please note the field was chosen and looked over well before the gear came down. Other than a few green leaves that needed to be washed away from the bottom of the glider it was no worse for wear and I am thrilled to have the video to share with others of what the experience of landing in a field is like. Please watch the video in the highest resolution your computer and connection can handle. *It was shot in 1080HD and at that resolution you should be able to read all the numbers on the instruments. *The camera is a Canon HF20 with a fish eye lens which does a great job of distorting my face... ![]() adjustable arms. *I have a custom voltage reducer to take a full 12 volt 7 amp/hr battery and lower it to 8.4 volts so I get 7+ hours of battery life. The standard camera batteries only last a few hours max so this is necessary. http://www.youtube.com/watch?v=JBfNA5nhGQM&hd=1 Here is the igc file - it wasn't an impressive flight but you can see the trace at the end where the video shows the final moments.http://www.onlinecontest.org/olc-2.0....html?flightId... Thanks for watching and hope you enjoy. Bruno Vassel IV - B4http://www.youtube.com/user/bviv Excellent video. *Wish I had this available last month when I was giving a land out talk. *There's a few things that you should learn from the experience, though (shouldn't there always be?), as suggested by the likes of Tim Welles and Kai Gertsen: 1. turn off the radio when you're low -- it's just a distraction. Also, as Doug Jacobs likes to say, if you can do anything else while thermalling, you're not thinking about thermalling hard enough. *You can turn it back on after you land and tell everyone you're all right. 2. pick the field while you still have room to change your mind, and when you can see it properly. *You picked a field ahead of yourself a ways, and lucked out that it was a good field (it was into the sun, too, so it had to be hard to see it well). *I tried that last year and landed in chest-high barley (ouch). 3. pick the field at a more reasonable altitude. *300 feet (100m for the rest of the world) is more like the altitude you should be turning base to final. It's a little hard to see, but it seems you had good fields under you at 800 feet, and you had a good chance to look at them while you were scratching (which is a good exception to DJ's rule). There's a bunch of good presentations on off field landings (and lots of other great soaring stuff) at Doug Jacob's collection of stuff for the US Team camps:http://www.dragonnorth.com/djpresentations/index.html -- Matt Also, I don't want to sound negative in all this. *You did do stuff right, too -- checklist, take the safe option to go into the field (rather than stretching too far), and local field knowledge. *As you said on the radio, you were very close to glide slope, but you broke off while you still had time to maneuver. There's too many NTSB reports of pilots just hoping for that last 80 feet to materialize... -- Matt- Hide quoted text - - Show quoted text - Fun video of pleasant ending to a flight that almost made it- sorta. Bruno really was 500 to 600 low to make the field if one allows a decent safety margin. I get the impression that he might have gone for it if he was a couple hundred feet higher. The sink he sees when leaving his last "thermal" shows why this can be folly. The concern I have is giving the impression that this last few minutes is how we should fly such that others use this as an example. Everything is in his favor. Benign terrain, not much wind, not a lot of sink(or lift). I would bet a tighter circle with a bit more flap would have improved his escape possibilities. Looked like he was bouncing off bubbles without trying to tighten up in best lift. That said, without feeling the seat, he could have been doing it quite well. All that said, deciding to quit at 3 or 400 ft when it hasn't worked all the way down, is from my experience, a poor thing to do for a couple reasons. First surprises happen and options become very limited. Second, the positive outcome makes the pilot comfortable with doing it, leading to lower and lower quitting points. I've pointed this out to a number of my competition friends over the years. 