![]() "Jerry Springer" wrote in message ink.net... Jim you don't find the 1500fpm number suspect? Once again lets see the horsepower and weight and prop comparisons. Jerry I really don't want to give the impression that I believe all of the numbers are accurate. I imagine that a complete and scientific POH may be lacking, but although the numbers may be "slightly enhanced", I believe the owner believes them. The 1500 FPM was probably on an optimum day, but it could also be because of the PSRU, that the prop is bigger, and being turned with more torque, allowing a bit more pitch. It is also not too hard to believe that it has better efficiency than the Lycosarus. I agree. I would love to see a full accounting given. It sounds as though the people have done some good work, and are more than some of BOb's wanna bees. A big V-8 can work. I site Orenda, or however it is spelled. After all, it is just 2/3rds of a V-12, and we all know they can work. -- Jim in NC |
![]() "Morgans" wrote: The 1500 FPM was probably on an optimum day, but it could also be because of the PSRU, that the prop is bigger, and being turned with more torque, allowing a bit more pitch. Some folks wanna bee-lieve anything. It would take a thermal to hoist this boat anchor at 1500 fpm. Horsepower is horsepower is horsepower.... and so far, we don't have a clue what it is, do we? Geejus H. Chryst, fella. It is also not too hard to believe that it has better efficiency than the Lycosarus. Ah ****, doofus. Do some homework... or are teachers exempt. Wake up and smell... the *FRANKLIN*. Barnyard BOb -- if it sound to good to be true, it is. |
On Tue, 04 Nov 2003 16:52:42 -0600, Bob U. wrote:
"Morgans" wrote: The 1500 FPM was probably on an optimum day, but it could also be because of the PSRU, that the prop is bigger, and being turned with more torque, allowing a bit more pitch. Some folks wanna bee-lieve anything. It would take a thermal to hoist this boat anchor at 1500 fpm. Horsepower is horsepower is horsepower.... and so far, we don't have a clue what it is, do we? Geejus H. Chryst, fella. It is also not too hard to believe that it has better efficiency than the Lycosarus. Ah ****, doofus. Do some homework... or are teachers exempt. Wake up and smell... the *FRANKLIN*. Read, SubUrban Bob The plane in question has flown with both Lyco and Franklin power in it's lifetime, from what has been stated here. Now - as for efficiency. If the stock aircraft engine (any make) has basically fixed timing (an impulse magneto to retard for starting) it is optimized for only one combination of throttle position, mixture, RPM, and load. That particular combination MAY never be realized. The computer controlled system on even the lowliest of current production automobiles optimizes the fuel mixture and ignition timing for virtually all possible combinations of load, throttle opening, RPM, as well as temperature and atmospheric conditions. I know my 3.8 injected and electronically controlled 6 in my current vehicle gives significantly better than a 30% improvement in mileage over the 3.8 liter carbureted engine with mechanical timing advance on my '75 Pacer did - and the van has a larger frontal area, weighs several hundredweight more, and has air conditioning and an automatic transmission. It is also capable of significantly higher cruising speed, and accelerates MUCH more quickly - and the 232 inch AMC was much more sophisticated in the control department than an old Franklin or Lycosaur. To go back just a bit farther, the 232 overhead valve engine in the Pacer gave better mileage and performance than the low compression L Head 231 in a '49 Dodge, of about the same weight. Higher compression ratio, advanced combustion chamber design, optimized fuel mixtures, and variable, closely controlled ignition timing make a HUGE difference in engine efficiency and power output. I know, Bob, you are going to say the optimized fuel mixtures and closely controlled ignition timing are thrown out the window because they are not running closed loop, having removed the O2 sensors. Well, 14.7:1, or whatever the O2 sensor forces the engine to run at is NOT the optimum for either power output or efficiency. It is simply the mixture required for the catalytic converter to do it's job. By removing the cat, and allowing the engine to run with a pre-plotted mixture and timing map it can actually be MORE efficient, and more powerful, than when constrained by the cat and O2 sensor. The engine that was installed in the Republic SeaBee from the factory was about equivalent, in technology and efficiency, with a 1932 Ford - or even closer to a Model A. The 60 hp Ford Flattie was about 209 cu inches displacement. It ran 6.6:1 compression ratio. That is basically a 3.5 liter engine. In 1976, Ford's 200 cu inch six, with 8.7:1 compression put out 84 hp. A 3 liter engine today can put out 200 HP - and at the same RPM as the old Flattie still put out in excess of 160 ft lbs, at 3200 RPM, roughly 100 HP. The specific fuel consumption of the new engine is significantly lower than the old engine,while producing almost double the horsepower. In other words, SubUrban Bob, You are blowing smoke. Barnyard BOb -- if it sound to good to be true, it is. |
