Future military fighters and guns - yes or no ?
Old February 16th 04, 08:04 AM
Dweezil Dwarftosser
George wrote:
The US is looking at putting a 100kW laser on the JSF. Does anyone
think this could supplant the gun? It is precise, effective (when they
get its power up), aimable (including well off boresight), has a
longer range than a gun, doesn't require ammo, and if you aim it up,
you don't have to worry about shells splashing at the wrong place.
Cool... if (and only if):
- the laser has the same optical path as the video-
aiming device. (May be slaved to radar aim point,
but it is essential the trigger-puller be able to
SEE the effectiveness of the aim/shot).
- all battles are over a sunny, clear desert.
- there is no smoke from previous targets, ground or air.
- There is no "Interlocks out" switch in the cockpit, so
the pilot cannot short-cuircuit the mandatory charge time.
(prevents him from firing "blanks"...)
Old February 16th 04, 09:40 PM
Ian
"Dweezil Dwarftosser" wrote in message
From what I've read, I'd say it is viable to do this, but questions have
been asked about the "recharge" time for the laser?
Old February 16th 04, 11:31 PM
steve gallacci
While lasers could be cool, I have doubts about effectiveness,
especially once they become operational, as ablatives and other
protections/countermeasures could reduce them to little more than
over-built flashlights.
I suspect a lot of talk about no need for guns/BVR missile environments
assumes a US style total air superiority situation with everything
working just like the advertisements claim. And those aircraft tasked
for that kind of air superiority role may well not need guns. However,
for everyone else in less than ideal situations, having a gun option
would seem prudent, especially for multi-role machines that end up being
in inventory for a few decades longer than expected, fighting wars in
places/circumstances that their designers never dreamed of.
Old February 16th 04, 11:45 PM
Bjørnar Bolsøy
steve gallacci wrote in
questions have been asked about the "recharge" time for the
laser?
than over-built flashlights.
What about the heat generated by it? A 100KW laser means many
times that in generated electrical power. Where do you put it?
Regards...
Old February 17th 04, 08:16 PM
George
"Bjørnar Bolsøy" wrote in message ...
laser?
Regards...
So far the way I've seen is to use water-cooling internally which
radiates through air cooled fins, using ram-air from the slipstream to
insure rapid air movement. How well this works, I don't know. For the
electrical power and placing, Lockheed has suggested using the STOVL
model and taking out the lift fan, using the large amount of shaft
horsepower to run a generator for power and the space for the laser
and generator.
Old February 17th 04, 01:16 AM
Paul J. Adam
In message , Tony
Williams writes
This does not mean
that guns are useless for air-to-air work. They have a particular
value in modern 'policing' applications, as they enable warning shots
to be fired in front of suspect aircraft.
However, you have to load tracer for that: which reduces effectiveness
in combat.
They also provide an
economical way of engaging low-value targets such as unmanned
reconnaissance drones, transport and liaison aircraft, or
drug-smugglers.
"Economical" is extremely dependent on assumptions: while a burst of
cannon shells is cheaper than a missile, keeping your entire fighter
force trained and ready to be proficient in gun use is not cost-free.
In a 'hot' war they still have certain advantages in
close-quarter fighting, for example in 'picking off' an enemy
attacking a wingman, who may be too close for a safe missile shot.
Last time this occurred?
The
ability of modern fighters to adopt extreme attitudes, pointing well
away from the line of flight, significantly assists gun aiming in
dogfights.
Only if the extreme attitude can be sustained and controlled long enough
for a gun snapshot: meanwhile a less extreme diversion wastes less
energy yet still allows an off-boresight missile shot.
Cannon projectiles have a shorter flight time than a
missile, a significant advantage in a dogfight.
Can't miss fast enough to win: and it takes significantly longer to get
into guns parameters.
Finally, the gun provides a last-ditch capability if the missiles run
out,
If an infantryman runs out of ammunition, should he continue to close
with the enemy in hopes of getting into bayonet, buttstock, boots and
teeth range?
When you find yourself at a major disadvantage, it's rarely wise to
press on through the killing zone.
or are defeated by advanced countermeasures or simply by
circumstances.
The trouble is that gunsights require significant sensor input:
particularly if the aircraft is flying extreme manoeuvres to generate
snapshots. This means that an enemy able to deceive radar-guided
missiles is also generating miss distance for cannon rounds.
The 1991 Gulf War revealed the deficiencies of modern
IR-homing missiles when faced with trying to pick up a low-flying
target against a hot desert background (helicopters being in any case
difficult for IR seekers to lock on to from above). USAF A-10
aircraft achieved two helicopter kills with the GAU-8/A (using 275 and
550 rounds respectively) in one case when the IR missiles failed to
lock on.
550 rounds is more than many fighters carry, even when using less potent
Gatling guns. Is the problem "only guns can kill low-flying
helicopters", or "there's a need to improve capability against
low-flying helicopters"?