2 proved me right within a year by crashing with low decision to land being a significant factor. BTW- another observation- How many times does he scan outside the circle? I know camera angle is deceiving. Enough preaching. Nice video Fun to watch Don't use as a training film. UH Thanks everyone for the comments so far - both positive and negative. Here are some more insights from the pilot's perspective... I agree with pretty much everything you all said. *Landouts are most often the result of poor decisions, poor flying and missed opportunities. *I am guilty of all three of these on this flight. This video is a perfect example of being low on final glide close to home and really wanting to make it. *When I am 80 miles out from home and down to 1,500 ft believe me I am circling over a field and have gear down by 600-800 ft and in a landing circuit, HOWEVER, when you are a few miles from home and on final glide the temptation to keep moving forward when you are over lots of good fields is incredibly strong. *Looking back now knowing that I did land out I would of course picked a field and landed as soon as I was dropping out of the thermal and into sink. *I wanted to share this video because it shows giving into temptation and continuing on to try to find something to get home when you are under glide with no margins and don't have a chance at making it. *Again, please give a little bit of credit as it was done over almost all landable fields. The fish eye lens really distorted my face and it was hard to see how much I was turning my head. *I had my final field picked out at around 600 ft which sounds low but I had another field picked out before I could have turned and flow back to. *Yes I didn't put the gear down until 300 ft but the field was picked out well before. *Please note I flew almost a downwind to the field as I was trying to get home that was NOT looking into the sun during the field selection so I was able to get a good view of it as some have suggested did not happen. *That said, had I spent 5 minutes circling over it looking before landing it would have been even safer. My poor attempts at the last save at 800 ft: No excuses - bad thermalling. *I was surprised when I looked back at the video how shallow I was thermalling. *Please take my word for it and from some of my friends who fly with me that I do like to thermal at 45% or even more normally. *I think that being so low I experienced an optical illusion with the bank angle compared to the horizon sight picture as well as just the desire not to get too steep so close to the ground. I just was not aware I was circling so shallow of a bank angle. *I agree that had I thermalled correctly there might have been a better chance at a save. *That's what I love about this sport - there's always room for improvement!!! * ![]() As for chatting on the radio: I was fat dumb and happy and had no idea I would be landing in a field anytime soon. *I really thought I would pull it out. *Again, looking back I should have spent the few brain cells I have on tightening up the circle and not chatting with my friend. ![]() I love having an HD video recorder in the the cockpit to share experiences like this. *When you do good you can share it and brag and when you make mistakes you can get good feedback and advice from the world. * ![]() incorporate them in my future flying...and future land outs. Thanks, Bruno Vassel IV - B4- Hide quoted text - - Show quoted text - Some of the thermal bubbles you ignored were quite good by UK standards. Perhaps you should come over here for a holiday next summer to find out how to use them? Derek C |
Thanks Bruno. Your videos are appreciated and the information one can
gather from both the video and comments are priceless. You handle the responses well whether positive or negative. Many pilots would not be so willing to place themselves out there. Keep 'em comin'. Craig |
Thanks for posting this, love the videos.
Just one question: What ever happend to this? Decision Altitudes Below 3000 agl Be in an area with landing possibilities 2000 agl Select several fields with potential 2000- 1500 agl Choose a field(s) / Search for thermals 1500- 1200 agl Position the upwind leg of chosen field 1000 agl Be established in the upwind leg 800- 600 agl Established on downwind leg On Oct 18, 11:03*am, Bruno wrote: Hey everyone. We had a fun weekend up in Utah with many gliders up in the air enjoying the amazing fall colors and mountain scenery. *At the end of Friday's flight I decided to extend the flight and go play out in the weak wave lift in the valley northeast of the Logan airport. It was fun until it stopped being fun... ![]() For those of you who have not yet enjoyed an off-field landing, this video shows the final 6 minutes before the landout and then landing in the farmer's alfalfa field. It does a good job of showing the desire to try to stretch and make it home but in the end making the correct decision and landing safely short of the airport in a good field. Please note the field was chosen and looked over well before the gear came down. Other than a few green leaves that needed to be washed away from the bottom of the glider it was no worse for wear and I am thrilled to have the video to share with others of what the experience of landing in a