On 04 Nov 2003 05:48 PM, clare @ snyder.on .ca posted the following:
I know my 3.8 injected and electronically controlled 6 in my current vehicle gives significantly better than a 30% improvement in mileage over the 3.8 liter carbureted engine with mechanical timing advance on my '75 Pacer did - and the van has a larger frontal area, weighs several hundredweight more, and has air conditioning and an automatic transmission. It is also capable of significantly higher cruising speed, and accelerates MUCH more quickly - and the 232 inch AMC was much more sophisticated in the control department than an old Franklin or Lycosaur. My 1973 Chevrolet pickup truck with a carbureted 350 V-8 and automatic transmission gets between 10 and 11 mpg, city, highway, loaded, unloaded, uphill, downhill, tailwind, headwind, whatever. A newer Chevrolet with the same engine and fuel injection can be expected to get around 20 mpg on the highway. Part of that is due to the better transmissions that are used today, but mostly due to the efficiency of EFI. In addition, modern fuel injection offers advantages in cold starting (my '94 S-10 would start instantly at 40 below zero with no preheat, though it was normally kept plugged in when it was below zero), and operation at extreme angles which would give a float carburetor fits (more of an issue offroading in my Jeep). I LOVE fuel injection. But I am not ready to fly behind an automotive based EFI system, not yet anyway. A little over a year ago, my less than 2 year old Jeep (which uses a descendant of your 232) coasted to a halt at mile 87 on the Parks Highway between Fairbanks and Anchorage. The cause was a seizure of the mechanical drive which operates the camshaft position sensor, a hall effect module which supplies engine speed information to the computer for the fuel injection. This single point failure instantly shut down the fuel injection system and required around a 150 mile tow to Anchorage, which luckily was covered under the vehicle's warranty ( particularly when you consider that I had been in the middle of Yukon, Canada two days previously). I would consider using an EFI with redundant sensors for required computer inputs, but until such a beast is available, I'll have to pass. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
![]() I know my 3.8 injected and electronically controlled 6 in my current vehicle gives significantly better than a 30% improvement in mileage over the 3.8 liter carbureted engine with mechanical timing advance on my '75 Pacer did - ++++++++++++++++++++++++++++++++++ The 30% improvement disappears when operating hour after hour at a 75% to 100% power setting to duplicate aircraft performance requirements. Run both on the German Autobahn wide open until destruction and get back with the data that may hint of some practical use and application. Pacer??? A bad joke perpetrated on clueless consumers... if it's not a classic and revered Lycoming powered Piper aircraft. Barnyard BOb -- unfair to compare apples and oranges |
Just thought I'd throw out a point for contention. (As if any more are
needed) The O2 sensor as used in a NB Speed Density system is of little value at the power levels used in aircraft. My understanding is that the NB O2 sensor is mainly an emissions device. 14.7 AFR is neither best power nor is it best economy. What it is is best emissions when combined with the proper cat. All NB Speed Density systems that I am aware of ignore the O2 sensor at full power. Removing the NBO2 sensor from the engines made perfect sense when taking the operating environment into account. In this situation (as in the car when at full power) the computer uses preprogrammed lookup tables based on operating and environmental considerations. A properly tuned engine can and will make full power without an NB O2 sensor. Nothing whatsoever is given up except emissions, but since no cat... The NB O2 sensor has nothing to do with making max power. So why include it on an aircraft? The NB O2 sensor has nothing to do with max economy. So why include it on an aircraft? A WB O2 sensor is a different story. And there are other compromises at play that have not been addressed here. Regards Ken Bauman |
"Morgans" wrote in message
... It is also not too hard to believe that it has better efficiency than the Lycosarus. Mak thet "Lycosaurus". I site Orenda, or however it is spelled. Its spelt "I cite Orenda". ;-) |
human powered flight | patrick timony | Home Built | 10 | September 16th 03 03:38 AM |
Illusive elastic powered Ornithopter | Mike Hindle | Home Built | 6 | September 15th 03 03:32 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Powered Parachute Plans | MJC | Home Built | 4 | July 15th 03 07:29 PM |
Powered Parachute Plans- correction | Cy Galley | Home Built | 0 | July 11th 03 03:43 AM |
