HP series landing gear info needed
Old September 23rd 11, 01:20 AM posted to rec.aviation.soaring
T8
Default HP series landing gear info needed
On Sep 22, 6:29*pm, Bob Kuykendall wrote:
It's easy to know when its set up right;
when the system is assembled sans O-rings the pistons slide in and out
of the cylinders with no appreciable drag.
My ship would have failed that test. By the time I'd noticed this (I
was the third owner), the damage to the oleo cylinder was done and I
didn't really have a clue as to how about putting it right. It's
awfully hard to make holes that are in the wrong place go away so you
can start over.
-Evan Ludeman / T8
Old September 22nd 11, 09:03 PM posted to rec.aviation.soaring
Brad
Take a look at how the thing is built. Ask yourself what prevents
metal/metal contact in the cylinder bore. In my case I think the
piston (the very end, just past the o-ring groove) is what chewed up
the cylinder bores. I remember trying to use a brake cylinder hone to
clean things up. It might have helped a little. My ship may have had
some gear alignment issues that pushed it over the edge. Obviously,
it worked fairly well for others. I've seen other HPs with flat
struts over the years. If I were doing it over again, I really would
weld the sucker (make certain you get the alignment exactly right).
Who needs a shock strut when you land at 30 mph?
Brad,
You keep the dirt out with a set of BMX bike fork bellows.
The oil is Honda SS-7 5W.
Android Usenet Reader
http://android.newsgroupstats.hk
Old September 22nd 11, 09:31 PM posted to rec.aviation.soaring
On Sep 22, 2:54Â*pm, Brad wrote:
On Sep 22, 11:41Â*am, T8
For those involved in this discussion they should be reminded that the landing gear in question is being installed in an HP-24 which has spoilers, NOT large span landing flaps.
Old September 22nd 11, 10:27 PM posted to rec.aviation.soaring
jim wynhoff
On Sep 22, 1:31*pm, "Wayne Paul " wrote:
On Sep 22, 2:54*pm, Brad wrote:
On Sep 22, 11:41*am, T8
Android Usenet Readerhttp://android.newsgroupstats.hk
Still, the struts on the few HP's I've helped work on are fine after
decades of use. Brad will be landing at a higher ground speed than an
'18, but I don't see how that dictates rougher landings. My glider
has a smaller mainwheel and ZERO suspension. Once or twice (maybe
more!) I've thought some suspension would be nice!
Cheers,
Old September 23rd 11, 12:33 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Landing in a rough field makes a pilot appreciate a suspension on the
landing gear. Landing faster in rough field makes a pilot REALLY
appreciate a suspension on the landing gear. A well done suspension can
reduce injury some crash situations, but I don't know if the gear in
question was designed to do that.
email me)
Old September 23rd 11, 05:22 PM posted to rec.aviation.soaring
Brian[_1_]
email me)
My understanding is that Dick having survived a few crashes was a big
believer and building strong crash worthy aircraft.
This was one of the reasons that nearly all of his designs had the
Oleo Strut Landing Gear.
I am sure it saved him from further injury in some of his adventures.
I have done at least one landing where I was very glad to have it.
Brian
Gear up series - what happened?? Terry M[_3_] Aviation Photos 1 April 19th 07 03:35 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 05:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
Info needed for SH3 Gralmk Naval Aviation 7 March 24th 04 07:18 AM
Wanted- 20 series Learjet main landing gear DANIEL R. KARSHIN Aviation Marketplace 0 July 28th 03 04:55 PM
