Except in very strong wind conditions a rope break at or above 200' is
hardly an "emergency". It is a circumstance that requires immediate action, but appropriate training should make this a routine maneuver, executed with confidence. A real 150’ rope break becomes a true emergency at many airports where the glider is going to land off- airport and the outcome is not certain. The level of training needs to overcome the “surprise” factor to minimize the delay in reaction should a rope break take place. Bob |
On Tue, 12 Jul 2011 06:43:09 -0700 (PDT), Frank Paynter
wrote: Hi Frank, Well, there is a huge body of evidence from GA, airline, corporate aviation, and military aviation that indicates that ground-based simulation is very a very effective training tool for emergency procedures True. But maybe you noticed that the hardware these guys are using is not exactly in your $300 price range.... ![]() A student can practice realistic rope breaks in Condor by having an assistant hit the release unexpectedly, just as in real life. The student must perform exactly the same functions (lower the nose, establish a bank in the proper direction, look for an appropriate landing area, etc) as in real life. In a real-life rope break, there are two things that save lifes: 1. Before you take off, have a plan. Obvously. Know exactly what you are going to do - always. Pretty simple to teach. 2. Situation awareness This is what cannot be simulated on a PC. Tell the student pilot to lower the nose after release or row break, and stabilize the glider. I think the US term is "Fly the plane". so far, so simple - no simulator necessary to teach that. But now comes the difficult part. I'd like to list just a couple of points that come to my mind that need to be judged correctly to get a safe landing: What's the correct nose-down attitude in reference to the horizon if there's rising area ahead? Tall trees? Judge the exact position. Judge the wind. Turbulence? Decide about the maneuver that is going to get you down safely: Sufficient runway ahead to land safely? Return to runway, shortened traffic circuit, safe off-field landing ahead? Or even a controlled crash if a safe landing is not warranted? Once the pilot has decided which maneuver to fly, he needs to execute it properly. As we are discussing turns to return to the runway: What's the direction of the first turn, how many degrees are necessary for that first turn, when does one start the turn back towards the runway, what's the correct speed, when to extrend the airbrakes? All these points need precise judgement - which can only be done visually. Ever tried to judge heights and distances in Condor? Close to impossible - at close range things look completely different in real life. Quick scanning is absolutely necessary - the pilot needs to turn the head to get a quick overview. When flying his approach (especially if he flies a teardrop turn at low altitude in order to turn back to the runway) he needs to be able to look back over his shoulder and keep the glider under control at the same time. He must be able to quickly turn his head, scan horizon position, airspeed indicator, yaw string, then look back to the runway, judge his position and his turning radius, and so on. The ability to do this correctly is going to save his life. This is a technique that must be practiced. Simulate this on a 22" screen? No way. You need a dome with a 360 degrees field of view to simulate this. Any instructor knows that nearly all pilots who are flying a turn at low altitude tend to keep the wings as level as possible and use the rudder to turn the nose into the desired heading - the yaw string is pointing inwards in such a turn. Get too slow, and even the most benign glider will spin immediately - such an uncoordinated turn is the classic spin entry maneuvre. One is never going to see such a mistake on a 22" screen - the experience on a PC sim is simply missing the imaginary fear that a wing tip could touch the ground (this is the cause for such an uncoordinated turn: The pilot wants to keep the lower wing tip as far as possible from the ground, therefore turns too shallow, therefore he has to use something else to get his nose pointed into the desired direction: Voila, the rudder! Usually he's task saturated in such a situation - he simply does not recognize that the yaw string points into the wrong direction). It is incredible what mistakes are being made by task-saturated pilots, even if there's an instructor on board. None of these mistakes are made at the desk, steering a glider on a 22" screen with a $50 joystick, a keyboard and no fear of dying. So the two most important things cannot be taught on a PC sim: - Precise judgement of the situation, situation awareness - Fly the plane under severe stress Of course one can show the student pilot the possible maneuvres on a PC sim - but as long as there's no access to a flight simulator with a 360 degrees field of view and photo-realistic graphics, the student pilot MUST experience a rope break simulation in a real glider. I can pretty much guarantee you that the first few times the student does this, their reaction will be indistinguishable from their reaction in real life. In my experience - they stay cool, fly whatever maneuvre they have decided, and try again if