Logan contest reporting now only on Soaring Cafe
Old July 26th 11, 02:38 AM posted to rec.aviation.soaring
Tuno
Default Logan contest reporting now only on Soaring Cafe
Although I personally disagree with this decision, it is within the
purview of the on-site contest management to decide who posts to the
SSA website.
QT
Rules Committee
And as reported by Ken Sorenson, "Logan, UT contests have apparently
elected to change reporters at the contest".
All that is clear, and no argument from me, but none of it explains
why SSA removed the old posts. I would like to know why that
additional step was taken.
2NO
Old July 26th 11, 02:57 AM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
SSA website.
QT
Rules Committee
2NO
Removing the posts is available and under control of the contest
management. So you can't tell whether it was the SSA or the contest
management.
Old July 26th 11, 04:09 AM posted to rec.aviation.soaring
Andy[_10_]
SSA website.
QT
Rules Committee
2NO
On censorship:
It's up to the organizers to select the individual to post daily
contest reports. They are within their rights to change writers or
even delete posts - though it doesn't look good when they do. When
you ask someone who injects color and personal opinion into his
writing to post on behalf of the contest organizers, then have some
marginal days with intimidating flying you are going to get the
obvious injection of perspective to the commentary.
On Logan as a site:
I broke my beloved -27B landing in barley in a mountain valley on Day
2 of the 15M nationals. I made all the decisions myself and live with
the consequences. In the end if I had flown about 2 miles farther
away from landable fields I likely would have made it home, but I
didn't feel comfortable with the all-or-nothing proposition that
appeared to represent at the time.
Logan is a very technical site and that fact is particularly apparent
when the top of lift is 10,000' or lower. The spread in the scores,
large numbers of outlandings and significant numbers of withdrawals -
along with a couple of broken gliders - all stand as evidence of how
challenging the flying can be.
The challenges this year at logan fall into three broad categories:
1) The lift starts on the late side - generally after 2pm. It might go
on until 7:30, but sometimes it doesn't. This makes it challenging to
get a 4-hour Nationals task in when you account for launching all the
gliders and giving them time to climb up. Yesterday's task shows the
challenge of getting a 3 1/2 hour task in.
2) Climbing out is a challenge. The Logan ridge is 10,000 feet high
and 4-5 miles from the airport. It's a steep series of ridges and
canyons and you really have to rack it up (but not past 45-50 degrees
or your circle get's bigger not smaller - shockingly even experienced
pilots forget this). You have to work your way from one spur to the
next and when you get to the top you have about a 1,000- foot working
band before you are below the ridge tops and have to start over.
Better weather make this less of a challenge, but in 10 days there
this was the case every day this year. This year we towed to 2,500
feet to try to give pilots a better chance to get a climb, bit it
exacerbates #1 when you spend the additional 25-30% in timer per tow.
3) Ridge transitions are the name of the game. There is not reliable
lift in the valleys so you fly ridge to ridge. Given the nature of the
terrain you may ridge soar or choose thermals in the high ground. When
the top of lift is low you have to do both - climb up on one ridge and
dive to the next one, ridge soar upon arrival until you can find a
thermal - or ridge run for a bit.
4) There are broad swaths of terrain in the contest areas that are
unattractive, either because they are in marine air, filled with water
or made of lava (hardened, not molten), among other things. This is
true of many sites to one degree or another. Most problem areas were
briefed at various pilots' meetings. If you combine #4 with #3 you get
areas like where I got into trouble where you need the ridge to work
our are faced with a 15-mile glide to landable spots. When the lift
doesn't go very high you end up with what amounts to a 500-1,000'
working band. In my case I decided to glide toward the fields to play
it safe but with the air running down instead of up in the valleys my
achieved L/D was cut in half - 23:1 instead of 48:1 according to
SeeYou. Which brings me to the final point...
5) It's mountain flying. Mountains are big geographic features that
can have a big impact on the local weather conditions. Large areas of
lift and sink that you might not find in the flatlands are the main
things to think about. It's all the more critical when you are flying
low-level.
To me all of this adds up to a need to do a lot of homework when going
to fly at a place like Logan. If the conditions are strong you likely
have enough margin to mask many of the challenges, but when you are
among, rather than above, the mountains you need to take care.
It's a beautiful place with a great airport and a supportive
community. I'd go again - I've already made a big investment in
learning about how to fly there.
9B
Old July 26th 11, 04:42 AM posted to rec.aviation.soaring
Andy[_10_]
SSA website.
QT
Rules Committee
2NO
On censorship:
contest reports. *They are within their rights to change writers or
even delete posts - though it doesn't look good when they do. *When
On Logan as a site:
the consequences. *In the end if I had flown about 2 miles farther
when the top of lift is 10,000' or lower. *The spread in the scores,
on until 7:30, but sometimes it doesn't. *This makes it challenging to
and 4-5 miles from the airport. *It's a steep series of ridges and
low-level.
to fly at a place like Logan. *If the conditions are strong you likely
9B
Meant to say "five categories" - or in the words of Monty Python, "No
one expects the Spanish Inquisition!"
