RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards)
Old November 6th 03, 10:30 PM
Paul Sengupta
Ah, ok, thanks for that! What do they use? Is it standard?
Paul
"Jim Weir" wrote in message
You can stop playing with 10.7 as a source of the problem. I cannot
recall an
aircraft navcom using 10.7 as the IF frequency.
Old November 7th 03, 06:04 PM
Jim Weir
Nope. They are all over the map. I chose a random book from the library...it
happens to be the King KX-170B. The high COM IF is 9.0M and the low COM IF is
861.25k. The high NAV IF is 15.1875M and the low NAV IF is 1.1857M. I could
pick half a dozen books from the shelf and no two would be the same.
"Paul Sengupta"
-Ah, ok, thanks for that! What do they use? Is it standard?
-Paul
-"Jim Weir" wrote in message
- You can stop playing with 10.7 as a source of the problem. I cannot
-recall an
- aircraft navcom using 10.7 as the IF frequency.
http://www.rst-engr.com
Old November 7th 03, 07:19 PM
Paul Sengupta
Blimey, thanks. Any idea how they decide to use these figures? Just out of
curiosity.
Paul
library...it
IF is
could
Old November 7th 03, 08:39 PM
Jim Weir
Back in the old days we did it by trial and error and glommed onto what worked
best. When the digital computer came along, we got a full blown printout of the
inter/cross/spuri mod products across a frequency band and picked a
frequency(ies) for the IF that produced minimum spurious products.
Note the word MINIMUM. There has never been a receiver produced by the
superheterodyne process that is totally free of spurious, including the
magnificent Collins S-line or 51J series of receivers.
"Paul Sengupta"
-Blimey, thanks. Any idea how they decide to use these figures? Just out of
-curiosity.
-Paul
- Nope. They are all over the map. I chose a random book from the
-library...it
- happens to be the King KX-170B. The high COM IF is 9.0M and the low COM
-IF is
- 861.25k. The high NAV IF is 15.1875M and the low NAV IF is 1.1857M. I
-could
- pick half a dozen books from the shelf and no two would be the same.
