On Sep 10, 7:18*pm, Dave Hoppe wrote:
Something is amiss. If you were entering the landing pattern with your gear up and you open your spoilers, you definitely should not have to power cycle the 302 to get the alarm. That would kind of defeat the purpose. My 302 is 6 years old, however it had the latest firmware installed this last winter. Dave - The power cycle testing I refer to is perform on the ground during/after assembly...not in the air during the landing cycle. Thanks. |
On Sep 9, 5:23*pm, ContestID67 wrote:
I was informed (and verified) that there is a way to easily test the 302 warning system while on the ground. - Power down the 302 - Unlock the airbrakes with the gear unlocked/up - Power up the 302 The alarm will then sound (euro siren) after the self test is complete. *A large upwards pointing arrow will appear in the display, different than the small speed up/down arrows, meaning I suppose that your gear is up. *You can silence the alarm by pushing the button. Yet another undocumented feature/sound from the Cambridge 302! - John The power up alarm sounds with brakes unlocked with the gear DOWN and locked. After power up test execution the gear warning is as expected - the gear alarm only sounds if the brakes are unlocked and the gear is not down locked. The alarm may also sound on power up with the brakes unlocked and the gear not down and locked but I can't be sure of that as my assembly routine has gear down and glider pushed back from trailer before the batteries are fitted. Andy |
What about the guys who routinely, and with knowledge, begin takeoff with
their spoliers partially opened. I do that when I'm flying the rented LS-4 as it feels to me like it improves aileron control early in the takeoff roll. I close and lock the spoilers as soon as control is assured. In my Mosquito, I begin takeoff roll with flaps full negative as I did in my previous LS-6. Would you deny me a hookup even after I announced to you that my spoilers are open and why? I'm talking about the (apparently) sleeping pilots who, at 200 feet fail to notice that the spoilers have just popped open without command. I've read of the tow pilot taking that glider pilot to safe altitude, releasing him within good landing position, and then watching him fail to reach the airport because he never recognized the problem. And, please, let's not start another radio discussion. "Martin Gregorie" wrote in message ... On Fri, 09 Sep 2011 09:00:53 -0600, Dan Marotta wrote: If your spoilers "suck open" and you don't recognize it, you shouldn't be flying. Maybe other outfits should adopt my club's new-for-2011 change in launch procedu the cable is NOT put on unless the pilot announces "Brakes locked" before asking for 'cable on'. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 9/9/11 3:56 PM, Martin Gregorie wrote:
the cable is NOT put on unless the pilot announces "Brakes locked" before asking for 'cable on'. And if the pilot uses spoilers to get better aileron control at the start of the takeoff? Or the wheel brake is on the spoilers and the pilot wants to prevent a rope overrun? -Tom |
On Sat, 10 Sep 2011 19:39:46 -0700, Tom Serkowski wrote:
On 9/9/11 3:56 PM, Martin Gregorie wrote: the cable is NOT put on unless the pilot announces "Brakes locked" before asking for 'cable on'. And if the pilot uses spoilers to get better aileron control at the start of the takeoff? Doing standard UK CBSIFTCBE preflight checks, accepting the cable before opening the brakes and keeping a hand on the brake lever allows the pilot to accept the cable with brakes locked, so the confirmation can be made correctly. Of course, if you are flying somewhere that doesn't teach a preflight check which includes opening, visually checking, and then locking the brakes, doesn't include the checks in every flight under instruction and which tolerates launches for pilots who skip the preflight check then you should expect launches with unlocked brakes as well as any consequent crashes. Or the wheel brake is on the spoilers and the pilot wants to prevent a rope overrun? Totally unlikely on our field, which is, if anything, always slightly uphill since it has a small hump (on a winch launch the wing runner can see the winch flashing but the pilot usually can't). I've only flown on one field where that was necessary, the Wasserkuppe, and again that's a bit special since you take off downwind and downhill on a hard runway which is steep enough to require a small wooden wedge in front of the main wheel to stop the glider running forward while the pilot (s) get in. In any case in the UK and other places where the CBSIFTCBE preflight check is taught the pilot will have cycled the brakes AND DONE A VISUAL CHECK before unlocking and opening them if the glider needs that for a successful launch, so the announcement "Brakes locked: cable on, please" should be redundant. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
ASW-20C Gear Warning Switch Placement | Jim Kellett | Soaring | 3 | May 16th 09 01:20 AM |
Gear Warning | Gadget Guy | Soaring | 118 | November 30th 05 10:43 PM |
Gear Warning | Gordon Schubert | Soaring | 11 | November 22nd 05 03:27 AM |
Gear Warning | Gordon Schubert | Soaring | 0 | November 18th 05 08:22 PM |
gear warning plus | K.P. Termaat | Soaring | 0 | September 8th 03 08:33 AM |