Old July 26th 11, 04:55 AM posted to rec.aviation.soaring
Ron Gleason
SSA website.
QT
Rules Committee
2NO
On censorship:
On Logan as a site:
low-level.
9B
Frank was never asked by the contest management to be the reporter for
the contest therefore we did not change reporters.
Old July 27th 11, 01:46 AM posted to rec.aviation.soaring
noel.wade
As someone who flew Logan both last year and this year, I wanted to
add a couple of things to Andy's thoughtful post:
My big takeaway from the contest (at least during the Regionals week)
was that Logan was a more challenging place to fly this year than
"normal". Mostly it was bad timing on the part of the weather Gods -
but there were a lot of things, including:
1) Weaker lift during a period of intense glider activity, especially
with folks who were keen to carry a lot of water and fly hard.
2) Somewhat lower lift heights than last year
3) A bad winter causing crops to be "behind schedule" in being
harvested, slightly reducing the landout options a bit
4) Contest organizers wanting to make sure that a very large field of
aircraft had enough time to get organized and ready. Coupled with the
late days this meant baking on the tarmac for 2 hours every day;
something that I think contributed to fatigue, concentration, and
frustration levels (especially after launch while crawling up the
ridge in groups).
5) A very large and diverse set of pilots, including a lot of people
who aren't used to mountain flying and didn't seem to be comfortable
with key aspects of such flying (including when to "change gears" to
fly conservatively, and planning ahead to ensure that you stop soaring
with enough altitude left to reach a landout field that may be a few
miles from your position).
I've got some minor quibbles (such as the backup tasking that others
have mentioned); but overall I think the contest staff did the best
they could, including many safety briefings, strategy tips, and "data-
dumps" by local experts gathered around big maps and slide-show
presentations. Scoring was handled very promptly and openly. Karl S
was a stern-but-reasonable CD while I was there. And although I had
some frustrating days myself, I *like* the fact that this was a
challenge (for both the Regional pilots and the Nats competitors). As
I've said befo in my opinion there's a big difference between a
"fun-fly" and a contest; especially when we're talking about National
Championships!
One last thing: I've seen and heard so much about the "unlandable"
terrain around Logan, on this message group and other places. I am
not trying to make a personal attack on those folks; but do people
talk the same way about Montague? Parowan? Or (most of) Nevada? How
about soaring in the Alps or New Zealand (which most pilots talk about
whilst drooling)? It seems to me that anywhere you fly there are
going to be unlandable areas. I was taught that part of soaring is
learning to either avoid those areas, or to cease soaring and deviate
to landable terrain when you get below a safe altitude. As long as
proper judgement is used, unlandable terrain isn't necessarily
_unsafe_ terrain. And while I have full sympathy and respect for the
pilots who damaged their gliders, I'd like to point out that it wasn't
the youngest pilots or least-experienced contestants at Logan who got
into trouble - so its not like baby lambs were being led to slaughter
(I consider myself one of those baby lambs, since this was just my 5th
contest and I only have ~300 hrs in gliders). OK, OK, I'll get off the
soap-box...
Hope to see you all at future contests!
--Noel
Old July 26th 11, 02:37 PM posted to rec.aviation.soaring
Ken Sorenson
Ted,
My understanding is that the contest organizer, who has responsibility for
the contest reports, asked the SSA webmaster to remove the reports, which he
did. The decision to remove the reports was made by the contest organizer. A
posting elsewhere in this thread by Tim Taylor explains their rationale.
As you know from your own experience as a contest organizer, putting on a
contest is a huge amount of work, usually done entirely by a small group of
volunteers. Those of us who are privileged to fly these contests really
appreciate the effort put in by all contest organizers, however imperfect
they may seem at times. It has become increasingly difficult to find the
volunteers needed to host, organize, and run contests. Hopefully the folks
who have become wound up over the handling of Frank's entertaining reports
will give the contest organizers, and the SSA volunteers, the benefit of the
doubt on this matter. The last thing we can afford to do is to run off the
few SSA volunteers and contest organizers we have. There is no "them", its
just "us".
Ken Sorenson
"Tuno" wrote in message
SSA website.
QT
Rules Committee
2NO
Old July 26th 11, 03:22 PM posted to rec.aviation.soaring
Ron Gleason
On Jul 26, 7:37*am, "Ken Sorenson" wrote:
Ted,
did. The decision to remove the reports was made by the contest organizer.. A
few SSA volunteers and contest organizers we have. *There is no "them", its
just "us".
Ken Sorenson
SSA website.
QT
Rules Committee
2NO
2NO,
The removal of the reports we done by the contest organizers, in fact
I performed the actions after ALL of the contest organizations agreed
to the action. There was no involvement by anyone at the SSA. We
understood the risks of our decision and actions.
