RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards)
Old November 5th 03, 07:04 PM
Jim Weir
You can stop playing with 10.7 as a source of the problem. I cannot recall an
aircraft navcom using 10.7 as the IF frequency.
"Paul Sengupta"
-Bear in mind that the radios involved may have different front
-ends. It might just be a coincidence that your handheld and
-panel radios are affected and nothing to do with the airframe.
-How about 127.00-10.7 (IF mixer) = 116.30
-116.30/2 = 58.15?
-(i.e. mixing of the second harmonic of 58.15MHz)
-Ok, unlikely, just playing with numbers!
-Paul
-G1YJY
-"Snowbird" wrote in message
. com...
- Update: I talked to a local DE who is also doing piles of
- instrument instruction. She says she's flying in beaucoup
- planes in that area, without the same problem.
http://www.rst-engr.com
Old November 6th 03, 10:30 PM
Paul Sengupta
Ah, ok, thanks for that! What do they use? Is it standard?
Paul
"Jim Weir" wrote in message
recall an
Old November 7th 03, 06:04 PM
Jim Weir
Nope. They are all over the map. I chose a random book from the library...it
happens to be the King KX-170B. The high COM IF is 9.0M and the low COM IF is
861.25k. The high NAV IF is 15.1875M and the low NAV IF is 1.1857M. I could
pick half a dozen books from the shelf and no two would be the same.
"Paul Sengupta"
-Ah, ok, thanks for that! What do they use? Is it standard?
-Paul
-"Jim Weir" wrote in message
- You can stop playing with 10.7 as a source of the problem. I cannot
-recall an
- aircraft navcom using 10.7 as the IF frequency.
Old November 7th 03, 07:19 PM
Paul Sengupta
Blimey, thanks. Any idea how they decide to use these figures? Just out of
curiosity.
Paul
library...it
IF is
could
