Where Can I Find Good P-Lead Cable
Old November 5th 03, 02:58 AM
Larry Smith
Default Where Can I Find Good P-Lead Cable
The kind I've been receiving from the suppliers is too light on the
shielding and too heavy on the cable lead. When you wire it up to the
switch you have to make grounded leads out of the shielding. With shield
it needs to be around .130 in diameter and the lead should be only a few
strands, like 10 or so.
Three of us need P-leads for our projects asap.
Thanks.
Old November 5th 03, 04:19 AM
Orval Fairbairn
Thanks.
Any good shielded cable will suffice, as there is very little amperage
that you have to ground. Essentially, P-leads ground the low-voltage
side of the magneto, so there is no current passing through the coil.
Old November 7th 03, 11:16 PM
Jerry Wass
!doctype html public "-//w3c//dtd html 4.0 transitional//en"
html
I have a bunch of MS 22759/20   20 ga.  that sounds about
right--the center cond
bructor has 19 strands , but the outer shield twists into a wire about
the same size...
brinner .037, outer .042---I'll send you 50 ft for  a $10.00 bill
Jerry
pLarry Smith wrote:
blockquote TYPE=CITEThe kind I've been receiving from the suppliers is
too light on the
brshielding and too heavy on the cable lead.   When you wire
it up to the
brswitch you have to make grounded leads out of the shielding.
With shield
brit needs to be around .130 in diameter and the lead should be only
a few
brstrands, like 10 or so.
pThree of us need P-leads for our projects asap.
pThanks./blockquote
/html
Old November 7th 03, 11:43 PM
Larry Smith
Bless you, you got a deal.
"Jerry Wass" wrote in message ...
I have a bunch of MS 22759/20 20 ga. that sounds about right--the center cond
uctor has 19 strands , but the outer shield twists into a wire about the same size...
inner .037, outer .042---I'll send you 50 ft for a $10.00 bill Jerry
Thanks.
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 04:14 PM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