Furthermore, the performance of even the best missiles cannot
always be guaranteed, for various reasons. In Kosovo, a US fighter
engaging a Serbian plane needed to fire three AMRAAMs to bring it
down.
How many cannon rounds were fired, out of interest?
In other engagements in the late 1990s, USAF and USN fighters
fired a total of seven Sparrows, AMRAAMs, and Phoenix missiles against
Iraqi MiG-25s without scoring a single hit (although the Phoenix shots
were taken at extreme range).
Again, how many gun shots were fired?
The Iraqi aircraft were evading at the edges of the missile envelope:
what improvements to the US aircraft's gunnery systems would have
changed the outcome?
Whatever the reason, this results in missiles being used
up at a high rate, making it more likely that they will run out during
a sortie. A cannon will typically carry enough ammunition for several
engagements, usefully increasing combat persistence at a minimal cost
in weight and performance.
Trouble is, just because _you_ are out of missiles doesn't mean the
enemy will chivalrously cease fi and it's much easier for the enemy
to get you into missile parameters, than for you to lure an enemy into a
guns shot. (Especially when you're having to break off your approaches
to evade enemy AAMs)
One curious aspect to the use of AAMs in combat is that of the
approximately 1,000 kills achieved between 1958 and 1991, only a
handful were scored beyond visual range, which does raise questions
about the significance of the very long ranges of which some missiles
are capable.
Restrictive ROE accounts for a great deal (Vietnam): limited conflict
area (Middle East); and weapon availability (Falklands).
Also, define "visual range". The definition usually cited is "within
five miles", which is well outside guns range and only useful for
head-on Sidewinder shots: "long-range" missiles may struggle to close
five miles of seperation in a low-altitude, co-speed tailchase.
There is a continual battle between missile sensor and countermeasure
technology.
And the gun is not immune, since it requires sensor input for any but
the crudest shot.
In the future, stealth technology applied to aircraft may
considerably shorten target acquisition and combat ranges, putting
into question the worth of modern BVR (beyond visual range) AAMs. The
possible future use of anti-radar missile guidance as a way of
overcoming stealth characteristics may force fighters to make minimal
use of their own radars, further reducing acquisition and combat
distances.
And making guns use equally problematic, as snapshots become much more
demanding and gyro gunsights demand tracking shots.
Of course, modern guns are usually aimed by the plane's radar which
could also be jammed (although less easily than the much smaller and
less powerful missile seekers) but laser rangefinders could make an
acceptable alternative in providing fire control data.
Only for range: not for angular rate.
If planes
eventually become 'laser-proof' as well, the possibility presumably
exists of linking variable magnification optical sights to a computer
which would be able to analyse the image, identify the plane,
calculate its distance, speed and heading and provide gunsight aiming
information accordingly, all without emitting any signals.
If you can do all this and compute a gunnery solution, why can you not
fly a much larger guided warhead into the target from greater range than
a cannon will allow?
However, not all conflicts involve front-line opposition; in fact,
armed forces are now commonly engaged on police work, frequently
dealing with guerrilla forces. In these circumstances, rockets and
missiles may represent an inappropriate degree of destruction, with a
high risk of collateral damage. The RAF was embarrassed during
operations against insurgents in Sierra Leone in 2000 to find that
they had no suitable weapon for their gunless Harrier GR.7 aircraft to
attack small groups of rebels operating close to innocent civilians.
Given the lack of air opposition, why not use Sea Harriers with their
reliable, proven 30mm ADENs for the role? It seems more is being made of
the story than might actually exist.
Another advantage of using cannon was demonstrated in the invasion of
Afghanistan in 2002. During an intense infantry battle at Takur Ghar
in late May, in which US forces were ambushed and in considerable
danger, air support was called for. The AC-130 was not permitted to
intervene in daylight due to its vulnerability, so USAF fighters were
sent to help. For a part of the battle the Afghan combatants were too
close to the Americans for rockets or bombs to be used, so the
fighters – F-16s and even F-15s – went in strafing with their 20 mm
cannon, as did the Navy's F-14s and F/A-18s on other occasions.
And, curiously, the ground troops reported how the enemy refused to be
suppressed, neutralised or destroyed by those strafing passes: though
PGMs dropped carefully in "danger close" proved effective.
Even
RAF Tornadoes were reported to have carried out gun strafing runs on
at least one occasion. It may logically be argued that it is foolish
to risk an extremely expensive aircraft, with its expensively trained
pilot, to being lost due to very low-tech ground fire, but sometimes
the risk needs to be taken to save friendly lives."
I'm automatically wary of this variation of "If it saves the life of
even one small child..."
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old February 17th 04, 12:28 PM
Tony Williams
"Paul J. Adam" wrote in message ...
