With an excellent V/STOL capability in the F-35B, why does the Navy still
demand those giant carriers? Read about the Falklands War and maybe you'll see why. -- Mike Kanze "Just because you do not take an interest in politics doesn't mean politics won't take an interest in you." - Pericles (430 B.C.) "puttster" wrote in message om... "John Carrier" wrote in message ... Now if you want to argue that the F-35B is an aircraft designed as a Carrier Aircraft, I know some Marines that would like to chat with you. The B will be replacing AV-8B's and land based F-18's. Sure, it can land on a carrier but it is not being built to trap aboard CV/N's using arresting gear or Cat launches. True in a sense, but as a VSTOL and STOVL design, it's fully carrier suitable w/o the need for catapult gear (I suspect it does have a tailhook). I'd also be much surprised if its CNI suite didn't include ACLS and SPN-41 in their latest incarnations. R / John With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? |
![]() "puttster" wrote in message om... "John Carrier" wrote in message ... With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Because they also plan to operate aircraft like the E2 Hawkeye and F-18E Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? Because they already gave the ships. Keith |
![]() "puttster" wrote in message om... "John Carrier" wrote in message ... Now if you want to argue that the F-35B is an aircraft designed as a Carrier Aircraft, I know some Marines that would like to chat with you. The B will be replacing AV-8B's and land based F-18's. Sure, it can land on a carrier but it is not being built to trap aboard CV/N's using arresting gear or Cat launches. True in a sense, but as a VSTOL and STOVL design, it's fully carrier suitable w/o the need for catapult gear (I suspect it does have a tailhook). I'd also be much surprised if its CNI suite didn't include ACLS and SPN-41 in their latest incarnations. R / John With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? Because the F-35C flies farther with a bigger load than the F-35B. Because the ships aren't going away since they need the deck for the E-2 and C-2 anyway. |
John Keeney wrote:
"puttster" wrote in message om... "John Carrier" wrote in message ... Now if you want to argue that the F-35B is an aircraft designed as a Carrier Aircraft, I know some Marines that would like to chat with you. The B will be replacing AV-8B's and land based F-18's. Sure, it can land on a carrier but it is not being built to trap aboard CV/N's using arresting gear or Cat launches. True in a sense, but as a VSTOL and STOVL design, it's fully carrier suitable w/o the need for catapult gear (I suspect it does have a tailhook). I'd also be much surprised if its CNI suite didn't include ACLS and SPN-41 in their latest incarnations. R / John With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? Because the F-35C flies farther with a bigger load than the F-35B. As always, the question is how much do you need that extra range, and should the navy a/c do that mission when it is needed? Kind of depends how you define the littorals -- you can see claims and studies made for everything from 200nm to 650nm from the coastline, depending on whose ox is being gored -- here's one that discusses this issue, and decides based on historical evidence that 400nm is about right, and that the STOVL JSF is more than adequate for all three services: http://handle.dtic.mil/100.2/ADA331611 Note, while you'd expect this to be a USMC paper, it was actually written at ACSC. Still, there were definitely Marines involved in writing it, so take the analysis and conclusions with as large or as small a grain of salt as you think appropriate. Because the ships aren't going away since they need the deck for the E-2 and C-2 anyway. Of course, when (if) the V-22 or some similar VSTOL support a/c enters service, that particular justification need no longer exist. IIRR it was Adm. Holloway, when CNO in the '80s(?), who planned to have the navy go all VSTOL sooner rather than later. The slow pace of VSTOL development slowed things down, especially the support a/c requirement (ASW, AEW, COD, tanker, ESM, SOJ, CSAR, what have you), as only now is an a/c (the V-22) with roughly the required performance, in view. It is inferior in performance for each specific mission than the more specialized individual aircraft types that now perform these functions, but the ability to use a single basic airframe for all these missions means big savings on training, spares and unit cost. Whether this changeover actually happens is another matter, as there doesn't appear to be a big VSTOL backer inside the navy at the moment, and the navy is afraid that going all VSTOL will make it easier for politicians to decide that, because VSTOL a/c _can_ operate from smaller, cheaper carriers, there's no need to buy big ones, ignoring the operational benefits of larger carriers in power projection. OTOH, the USAF's recent volte-face (they want some again) on buying some STOVL F-35s for themselves, may put more pressure on the navy to go VSTOL. Or not :-) Guy |