it does not work. In real life they are scared to death and make mistakes they'd never make on a PC. Moreover, the situation in Condor can be easily configured so the student has no hope of returning to the field, and therefore must accomplish a safe off-airport landing - try that in real life! In real life the pilot thinks about the value of the glider he's about to trash - voila, stress! Won't happen on the PC. After 10 or 20 (or 100) SRBs in Condor, a student will be very well-drilled in rope-break procedures for a wide variety of situations, much more so than a corresponding real life only student who typically is exposed to only a few well-planned and very safe SRBs. ..... and after he's done some real-life rope-break procedures. I think that a PC based simulator like Condor could support real-life training, but never replace it. For less than $300 (assuming you already have a decent PC) you can have a training tool that has been shown over and over again to be effective in saving lives. Need I say more? What is effective in saving lives is to teach the student pilot the correct techniques to master such a situation. Show him in a realistic enviroment how to keep things under control. Let him experience that even a rope-break at a critical height is something that gives him enough time to assess a situation and make a decision for a safe landing. Once he has got the feeling that he is always in control, he'll loose most of his nervousness - stay calm, and fly a lot better. This self-confidence can only be taught inflight, not in a $300 PC game on a 22" screen. I am pretty sure that this could also be taught in a simulator with a cockpit and a view system that closele resembles reality - but then we are talking about an impressive five-digit $ sum. I tend to think that such a sum would better be used to (re-)train instructors to perform *safe* rope-break training. I have to admit that some of the stories I read in this thread made my hairs stand up. Andreas |
On 7/12/2011 7:24 PM, Andreas Maurer wrote:
Hi Frank, Well, there is a huge body of evidence from GA, airline, corporate aviation, and military aviation that indicates that ground-based simulation is very a very effective training tool for emergency procedures True. But maybe you noticed that the hardware these guys are using is not exactly in your $300 price range.... ![]() When you tell a student to push the nose down when he's already seeing individual leaves in stunning detail..... well, I'd like to see that simulated effectively. As others have said - there's a place for both. Tony V. |
Hi Bart,
It's interesting to me that "traffic pattern altitude" is not defined in 14 CFR part 1. As far as I know, any flight that includes a takeoff, climb and turn qualifies as a BFR flight. I'm sure no expert on the FAR's though. I think I read somewhere that the FAA definition (somewhere) of traffic pattern flight includes the requirement that it be within a half mile of the landing spot. I can't remember where I saw this though. |
On Friday, June 26, 2015 at 1:04:43 PM UTC-4, Jim Lewis wrote:
Hi Bart, It's interesting to me that "traffic pattern altitude" is not defined in 14 CFR part 1. As far as I know, any flight that includes a takeoff, climb and turn qualifies as a BFR flight. I'm sure no expert on the FAR's though. I think I read somewhere that the FAA definition (somewhere) of traffic pattern flight includes the requirement that it be within a half mile of the landing spot. I can't remember where I saw this though. Long dead thread resurrected... I was told at my CFI refresher clinic that the FAA considers the low rope break to be a pattern flight, especially since it helps promote safer flying by practicing emergency procedures. Matt |
TPA may not be defined in 14 CFR Part 1, but there's a section on it in the (yes, I know, not regulatory) AIM 4-3-3. "Traffic Patterns".
On Friday, June 26, 2015 at 4:29:08 PM UTC-7, Bob Pasker wrote:
TPA may not be defined in 14 CFR Part 1, but there's a section on it in the (yes, I know, not regulatory) AIM 4-3-3. "Traffic Patterns". Hi Bob, The stuff in the AIM is not regulatory but it is important for us to pay close attention to it. My feeling about the description of traffic patterns in the AIM is not due to it not being regulatory, it's due to it looking like it's describing a suggested pattern for power aircraft, not for gliders. Also, traffic pattern altitude, even for power aircraft, is not a universal value. We have all seen traffic pattern altitudes at a variety of airfields specified at altitudes from 500' for gliders (Rosamond) to 1500' for large aircraft at some fields. If we are doing our BFR in a glider at Rosamond do we need to delay a rope break to 500' so we reach "traffic pattern altitude". Maybe, but it seems foolish to me. I will continue to accept a rope break at 300' feet or so as qualifying for a BFR flight - but that's just me. |
tow rope | tazman | Soaring | 9 | August 25th 10 02:30 AM |
Mig-29 Crash during practice - topi.wmv (0/1) | Immaterial | Aviation Photos | 0 | January 20th 07 07:11 PM |
11 on a Rope | Peter Seddon | Rotorcraft | 0 | May 27th 04 11:33 AM |
Donuts on a rope | Big John | Piloting | 4 | May 2nd 04 04:53 AM |
Tow Rope Take-Up Reels | Nyal Williams | Soaring | 1 | September 17th 03 04:11 PM |
