On Fri, 28 Oct 2011 10:55:24 -0700, JohnDeRosa wrote:
It would appear that "Spin Clip 2" is a candidate for what might have occured at Cle Elum. "Spin Clip 1" is a cockpit view which is especially chilling. Both show what we are exhaustively trained against: assuming that you're OK once you've pushed over to a normal gliding attitude. You're not of course, because you'll be too slow and, unless you reacted IMMEDIATELY and got the stick far enough forward for a zero G push-over you'll be below stall speed, from where any turn will spin immediately. The rule of thumb[*] is to push over until your dive attitude is as steep as you were going up and then hold the attitude without attempting to turn until you've reached the landing approach speed you'd chosen for the day. Then, and only then you decide whether you've space to land ahead or whether you need to turn. [*] unless, of course, its a low break where you'd become a lawn dart if you used the above technique. Off a winch you'll always have plenty of specs ahead, so a shallower recovery attitude is OK once you're combortable above stall speed and anyway you won't need to turn. Sadly, I think Steve Leonard has probably called this about right. IMO whether the rope broke or not isn't relevant, but the fact that no witnesses reported an immediate push-over into a speed recovery attitude is. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Final NTSB report on Fossett crash | danlj | Soaring | 0 | July 10th 09 06:32 AM |
NTSB Factual Walton Crash | ChuckSlusarczyk | Home Built | 29 | September 5th 06 06:59 PM |
NTSB Preliminary report on HPN crash | Peter R. | Instrument Flight Rules | 83 | May 10th 05 08:37 PM |
Hendricks Crash- NTSB Prelim | C Kingsbury | Instrument Flight Rules | 10 | November 14th 04 02:18 AM |
NTSB: Co-pilot error caused AA 587 crash | Bertie the Bunyip | Piloting | 4 | November 3rd 04 04:30 AM |
