Netto
Old August 1st 11, 08:50 PM posted to rec.aviation.soaring
BobW
Default Netto
On 7/31/2011 2:02 PM, Martin Gregorie wrote:
To me, "netto" means a vario display indicating the actual vertical air
motion, relative to the earth's surface...i.e. 'net air motion' once the
glider's own speed-dependent sink-rate contribution has been
subtracted/eliminated from the picture. In other words, 'my netto
display' always indicates actual air motion, independent of glider speed
(the 'glider speed' bit being the 'compensation' part). No
interpretation needed - that's the beauty of it, so far as my brain is
concerned. And that's also why the speed ring doesn't require the pilot
to iterate in on the speed to fly...because the glider's increasing sink
rate with increasing speed has already been subtracted out of the
display. Hence the vario needle *always* points to 'absolute air
motion,' and in consequence to the whatever speed to fly your ring
setting calls for.
Yes, I agree, but 'super netto' or 'relative netto' are alternative terms
for something different from either TE vario of 'netto'.
A 'super netto' vario shows what a glider would be doing if it was flying
in the current air mass at its thermalling speed, so as well as the TE
input, it also needs the current IAS and the glider's polar.
Snip...
Trying to keep things simple (for my simple brain), here's my understanding of
the following terms...
Unadjectivized "netto" - subtracts out the glider's (presumed known) straignt
line, speed-dependent polar from (the common, everyone-is-comfortable-with-it)
'pure TE vario' display...(theoretically) yielding a speed-independent display
of actual vertical air motion, relative to the earth's surface.
Super/Relative "netto" - *FURTHER* aubtracts out the glider's (also presumed
known) circling-in-lift sink rate *increment* (i.e. the bit exceeding the
straight line sink rate at thermaling speed) *FROM* the 'unadjectivized
"netto"' display...(theoretically) yielding a speed-independent display NOT of
vertical air motion, but of 'theoretical projected climb rate' should Joe
Glider Pilot decide to stop and thermal.
The former subtracts out a speed-dependent, quadratically-approximate polar
curve, while...
the latter subtracts out [the former + a thermaling increment/constant].
Both quantities subtracted are approximations of reality, though a good
argument can be made that speed-dependent polars are more precisely known (at
least in the public world of shared, measured data) than are circling sink
rates (and by implication, their increment above the non-circling sink rate at
thermaling speed).
My guess is 'actual vertical air motion' is what every hawk intuitively is
interested in. Certainly an interesting, discussion-worthy topic for those
non-soaring times. Is there a 'best display'? It depends!!!
Regards,
Bob W.
Old July 31st 11, 07:07 PM posted to rec.aviation.soaring
John Sinclair[_2_]
Default Netto
At 15:43 31 July 2011, John Sinclair wrote:
At 17:19 29 July 2011, bish wrote:
Hi
This question has probably been ask many time!
My new to me LX 7000 offer the choice of Netto or Relative netto for
the vario needle
During cruise with pure Netto selected the needle will be down most of
time. When you go through a 3 knot thermal your display will go from 600
down to 300 down, hard to realize you are in a 3 knotter. If you select
relative Netto, the display will show the climb rate you will get if you
slow down to thermal speed, or 300 up! Much easier to read and
understand.
I never use anything but relative netto.
JJ
TEST
How do I rig a netto variometer Scott Alexander[_2_] Soaring 10 February 17th 11 06:09 AM
How to build a Netto Pat Russell[_2_] Soaring 3 May 14th 10 12:17 PM
WTB: Sage Model B Netto Total Energy Box November Bravo Soaring 0 March 15th 05 03:10 PM
NETTO Question Shoulbe Soaring 5 September 16th 03 05:21 PM
Cambridge 302 and Super netto Ross Biggar Soaring 13 September 13th 03 08:57 PM
