![]() "John R Weiss" wrote in message news:j1f%b.60182$4o.83386@attbi_s52... "Tarver Engineering" wrote... According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Just prior to the pilot adding go-around power, the airplane was in an aerodynamic regime that had been encountered many times previously -- airspeed between stall and Vref, with a slight rate of descent (approx 375 fpm, from last datapoint), engines at idle. How could it be that the flight control system was "unmapped" in that aerodynamic regime?!? That is a good question. I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. Then you have departed from reality. |
What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Hmmm... I suspect that when the pilot added go-around power, he commanded the airplane to provide maximum lift/minimum sink while the engines spooled up. As far as we can tell, the flight control system responded properly, providing max lift without stalling. It is not the job of the flight control system to map trees, but the trees in the flight path interrupted the plan... I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. Then you have departed from reality. I see... Now you imply that either the A-320 certification did NOT include slow flight and approaches to stalls, or that it was certified despite its failure to demonstrate the required controllability in those regimes. Anyone have the coordinates of reality? I need to punch them into the FMS-CDU tomorrow... |
![]() "John R Weiss" wrote in message news:AFp%b.402349$I06.4378804@attbi_s01... "Tarver Engineering" wrote... What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Hmmm... I suspect that when the pilot added go-around power, he commanded the airplane to provide maximum lift/minimum sink while the engines spooled up. In what wy do you believe that stalling the wing is within the flight envelope? |
Airbus hadn't programmed their A-320 to do what the operator commanded. Hmmm... I suspect that when the pilot added go-around power, he commanded the airplane to provide maximum lift/minimum sink while the engines spooled up. In what wy do you believe that stalling the wing is within the flight envelope? In what way do you believe stalling the wing had anything to do with the late go-around attempt? What flight envelope? |
"Tarver Engineering" wrote in message ...
"John R Weiss" wrote in message news:AFp%b.402349$I06.4378804@attbi_s01... "Tarver Engineering" wrote... What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Hmmm... I suspect that when the pilot added go-around power, he commanded the airplane to provide maximum lift/minimum sink while the engines spooled up. In what wy do you believe that stalling the wing is within the flight envelope? how did it stall ? |
"Tarver Engineering" wrote:
"John R Weiss" wrote in message news:j1f%b.60182$4o.83386@attbi_s52... "Tarver Engineering" wrote... According to the ASN Accident Description, "Go-around power was added at 14.45:35" The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. What is "an unmapped part of the A-320's flight control system" supposed to mean?!? Airbus hadn't programmed their A-320 to do what the operator commanded. Just prior to the pilot adding go-around power, the airplane was in an aerodynamic regime that had been encountered many times previously -- airspeed between stall and Vref, with a slight rate of descent (approx 375 fpm, from last datapoint), engines at idle. How could it be that the flight control system was "unmapped" in that aerodynamic regime?!? That is a good question. I am quite certain that the A-320's certification included slow flight and approaches to stalls, and that its flight control system is well able to handle them. Then you have departed from reality. Jesus Christ John, this is ridiculous...I've read a lot about this accident and agree with the consensus that the a/c did all any a/c could have done given the parameters this not too bright bulb asked it to do. How in hell could the system have done more than, as JW explained, hold the AoA at the max lift point just short of stall while the autothrottle system applied max power and everyone was waiting with bated breath for the engines to spool up. Would you have preferred that the pilot have been able to manhandle the AoA higher almost certainly stalling the wings?. Maybe if you were a magician like Marron you could have changed the Angle of Incidence therefore giving the wings 'more lift'?... snort -- -Gord. |
![]() "Gord Beaman" wrote in message news ![]() Then you have departed from reality. Jesus Christ John, this is ridiculous...I've read a lot about this accident and agree with the consensus that the a/c did all any a/c could have done given the parameters this not too bright bulb asked it to do. You mean the pilot stalled the wing? Then you are well advanced from Weiss' understanding. How in hell could the system have done more than, as JW explained, hold the AoA at the max lift point just short of stall while the autothrottle system applied max power The autothrottle only knows land and go around in the situation we are discussing and the pilot was beyond the point of either flight mode. The operator has to follow the POH, as it is part of the type Certificate. |
The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. bwahahahhahahahhahhahahhhahahhahhahahahahahhahahah ahahahahahahha every ****ing aircraft goes past the end of a runway. its called takeoff |
running with scissors wrote:
every ****ing aircraft goes past the end of a runway. its called takeoff Heh. The high-performance types often don't cross the far-end threshold during takeoff. I remember one time 10,000 feet over Sherman field, looking straight down at the midpoint... -- John Miller Email address: domain, n4vu.com; username, jsm I have ways of making money that you know nothing of. -John D. Rockefeller |
John Miller wrote in message ...
running with scissors wrote: every ****ing aircraft goes past the end of a runway. its called takeoff Heh. The high-performance types often don't cross the far-end threshold during takeoff. I remember one time 10,000 feet over Sherman field, looking straight down at the midpoint... ahh but in tarverworld past the end the runway is an unmapped part of the A-320's flight control system. |
"C-175 SoCal Beware" Original Poster Replies | Bill Berle | Aviation Marketplace | 8 | July 8th 04 07:01 AM |
More LED's | Veeduber | Home Built | 19 | June 9th 04 10:07 PM |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