![]() "Guy Alcala" wrote in message . .. John Keeney wrote: "puttster" wrote in message om... "John Carrier" wrote in message ... Now if you want to argue that the F-35B is an aircraft designed as a Carrier Aircraft, I know some Marines that would like to chat with you. The B will be replacing AV-8B's and land based F-18's. Sure, it can land on a carrier but it is not being built to trap aboard CV/N's using arresting gear or Cat launches. True in a sense, but as a VSTOL and STOVL design, it's fully carrier suitable w/o the need for catapult gear (I suspect it does have a tailhook). I'd also be much surprised if its CNI suite didn't include ACLS and SPN-41 in their latest incarnations. R / John With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? Because the F-35C flies farther with a bigger load than the F-35B. As always, the question is how much do you need that extra range, and should the navy a/c do that mission when it is needed? Kind of depends how you define the I want to see the carriers able to hit Afganistan from the Indian Ocean and a few other places that might be a tad less accessible. Call it the "anywhere in the second country in from the beach" rule. littorals -- you can see claims and studies made for everything from 200nm to 650nm from the coastline, depending on whose ox is being gored -- here's one that discusses this issue, and decides based on historical evidence that 400nm is about right, and that the STOVL JSF is more than adequate for all three services: http://handle.dtic.mil/100.2/ADA331611 I tried to look, but I became too impatient and gave up on the down load. Note, while you'd expect this to be a USMC paper, it was actually written at ACSC. Still, there were definitely Marines involved in writing it, so take the analysis and conclusions with as large or as small a grain of salt as you think appropriate. Because the ships aren't going away since they need the deck for the E-2 and C-2 anyway. Of course, when (if) the V-22 or some similar VSTOL support a/c enters service, that particular justification need no longer exist. Putting a spinning top on a V-22 sounds scary to me, have to be plum tall to see over those rotors. Might do an EV-22 with a phased array. As for the COD role: the C-2 does 10,000 pounds over a distance in excess of 1,000 nm. The CV-22 can provide VTOL with 8,300lb of cargo for 220 nm. Obviously you aren't going to move as much as fast using CV-22 vs C-2. Let's assume for the moment that the V-22 can handle COD and radar missions. Then you are stuck with the tanker problem and three choices: 1) Use the V-22 as a tanker. r) Odds on bet the V-22 is too slow. 2) Buddy store off a F-35B. r) Yea, that would make buddy storing off F-18s look positively lovely. How much passable gas could you actually get off the deck? 3) Call the Air Force. r) Left as an exercise for the reader. than later. The slow pace of VSTOL development slowed things down, especially the support a/c requirement (ASW, AEW, COD, tanker, ESM, SOJ, CSAR, what have you), as only now is an a/c (the V-22) with roughly the required performance, in view. It is inferior in performance for each specific mission than the more specialized individual aircraft types that now perform these functions, but the ability to use a single basic airframe for all these missions means big savings on training, spares and unit cost. |
John Keeney wrote:
"Guy Alcala" wrote in message . .. John Keeney wrote: snip Because the F-35C flies farther with a bigger load than the F-35B. As always, the question is how much do you need that extra range, and should the navy a/c do that mission when it is needed? Kind of depends how you define the I want to see the carriers able to hit Afganistan from the Indian Ocean and a few other places that might be a tad less accessible. Call it the "anywhere in the second country in from the beach" rule. The question is, how often is that second country in more than X nm from the beach. Should we plan our military around a single third-world country? Justify why we need to meet your want. You know, what the people who make these decisions have to do, as opposed to the likes of us who are free to spout our pet theories on Usenet;-) Actually, hitting Afghanistan up at least as far north as Kandahar and maybe up to Kabul from 50-80nm offshore would be possible by unrefueled F-35Bs (assuming they meet their range requirement), and the rest of the country if you tank them. littorals -- you can see claims and studies made for everything from 200nm to 650nm from the coastline, depending on whose ox is being gored -- here's one that discusses this issue, and decides based on historical evidence that 400nm is about right, and that the STOVL JSF is more than adequate for all three services: http://handle.dtic.mil/100.2/ADA331611 I tried to look, but I became too impatient and gave up on the down load. The devil IS in the details, and if you want to discuss them, you've got to know the issues, assumptions and proposed strategy. Note, while you'd expect this to be a USMC paper, it was actually written at ACSC. Still, there were definitely Marines involved in writing it, so take the analysis and conclusions with as large or as small a grain of salt as you think appropriate. Because the ships aren't going away since they need the deck for the E-2 and C-2 anyway. Of course, when (if) the V-22 or some similar VSTOL support a/c enters service, that particular justification need no longer exist. Putting a spinning top on a V-22 sounds scary to me, have to be plum tall to see over those rotors. Might do an EV-22 with a phased array. That was the proposed method; initial idea was to use a triangular radome on top with a three-face phased array. Later there seemed to be some interest in a spine-mounted array like the Erieye, or a ventral folding array. The V-22 has a lower ceiling and no pressurized cabin, although it may be possible to insert a pressurized module into it (kind of like RB-52s had). Or alternatively, everyone will just have to wear oxygen masks. The other possiblity would be to develop a new fuselage with the powerplants etc. the same, kind of like the E-2/C-2 did. As for the COD role: the C-2 does 10,000 pounds over a distance in excess of 1,000 nm. Not according to the C-2A S.A.C. (available on the Naval Historical Center website). Range with a 10,000 lb. load is 961nm, with reserves. The CV-22 can provide VTOL with 8,300lb of cargo for 220 nm. Why on earth would a V-22 COD make a VTO? It will make a STO or full rolling takeoff from shore, a STO from a carrier or LHD/LHA, and only make a VTO from a LPD/LSD/AOE. A C-2 can only land on the carrier and has to tranship loads to a