On Aug 18, 9:09*am, JJ Sinclair wrote:
On Aug 17, 11:13*pm, P9 wrote: Another water ballast question. How well does a fully ballasted glider recover from a spin? I practice spins every season, dry. *The recovery is easy and predictable. *(SZD 55-1) *I have never tried a spin with water. *If I accidently spin at low atlitude (1000 ft agl or lower) fully ballasted, should I attempt to recover, or just bail? Kerry Hi Kerry, Enjoyed flying with you at Air Sailing Sports. Good race again this year and those AFA guys can no longer be ignored, can they?Your 55 holds a ton of water, I'd recommend you try spinning it with a half load, then work up from there.................well maybe that's not such a good idea because a partial load can shift to the outboard wing tip and give a big lateral weight problem. I remember Carl Herold telling me the 12 would tuck under to where the nose was more than vertical when he spun her with a load of water.........Hmmm, maybe don't spin it wet would be the best advice and if you spin it at 1000 agl, i'd do it with *a BRS installed. Adding the BRS to my Genesis was the best thing I have done lately, I feel much more secure now and enjoy that comfortable seat (without *chute). Cheers, JJ Don't forget the story of spin testing the Schweitzer 1-35. Since the plane was to be certified by the FAA and it was the first Schweitzer with water ballast, the FAA insisted on a spin test with one wing full and the other dry. Needless to say it was a pretty exciting test... The towpilot followed the plane down and reported the spin axis was outboard in the wing. It took multiple kicks of the rudder to finally break the spin. The test pilot administered a few extra kicks after landing just for good measure! Note also that some planes prohibit spins while loaded with ballast. Make sure to consult your owner's manual carefully. Keep in mind that the ballast will move outboard in your wings and increase your rotational momentum. Also keep in mind the advice from a good friend of mine who used to be a test pilot: "Don't spin!" -- Matt |
On Aug 18, 7:05*am, mattm wrote:
On Aug 18, 9:09*am, JJ Sinclair wrote: On Aug 17, 11:13*pm, P9 wrote: Another water ballast question. How well does a fully ballasted glider recover from a spin? I practice spins every season, dry. *The recovery is easy and predictable. *(SZD 55-1) *I have never tried a spin with water. *If I accidently spin at low atlitude (1000 ft agl or lower) fully ballasted, should I attempt to recover, or just bail? Kerry Hi Kerry, Enjoyed flying with you at Air Sailing Sports. Good race again this year and those AFA guys can no longer be ignored, can they?Your 55 holds a ton of water, I'd recommend you try spinning it with a half load, then work up from there.................well maybe that's not such a good idea because a partial load can shift to the outboard wing tip and give a big lateral weight problem. I remember Carl Herold telling me the 12 would tuck under to where the nose was more than vertical when he spun her with a load of water.........Hmmm, maybe don't spin it wet would be the best advice and if you spin it at 1000 agl, i'd do it with *a BRS installed. Adding the BRS to my Genesis was the best thing I have done lately, I feel much more secure now and enjoy that comfortable seat (without *chute). Cheers, JJ Don't forget the story of spin testing the Schweitzer 1-35. *Since the plane was to be certified by the FAA and it was the first Schweitzer with water ballast, the FAA insisted on a spin test with one wing full and the other dry. *Needless to say it was a pretty exciting test... The towpilot followed the plane down and reported the spin axis was outboard in the wing. *It took multiple kicks of the rudder to finally break the spin. The test pilot administered a few extra kicks after landing just for good measure! Note also that some planes prohibit spins while loaded with ballast. Make sure to consult your owner's manual carefully. *Keep in mind that the ballast will move outboard in your wings and increase your rotational momentum. *Also keep in mind the advice from a good friend of mine who used to be a test pilot: *"Don't spin!" -- Matt Some years ago, I got kicked out of a boisterous and very turbulent Arizona thermal flying my ASW-20 with close to full ballast. The yaw string went sideways, then backwards and I literally fell out of the sky, entering a strong incipient spin (perhaps half or three-quarters of a turn). I fortunately did everything right and recovered quite quickly, but lost nearly 800 feet of altitude in the process. It caught my attention! Ever since then, I have always thermalled more conservatively when anywhere near the ground. I know of at least one incident of a modern ship that stalled off tow and spun into the ground when fully ballasted. I also do not spin - ever! Mike |
Trying for a Diamond Goal tommorow - water ballast question | Scott Alexander[_2_] | Soaring | 27 | April 29th 10 09:28 PM |
DUMB ROOKIE QUESTION | Travis Beach | Soaring | 10 | November 7th 06 07:28 PM |
Who first used water ballast and when? | John McCullagh | Soaring | 9 | October 18th 06 09:36 AM |
water ballast leak | Robert Harvey | Soaring | 2 | May 27th 05 03:49 PM |
Std 102 water ballast plug | Tom Dukerich | Soaring | 3 | April 12th 05 05:10 PM |
