![]() yes my mistake: I realised as soon as I pressed send ... On Jan 18, 10:23*am, Darryl Ramm wrote: On Jan 17, 2:48*pm, pp2076 wrote: Incorrect I'm afraid See you does support raster maps, satellite or otherwise. The only issue is the calibration of the map On Nov 24 2010, 6:04*pm, Darryl Ramm wrote: On Nov 23, 10:33*pm, sisu1a wrote: those files if you proceed - which is what you should want. Did you actually run the install and see what happens? I've run it and wind up with the same install, which I'm pretty sure has some hiccups in the Mobile Wizard. Specifically, I'm trying to upload satellite maps with no luck. My airspace and waypoint files load no problem, but none of the sat maps are going through the Mobile Wizard. I can find the .cmr files inSeeYouunder ToolsRaster Maps, so they are making it intoSeeYouwhen I run the cmr.exe. I've also run pcsetup, which at least gives me access to re-register SeeYouonce I run it, but the new key I have wont unlock it, so I used my old key but have the same issues. I'm suspect of mySeeYouinstallation so was hoping to wipe clean and start fresh. I've tried Add/Remove programs, deleting/uninstalling it from C:\discProgram Files and then manually removing it from the registry, rebooted and searched every nook and cranny without finding a trace of it before proceeding. I run wcsetup and bam! all application data is still there... *ugggh, *I fought with it all day. It won, seeing as I'm too tired to wield the sawsall at the moment, but the PNA now seems happy at least. :| -Paul Paul I will try to break this to you gently..... :-) *SEEYOUMOBILE DOES NOT SUPPORT SATELLITE RASTER MAPS!! This could have been much easier if you had started by describing the original problem you were trying to solve! BTW the .cit and .cmr etc. data file installed inSeeYouusually live in folders under Program Files\Naviter\SeeYouand the ones "installed" intoSeeYouare listed in the registry. I'm not sure exactly what you were doing when things were getting confused. But hopefully everything is working or will after a clean install. Darryl- Hide quoted text - - Show quoted text - SeeYou does support raster maps vs. SeeYou Mobile which does not. If you had read the whole thread what product was being discussed was extremely clear. Darryl- Hide quoted text - - Show quoted text - |
SeeYou and OLC | Greg Arnold[_3_] | Soaring | 3 | April 27th 10 12:42 AM |
SeeYou Desktop Software - Runs on Vista 64-bit? | V1 | Soaring | 4 | December 18th 08 02:06 PM |
SeeYou and OLC | Doug Haluza | Soaring | 0 | April 20th 07 11:14 PM |
Where is SeeYou help? | [email protected] | Soaring | 1 | November 22nd 06 11:19 PM |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
