FCC License?
Old March 8th 21, 12:41 AM posted to rec.aviation.soaring
Dan Marotta
Default FCC License?
No. Used to, not any more unless you cross a border. If you plan any
international flights, check first.
Dan
5J
On 3/7/21 12:09 PM, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
I'm circling back on this old 2010 thread as I received a letter from the FCC asking me to renew the radio license specific specific to my N number (aka "Call Sign").
So here is a question that really needs a simple yes/no answer*.
"Do I need an FCC license for my glider (or for that matter for the myriad of GA power pilots flying their airplanes owned or rented) while flying WITHIN THE US so I can transmit across the entire aviation frequency range (118-137 MHz) and I can communicate with other pilots, small/large airports, ATC, etc, etc?"
I believe that the answer is "No". See the reference links below.
https://www.fcc.gov/commercial-radio...icense-program
https://www.aopa.org/travel/internat...r-certificates
https://sportysacademy.com/fcc/
https://cfiacademy.com/how-to-get-fc...rivate-pilots/
Let the conversation begin.
Thanks, John (OHM)
*PS - I'm *NOT* talking about a license for my gliderport, international flying, drug running, insurrection, or (for Bruno's benefit) flying in an air show.
Old December 31st 10, 03:48 AM posted to rec.aviation.soaring
2KA
You can get a license for a mobile ground station (in support of
glider operations) to transmit on a single frequency, i.e. 123.3. I
have one. You need a second license if you want to transmit on
123.5. Such mobile ground stations are not allowed, however, to
transmit on the CTAF.
Lynn Alley
"2KA"
Old December 31st 10, 02:04 PM posted to rec.aviation.soaring
Tony V
Crazy, isn't it? Hand held air band transceivers have been around for a
long time but it is only recently that they've become "dirt cheap" and
everybody and his brother has one. Case in point - in 1985 I paid almost
US$500 for an Icom A20. Today, I earn 3 times as much as I did in '85
and I got an A6 for well under US$300.
I suspect that the current communications regs are simply a reflection
of the earlier era - at least, I hope so.The reality is that if you
briefly and occasionally use a hand held outside of an aircraft, the
feds will not come after you - not that I recommend illegal use, mind
you. If you repeatedly mis-use a base station, chances are that they
will - http://www.fcc.gov/eb/Orders/2004/DA-04-3498A1.html ,
http://www.fcc.gov/eb/Orders/2009/DA-09-1258A1.html.
Tony, LS6-b "6N", W1DYS
Old January 1st 11, 12:45 AM posted to rec.aviation.soaring
John Gilbert[_2_]
I can show an example that makes this incorrect. Our club had a
license that allowed ground support stations to use either 123.3 or
123.5. Also, 87.323 says explicitly "Aviation support mobile stations
will be assigned 123.300 and 123.500 MHz". "And", not "or". Perhaps
you can pay a fee to get them to correct your license?? That's
crazy...
On Dec 31, 6:04*am, Tony V wrote:
glider operations) to transmit on a single frequency, i.e. 123.3. *I
have one. *You need a second license if you want to transmit on
123.5. *Such mobile ground stations are not allowed, however, to
will -http://www.fcc.gov/eb/Orders/2004/DA-04-3498A1.html,http://www.fcc.gov/eb/Orders/2009/DA-09-1258A1.html.
Old January 1st 11, 03:46 AM posted to rec.aviation.soaring
2KA
When I got my support license, I called to ask specifically about
using 123.5 as well. You are correct that such an option is
available, but it costs twice as much. You have to fill out two
license applications. But at the end you're right -- they give you a
single ground station ID and allow you to transmit on either.
Lynn
"2KA"
Getting an A&P license [email protected] Home Built 5 August 26th 06 03:06 PM
Accelerated license course? Deane Soaring 8 June 1st 06 04:14 AM
Got my new license Brien K. Meehan Piloting 3 November 18th 04 02:27 PM
Should the USA have a soaring license, not a glider license? Mark James Boyd Soaring 0 August 6th 04 07:16 PM
Cheap License Brad Mallard Rotorcraft 6 November 17th 03 02:16 PM