Ron Gleason
Old July 26th 11, 06:45 AM posted to rec.aviation.soaring
Tim Taylor
Posts to the SSA contest page are permanent parts of contest
reporting. The Logan contest management expected that material posted
to the official webpage would be factual. While blogs may embellish
or exaggerate to make the material more interesting, it is important
to provide true statements on the official website that do not mislead
readers. Unfortunately the posts to the website had misleading
statements that were beyond mild exaggeration. The statement that led
to the removal of the posts was from the Day Three report (July 22,
2011):
“As it turned out, a huge cloud street set up well to our north over
Sherman Peak running horizon to horizon east-northeast to west-
southwest that ran right through the 15m task area. ”All” we had to
do was get to Sherman Peak, connect with the street, run it for 80
miles out over completely unlandable (and uninhabited) terrain, turn
around and get home, and all but one 15m pilot was able to do this in
some fashion or another.”
While the statement makes for sensational reading and from the
comments on RAS many believed it; unfortunately it was misleading and
was well beyond exaggeration for effect. After reviewing Frank’s
flight for that day (July 21st), it is evident that he was never more
than eight miles from landable fields and this was at flight altitudes
of 4500 to 9000 feet agl. You can download his KML file from the OLC
and review it in Google Earth. Please notice both the many
communities, farms, airports and landable fields he and the rest of
the competitors flew over. You can review my July 3rd flight where I
landed in the flight zone of the July 21st contest flight to see that
many of the fields that are not green are also landable. Almost every
valley in the flight area is filled with landable fields. In general,
most of the tasking area in Logan has many airports and landable
fields in all quadrants. It is one of the safest mountain sites that
I have ever flown at and I have received similar comments from top
pilots that have flown at Logan. It is somewhat intimidating to the
new pilots that are not familiar with mountain flying, but those that
embrace it come away excited about the possibilities and find they
approach their flying in a different way after the experience. I
encourage the readers here to do their due diligence and review flight
logs and tasks in Google Earth before believing everything they read
in blogs and RAS.
The Logan contest management felt that while it was perfectly fine for
Frank or any other blogger to write their opinions, they should not be
posted as part of the official website. There were also many other
bloggers at the contest and this leads to the question of how best to
provide easy access to all bloggers without officially endorsing
them. The best solution was to remove the posts and provide links to
Frank’s and others’ blogs as part of the official daily report.
Readers can easily link to the blogs and it provides a clear
separation from the official report.
Tim Taylor
Old August 8th 11, 07:55 AM posted to rec.aviation.soaring
Buba Smith
reporting. *The Logan contest management expected that material posted
to the official webpage would be factual. *While blogs may embellish
readers. *Unfortunately the posts to the website had misleading
statements that were beyond mild exaggeration. *The statement that led
2011):
southwest that ran right through the 15m task area. *”All” we had to
was well beyond exaggeration for effect. *After reviewing Frank’s
of 4500 to 9000 feet agl. *You can download his KML file from the OLC
the competitors flew over. *You can review my July 3rd flight where I
many of the fields that are not green are also landable. *Almost every
valley in the flight area is filled with landable fields. *In general,
fields in all quadrants. *It is one of the safest mountain sites that
pilots that have flown at Logan. *It is somewhat intimidating to the
approach their flying in a different way after the experience. *I
in blogs and RAS.
posted as part of the official website. *There were also many other
them. *The best solution was to remove the posts and provide links to
Tim Taylor
Tim ,
I am amused and amazed by your response . While doing my " Due
diligence " it got me wondering how often Google earth is updated ( IE
to show things like crop height , damage from an excessive winter
snowfall , single wire powerlines , etc ) . Second , I welcome your
opinion but please don't express it as fact . Ive flown nothing but
mountain sites in my gliding career and there is nothing safe about
some of the dubious terrain pilots had to fly over to complete tasks
in Logan . Nothing safe about packing close to 60 gliders and 5
towplanes at the same altitudes along a mile and a half stretch of
ridge either . For the contest management to sterilize the news from
Logan was probably not the best course of action . In many of the
attendees opinions the criticism was justified and it should have been
dealt with and put behind us .
Here is another way to look at it ; A contest can be run in such a
manner that it encourages participation and stresses safety or it can
be run in such a manner that only a small handfull of participants
finish tasks and want to come back . http://soaringcafe.com/2011/08/thoug...15m-nationals/
A sad day for Utah soaring . I hope that if there is another
contest at Logan next year things will go better . I am a big fan of
soaring in Northern Utah and Ill do anything I can to help .
r4
Soaring Cafe | First Week Digest Bill Elliott Soaring 3 January 11th 11 07:04 PM
More Videos from Logan, UT Region 9 contest Bruno[_2_] Soaring 5 August 15th 10 03:58 PM
First of Logan Region 9 Contest HD Videos Bruno[_2_] Soaring 1 July 27th 10 02:05 AM
HD video from Logan Region 9 Contest Bruno Soaring 2 August 25th 09 04:03 AM
Ely Region 11 Soaring contest # 711 reporting. [email protected] Soaring 0 May 31st 05 06:16 PM
