Solar charging question
Old January 17th 11, 09:29 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Solar charging question
On 1/17/2011 12:09 PM, Morgans wrote:
"Ed" wrote in message
Thank you, Eric, this is a good start knowing that I have to upgrade a
bit.
How about a different route. How about adding a small 20 amp alternator
to the engine to charge the battery? You charge it on the way down with
a short engine run, or on the ground, assuming you left enough in the
battery to start the engine.
I don't know the Grob 103 details, but most self-launchers do have an
alternator. If not, finding a way to mount an alternator in what is
usually a very cramped location, and making it sturdy enough to keep the
two-stroke engine from vibrating it to pieces, and integrating it into
the electrical system would be a major project.
The recharge current is limited by the battery size, and the 28 Ah
battery means a limit around 5 or 6 amps. Since the current drops off as
the battery charges, replacing 6 Ah means an engine run of at least 1.5
hours. Nobody wants to put an hour and a half on their engine to top off
a battery - the noise alone is enough to seek other solutions!
email me)
Old January 18th 11, 02:17 AM posted to rec.aviation.soaring
Morgans[_2_]
two-stroke engine from vibrating it to pieces, and integrating it into the
The recharge current is limited by the battery size, and the 28 Ah battery
means a limit around 5 or 6 amps. Since the current drops off as the
battery charges, replacing 6 Ah means an engine run of at least 1.5 hours.
Nobody wants to put an hour and a half on their engine to top off a
I see your points, but still am not sure that some increased charging system
could not provide a good answer.
Most engines like that have a flywheel magnet and stator system, and are
pretty anemic in the amount of current they put out. One of the small
alternators from something like a small tractor could be mounted, and a
larger battery installed, probably a wet cell, or other type that could
handle more charging current. If not able to fill the larger battery in a
20 minute run to altitude, it would be darn close, and the larger capacity
would have more than enough to run your electronics all day, even at only
1/2 or 2/3rds capacity. I agree about not running an engine a long time,
just to charge, but if you ran the battery down one day on a marathon
flight, a little run would keep your electrons zinging around the
microcircuits!
Jim in NC
Old January 18th 11, 09:17 AM posted to rec.aviation.soaring
Bruce Hoult
pretty anemic in the amount of current they put out. *One of the small
After suffering for years with motorcycles that could barely light a
decent headlight, it was fantastic to get my current bike, a 1995 BMW
R1100.
It has an 800W alternator. That's a lot of amps at 12V!
I don't know how many of those amps it can put into the battery. It
has power outlets for both rider and passenger intended to plug
electrically heated clothing in to for winter riding. (not necessary
in NZ, so I've never investigated properly)
Old January 18th 11, 04:35 PM posted to rec.aviation.soaring
Darryl Ramm
handle more charging current. *If not able to fill the larger battery in a
1/2 or 2/3rds capacity. *I agree about not running an engine a long time,
microcircuits!
Jim in NC
Last time I checked we were talking about an aircraft and associated
weight and balance, saftey and regulatory concerns. Adding a larger
generator and a flooded battery is not something more practical people
would even consider to solve a problem that can practically be solved
with a larger solar panel or a DC-DC charger.
Darryl
Battery charging C172 rowntree Owning 16 January 20th 08 08:15 PM
Basic battery charging question [email protected] Soaring 28 April 10th 06 03:12 PM
Charging? PaulaJay1 Owning 25 February 2nd 05 06:03 AM
Charging Question (Electrical - Not Credit) Michael Bremer Owning 15 January 20th 05 02:00 AM
Cessna 210 charging problem John Clonts Owning 9 July 14th 04 03:08 PM
