Flarm and stealth
Old October 29th 10, 04:40 PM posted to rec.aviation.soaring
Mark Dickson[_2_]
Default Flarm and stealth
In the UK Flarm has to be set to stealth mode for use in
competitions. This was introduced this year. Organisers may
make spot checks for compliance, but I'm not aware of any checks
being made. It didn't seem to cause any issues, apart from the
minor hassle of making the file change on the sd card.
At 11:57 29 October 2010, Paul Remde wrote:
I hope that the U.S. Contest Rules Committee finds through this
thread
that
forcing the use of Stealth or Competition modes is not being done
anywhere
in the world. I don't know whether or not that is true - but I
suspect it
is from what I have heard from my customers around the world.
Old October 29th 10, 04:53 PM posted to rec.aviation.soaring
cernauta
On Thu, 28 Oct 2010 12:53:32 -0700 (PDT), John Cochrane
As the US gets ready for the arrival of flarm, a big question on many
US pilot's minds is, what about stealth mode?
This year I flew competitions in Italy, Spain and Switzerland. There
was never any requirement to select any particular Flarm setting. Most
of the pilots had in standard mode.
My impression is that this is the way to go.
Where "team flying" is accepted, the pilots regularly use Flarm
indications to be aware of the position of the partner, reducing radio
chat.
Vertical speeds as indicated for the surrounding gliders is mostly
unreliable, but you can learn to make good use of it, somehow.
Some considerations:
Sometimes my Flarm could spot gilders inside clouds (maybe only a few
hundred feet above cloudbase, not permitted by the rules. In facts,
Flarm records might help identify the "bad guys.."
A minority of pilots may possibly develop habits that I consider
wrong: turning Flarm off (or disabling the gps antenna or whatever) to
hide their position upon finding the last thermal. Flying through
clouds as Flarm doesn't indicate any traffic inside.
I believe this is a side-effect that will desappear, given enough time
and experience.
It has taken more than 5 years for Flarm to be generally well accepted
by pilots and competition pilots. A minority are still negating the
usefulness of this device, or are against requiring Flarm as mandatory
equipment (for competition).
Old October 29th 10, 05:13 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
I usually look more at the change in relative vertical distance to a
specific target to determine if's worth to leave my thermal in favour of
somebody elses. This can be decided in 30-60 seconds.
Flarm in the US Steve Freeman Soaring 163 August 15th 10 12:12 AM
Chinese J-XX ''stealth fighter''. - File 1 of 1 - Chinese J-XX ''stealth fighter''.jpg (1/1) Troy[_2_] Aviation Photos 10 June 10th 08 01:41 PM
IGC FLARM DLL [email protected] Soaring 1 March 25th 08 11:27 AM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
FLARM John Galloway Soaring 9 November 27th 04 07:16 AM