helo for the latter ships (and hope that the helos are in range), while a V-22 can go direct to them. Obviously you aren't going to move as much as fast using CV-22 vs C-2. That remains to be seen. Empty and MTOW weights of the C-2 and MV-22 are in the same league: 33,746/54,354 for the C-2, and 33,140/57,000 (STO)/60,500 (max.) for the MV-22, and the latter is carrying around self-sealing tanks and armor that the former isn't, and doesn't need to maintain the same reserve fuel. The MV-22 currently lacks a pressurized cabin, which might or might not be significant when carrying passengers, depending on the range, weather and cruise altitude. It's cabin is also slightly smaller than the C-2's, which again, may or may not be significant. Let's assume for the moment that the V-22 can handle COD and radar missions. Then you are stuck with the tanker problem and three choices: 1) Use the V-22 as a tanker. r) Odds on bet the V-22 is too slow. Too slow for the escort tanking job, certainly, so that will remain with buddy tankers (or, down the road, a STOVL support jet). I asked Cecil Turner about this a year or two ago, as he'd refueled in his A-4 and AV-8B from various a/c. Based on published stats, a KV-22 should be able to tank strikers at least up to 15,000 feet, which he said was a typical tanking altitude, and maybe 18-20,000 (the latter would probably require a toboggan). As for recovery tankers, if the navy goes all STOVL there will be far less need for them because wave-offs due to fouled decks will become a thing of the past, as will bolters, and the incidence of missed approaches due to low visibility will shrink to almost nothing. A KV-22 will certainly be lower in performance than the current S-3s; the question is how critical is that performance to the mission. 2) Buddy store off a F-35B. r) Yea, that would make buddy storing off F-18s look positively lovely. How much passable gas could you actually get off the deck? Considering that the F-35B is credited with equal or greater range than the F-18E/F on slightly less internal fuel, has only one engine, lots of wet external pylons and no need to hold large landing fuel reserves, I imagine the answer is a comparable amount. 3) Call the Air Force. As the navy has been doing in every one of our recent conflicts. Or the RAF, or the Dutch, or the Italians, French, Australians, Japanese, Germans . . . Guy |
"John Keeney" wrote in message ...
"Guy Alcala" wrote in message . .. John Keeney wrote: "puttster" wrote in message om... "John Carrier" wrote in message ... Now if you want to argue that the F-35B is an aircraft designed as a Carrier Aircraft, I know some Marines that would like to chat with you. The B will be replacing AV-8B's and land based F-18's. Sure, it can land on a carrier but it is not being built to trap aboard CV/N's using arresting gear or Cat launches. True in a sense, but as a VSTOL and STOVL design, it's fully carrier suitable w/o the need for catapult gear (I suspect it does have a tailhook). I'd also be much surprised if its CNI suite didn't include ACLS and SPN-41 in their latest incarnations. R / John With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? Because the F-35C flies farther with a bigger load than the F-35B. As always, the question is how much do you need that extra range, and should the navy a/c do that mission when it is needed? Kind of depends how you define the I want to see the carriers able to hit Afganistan from the Indian Ocean and a few other places that might be a tad less accessible. Call it the "anywhere in the second country in from the beach" rule. Here is the math fails. If the Marine F-35B's have a range of 450 miles and the Navy's F-35C's have a range of 700 miles, how are the marines going to set up at points inaccessible by the Navy? Besides, how will they get resupplied? |
![]() "puttster" wrote in message om... "John Keeney" wrote in message ... "Guy Alcala" wrote in message . .. John Keeney wrote: "puttster" wrote in message om... "John Carrier" wrote in message ... Now if you want to argue that the F-35B is an aircraft designed as a Carrier Aircraft, I know some Marines that would like to chat with you. The B will be replacing AV-8B's and land based F-18's. Sure, it can land on a carrier but it is not being built to trap aboard CV/N's using arresting gear or Cat launches. True in a sense, but as a VSTOL and STOVL design, it's fully carrier suitable w/o the need for catapult gear (I suspect it does have a tailhook). I'd also be much surprised if its CNI suite didn't include ACLS and SPN-41 in their latest incarnations. R / John With an excellent V/STOL capability in the F-35B, why does the Navy still demand those giant carriers? Seems like something can be done there to make the whole system more efficient. Why design a plane (the F-35C) to fit their ships? Because the F-35C flies farther with a bigger load than the F-35B. As always, the question is how much do you need that extra range, and should the navy a/c do that mission when it is needed? Kind of depends how you define the I want to see the carriers able to hit Afganistan from the Indian Ocean and a few other places that might be a tad less accessible. Call it the "anywhere in the second country in from the beach" rule. Here is the math fails. If the Marine F-35B's have a range of 450 miles and the Navy's F-35C's have a range of 700 miles, how are the marines going to set up at points inaccessible by the Navy? Besides, how will they get resupplied? By air, like they did in Afghanistan, *before* major airfields were available for use IIRC. Unless Afghanistan has been moved to where it *is* accessable by the Navy? Brooks Brooks |
"C-175 SoCal Beware" Original Poster Replies | Bill Berle | Aviation Marketplace | 8 | July 8th 04 07:01 AM |
More LED's | Veeduber | Home Built | 19 | June 9th 04 10:07 PM |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