In message , Tony
Williams writes
drug-smugglers.
No it isn't - but UAVs/UCAVs are likely to proliferate rapidly, and
dealing with them is likely to shift up the scale of importance.
lock on.
The A-10 was not equipped (nor are the pilots trained, AFAIK) for
air-to-air gunnery.
down.
Irrelevant - the point I am making is that missiles run out very fast.
The Iranian F-14s made good use of their Phoenix missiles, and
Sparrows, but still ended up in gunfights on occasions and even scored
kills with the gun. Nice theories about how engagements ought to go
tend to break down in real life.
If planes
Because an aircraft has far more space for sensors and computing
capacity than a missile does.
The Sea Harriers have, what - two or three more years? Then what? Do
guns suddenly stop being useful for such purposes?
Tony Williams
Military gun and ammunition website: http://www.quarry.nildram.co.uk
Discussion forum at: http://forums.delphiforums.com/autogun/messages/
Old February 17th 04, 06:25 PM
Paul J. Adam
In message , Tony
Williams writes
I'm still unconvinced that a gun (in its current incarnation) is the
best option, if that's a key driver.
air-to-air gunnery.
So? Helicopters are closer to air-to-ground strafing than air-to-air,
looking at the velocity and altitude differentials.
A few examples where this has befallen Western pilots would be handy. It
was a problem in Vietnam for the USAF, for example, where they were
plagued by poor reliability of the weapons and by doctrinal guidance to
volley every selected weapon at a target (so a F-4 Phantom effectively
had one Sidewinder shot and one Sparrow shot); the USN used different
doctrine based on single firings and got much better results.
A strong example for your case should be the Falklands, where the SHars
only had two AIM-9Ls apiece, yet it's an interesting commentary on
relative envelopes that there were very few (three IIRC) guns kills, one
a C-130 finished off with gunfire after Sidewinder hits and one Pucara:
though on several occasions the SHars emptied their guns at Argentine
aircraft without results (LCdrs Mike Blissett and 'Fred' Frederiksen,
and Lt. Clive Morell, all had this experience on the 21st May, for
instance: Sharkey Ward recalls firing on and missing a Turbo-Mentor, as
well as three SHars taking five firing passes to down a single Pucara;
Flight Lieutenant Dave Morgan scored two kills with two Sidewinders on
8th June, and shot his guns dry to no effect before his wingman got a
third kill with another Sidewinder...)
Having the guns along when the missiles were exhausted was no guarantee
of being able to get into range, let alone score disabling damage: with
hindsight, trading the gun pods for more fuel and twin-rail Sidewinder
launchers (giving four rather than two shots) would have been much more
effective.
kills with the gun.
The Iranians also used human wave attacks against prepared defensive
positions, using unarmed schoolboys carrying plastic "keys to heaven" in
the first wave (they were expendable, available, and revealed the
locations of minefields and concealed bunkers for the armed fighters
following). I would be somewhat wary of taking a cue from Iranian
tactics without much more detail of the encounters involved.
True: like the notion that any gunless fighter is doomed
But the gun is still a fixed installation and you have to point it at
where the target will be one time-of-flight after firing: and you have
to fly through the enemy's weapons envelope(s) to do so.
They were available, why weren't they used? Did nobody consider the
chances of a 'danger close'?
Then what? Do
They were available then - the story seems to have more agenda behind it
than it would like to admit.
W S Churchill
Old February 17th 04, 11:03 PM
Guy Alcala
"Paul J. Adam" wrote:
In message , Tony
Williams writes
Now here, Tony raises an interesting point. Talking with a serving IAF pilot
some years back, he mentioned that all their tactical a/c have their guns
loaded on every flight, including training, just so they'll have something to
fire if they get diverted to an interception. He said that an IAF Brigadier
General had shot down a foreign recon drone while on a training flight in his
(IIRR) F-15 . Of course, lasers or cheap missiles may do the job as well, and
high-performance UAVs are never going to be _that_ cheap.
snip
effective.
snip
Yup. Of course, the lack of IR decoys in most of the Argentine a/c also played
a part, but we're now in the age of IIR seekers, and decoying _them_ is going
to be very difficult if not impossible. They may require damage or destruction
to make them miss. And if the SHARs had had RH missiles and PD radar (and
AEW), then chances are they would have shot down many of the Argentine aircraft
long before they'd even have closed to visual range, even if they were using
older generation missiles.
Guy
Best dogfight gun? Bjørnar Bolsøy Military Aviation 317 January 24th 04 06:24 PM
Remote controled weapons in WWII Charles Gray Military Aviation 12 January 21st 04 05:07 AM
Why did Britain win the BoB? Grantland Military Aviation 79 October 15th 03 03:34 PM
P-47/51 deflection shots into the belly of the German tanks,reality ArtKramr Military Aviation 131 September 7th 03 09:02 PM