field is like. Please watch the video in the highest resolution your computer and connection can handle. *It was shot in 1080HD and at that resolution you should be able to read all the numbers on the instruments. *The camera is a Canon HF20 with a fish eye lens which does a great job of distorting my face... ![]() adjustable arms. *I have a custom voltage reducer to take a full 12 volt 7 amp/hr battery and lower it to 8.4 volts so I get 7+ hours of battery life. The standard camera batteries only last a few hours max so this is necessary. http://www.youtube.com/watch?v=JBfNA5nhGQM&hd=1 Here is the igc file - it wasn't an impressive flight but you can see the trace at the end where the video shows the final moments.http://www.onlinecontest.org/olc-2.0....html?flightId... Thanks for watching and hope you enjoy. Bruno Vassel IV - B4http://www.youtube.com/user/bviv |
On Oct 18, 3:29*pm, glider12321 wrote:
*Thanks for posting this, love the videos. Just one question: What ever happend to this? Decision Altitudes Below 3000 agl Be in an area with landing possibilities 2000 agl Select several fields with potential 2000- 1500 agl Choose a field(s) / Search for thermals 1500- 1200 agl Position the upwind leg of chosen field 1000 agl Be established in the upwind leg 800- 600 agl Established on downwind leg On Oct 18, 11:03*am, Bruno wrote: Please review the IGC file, you will see that Bruno did overfly the landing site a few minutes earlier and spent time thermalling over the field at 1000 feet. It is also noted in the video that he had checked the field. As for your numbers for 1500 feet and lower, those numbers depend on the pilot and skill level. A new pilot may use the numbers you propose, more experienced pilots may adjust those numbers down to their own comfort level and the type of terrain they are over. |
Tim Taylor wrote:
As for your numbers for 1500 feet and lower, those numbers depend on the pilot and skill level. And the landscape below you. There are regions where I never fly outside of the gliding range of a known outlanding field, and there are other regions where I just go and fly ahead until the wheel rolls. |
On Oct 18, 10:03*am, Bruno wrote:
Hey everyone. We had a fun weekend up in Utah with many gliders up in the air enjoying the amazing fall colors and mountain scenery. *At the end of Friday's flight I decided to extend the flight and go play out in the weak wave lift in the valley northeast of the Logan airport. It was fun until it stopped being fun... ![]() For those of you who have not yet enjoyed an off-field landing, this video shows the final 6 minutes before the landout and then landing in the farmer's alfalfa field. It does a good job of showing the desire to try to stretch and make it home but in the end making the correct decision and landing safely short of the airport in a good field. Please note the field was chosen and looked over well before the gear came down. Other than a few green leaves that needed to be washed away from the bottom of the glider it was no worse for wear and I am thrilled to have the video to share with others of what the experience of landing in a field is like. Please watch the video in the highest resolution your computer and connection can handle. *It was shot in 1080HD and at that resolution you should be able to read all the numbers on the instruments. *The camera is a Canon HF20 with a fish eye lens which does a great job of distorting my face... ![]() adjustable arms. *I have a custom voltage reducer to take a full 12 volt 7 amp/hr battery and lower it to 8.4 volts so I get 7+ hours of battery life. The standard camera batteries only last a few hours max so this is necessary. http://www.youtube.com/watch?v=JBfNA5nhGQM&hd=1 Here is the igc file - it wasn't an impressive flight but you can see the trace at the end where the video shows the final moments.http://www.onlinecontest.org/olc-2.0....html?flightId... Thanks for watching and hope you enjoy. Bruno Vassel IV - B4http://www.youtube.com/user/bviv Bruno What kind of camera were you using and how did you have it mounted and was it wired into the electrical system? Nice work. |
Nice video, thanks for sharing.
There always seems to be somebody who still has lift (and reminds you) just when you΄re about to land out..(4:58).. |
Short field landing Haiti | Gulfside | Instrument Flight Rules | 0 | February 24th 10 06:54 PM |
Short field landing Lake Providence LA (0M8) with ATC COMS - Video | A Lieberma[_2_] | Owning | 0 | July 21st 09 12:06 AM |
Off-Field landing | Casey Wilson | Piloting | 14 | January 13th 06 04:13 AM |
Soft-field landing in C172 | Magnus | Piloting | 24 | March 28th 04 04:58 PM |
Now THIS is a short field landing | John Harlow | Piloting | 8 | March 16th 04 10:42 PM |
