On Jan 2, 2:49*am, Doug Greenwell wrote:
At 03:11 02 January 2011, wrote: On Jan 1, 10:34=A0am, Doug Greenwell *wrote: At 15:09 01 January 2011, Derek C wrote: On Jan 1, 11:15=3DA0am, Doug Greenwell =A0wrote: At 20:23 31 December 2010, bildan wrote: On Dec 31, 1:06=3D3DA0pm, Todd =3DA0wrote: I too agree with the real or perceived tow handling characteristics. Looking at things =3D3DA0from and aerodynamics standpoint (and I am abou=3D t as far from and aerodynamicist as you can get) it should seem that part of the empirical data would suggest an experiment where you fly a glider equipped with and Angel of Attack meter at your typical tow speeds and record the AoA at various speeds. =3D3DA0Then fly that glider on tow at those same speeds and record the results. Done that - and as nearly as I can see, there's no difference in AoA. I've flown some pretty heavy high performance gliders behind some pretty bad tow pilots - one of them stalled the tug with me on tow. If I'm careful not to over-control the ailerons, there's no problem at all. Heavily ballasted gliders respond sluggishly in roll just due to the extra roll inertia. =3DA0A pilot trying to hold a precise position behind a tug needs and expects crisp aileron response. =3DA0When he doesn't get it, he increases the amount and frequency of aileron with a corresponding increase in adverse yaw. =3DA0If he's less than equally crisp with rudder to oppose the adverse yaw, it gets wobbly. Where did you mount the AoA meter? It's not the angle of attack that's the problem, but the change in local incidence along the wing. =3DA0The overall lift may not change by very much when near to the tug wake, but its distribution along the wing does, with increased lift at the tips and reduced lift at the root - putting the aileron region close to the stall and hence reducing control effectiveness. I agree that increased roll inertia due to ballast is a factor, but since the same factor applies to maintaining bank angle in a thermalling turn I don't see how it can account for a significant difference in handling between tow and thermalling?- Hide quoted text - - Show quoted text - What started the debate at Lasham was using a Rotax engined Falke as a glider tug. This towed best at about 50 to 55 knots (c.f. 60+ knots with a normal tug), but K13s with a stalling speed of 36 knots felt very unhappy behind it, especially two up. In a conventional powered aircraft you pull the nose up (to increase the angle of attack and produce more lift) and increase power to climb, the extra power being used to prevent the aircraft from slowing down. I don't see why gliders should behave any differently, except that the power is coming from an external source. As you try not to tow in the wake and downwash from the tug, I can't see that this is particularly significant, Derek C In a steady climb in any light aircraft the climb angles are so low ( 10deg) that the lift remains pretty well equal to weight. =A0For example = a 10deg climb angle at 60 kts corresponds to an impressive climb rate of 10.5kts - but that would only give Lift =3D Weight/cos(10deg) =3D 1.02 x Weight. =A0You don't need to increase lift to climb - you increase thrust to overcome the aft component of the weight, and the stick comes back to maintain speed ... at constant speed the increased power input comes out as increasing potential energy =3D increasing height. I think a lot of people confuse the actions needed to initiate a climb with what is actually happening in a steady climb. =A0 On your second point, if you are on tow anywhere sensible behind a tug yo= u are in its wake and are being affected by the wing downwash. =A0Wake is n= ot really a good word, since it seems to get confused with the much more localised (and turbulent) propwash. A (very) crude way of visualising the affected wake area is to imagine a cylinder with a diameter equal to the tug wing span extending back from the tug - that's the downwash region, and then in addition there's an upwash region extending perhaps another half-span out either side.- Hide = quoted text - - Show quoted text - "aft component of weight??" Not that this adds anything to the discussion, but.....weight acts in a "downward" direction toward the center of the earth. In a climb, on tow, the "aft" forces are drag (mostly) and a small bit of lift. Anyway, interesting topic.......has been beat to death at our local field...EVERY pilot seems to have had it happen, in all different kinds of gliders......many explainations....not one all-encompassing explaination yet. Cookie it depends on your reference frame - lift and drag are perpendicular to the direction of motion (relative to the air), which is inclined upwards - so if you take 'aft' as relative to the glider flight path rather than the earth, then there is an aft component of weight.- Hide quoted text - - Show quoted text - Lift is perpendicular.......drag is parallel........ |
another poor man's car engine conversion | jan olieslagers[_2_] | Home Built | 19 | February 22nd 09 03:49 PM |
Poor readability | Kees Mies | Owning | 2 | August 14th 04 04:22 AM |
Poor Guy | Bob Chilcoat | Owning | 6 | July 17th 04 06:45 PM |
I'm grateful for poor people who are willing to murder & die | Krztalizer | Military Aviation | 0 | April 20th 04 11:11 PM |
Concorde in FS2002: No lateral views | A. Bomanns | Simulators | 3 | July 19th 03 11:33 AM |
