Who is responsible for the USA "Club Class" list that BB linked?
The max weight they show for the LS1-B/C/F is incorrect. The weight of 772 lbs is most likely for the "F" model. My glider was built as a "C" then granted to become a "D" via a letter from LS back in the good ol' days. The max weight was increased, again only by letter and not by any physical change in the glider, to 752 lbs to allow for water ballast. The B and C probably have lower max weights. And why is the "D" model not listed? Thanks, Ray Lovinggood |
On Dec 20, 12:30*pm, Tony wrote:
On Dec 20, 1:14*pm, "kirk.stant" wrote: On Dec 20, 10:25*am, Tony wrote: It was my impression that the tasking at the regional i went to was satisfactory to everyone involved. *The circles were large thanks to gliders ranging from my Cherokee to Dave Coggins' Nimbus. *If a pilot felt we weren't flying far enough each day it was his own fault, IMO. The weather was very consistent throughout the entire region which definitely helped. My experience is a very small slice of the contest world though, so I'm rather pollyanna-ish about the subject. Tony, it is fundamentally impossible to create a fair, challenging race (not organized timed XC) task when the range of gliders is Cherokee to Nimbus. *Sure, you can throw out a short AAT with huge turn areas and send them out - but that isn't racing! I've got nothing agains the lower performance gliders - but I've CD'd enough ASA contests to appreciate how hard it is to make challenging tasks without stooping to the "fits-all" AAT. The point is - get as many gliders as possible together at the same time, sort them into similar performance groups, then task accordingly. *What is so hard about that? *It's already done with FAI classes! *Then we can see the return of the speed task, and put AATs back where they belong - as weather option *tasks! I am looking forward to the day I can get a club class glider though. In the meantime I will have a lot of fun flying sports class in my Cherokee. Looking forward to racing with you! Cheers, Kirk "I do like the idea of separating gliders by handicap range instead of wingspan as has become an option in the last few years." The above is really descriptive of where we are at now, in regards to handicap racing in the USA. There is another option for handicap racing in the US. The existing four main FAI classes flown in the USA are really classes formed by handicaps already, handicaps defined by performance, dictated by flaps and wingspan, categorized into their perspective class. It would not be a large conceptual leap to form classes dictated by performance, regardless of flaps, age and wingspan. Instead of Std., 15 meter, 18 meter and Open, divide the encompassing fleet into three classes. This would allow more pilots to compete. This is really a logical step, considering the fairly low number of sailplanes and pilots, racing now. I think both the Std and Open Class Nationals, last year, had 16 pilots each, including guests. There were 14 pilots in the 18 meter class. Allowing older sailplanes to compete in these existing classes, with handicaps, would probably improve attendance. We have gradually grown into a "caste" system of sailplane racing and the resulting effort to keep the classes pure (handicap wise), has brought us to the lower numbers racing in FAI and the emergence of Sports and Club Class. If the resistance to adding another class is really because of the ever dwindling number of racing pilots and sailplanes in the existing classes, maybe handicapping the existing classes, that were initially formed due to their handicaps, will vitalize class racing again. Just a thought. Mike 66 Kirk, now I understand better. *I didn't realize you were focused on assigned tasks instead of TAT's. *Agree that with a wide range of handicaps the assigned task is impossible to task fairly, which I suppose is why it isn't used in the sports class. I do like the idea of separating gliders by handicap range instead of wingspan as has become an option in the last few years. *If Moriarty would run a low/medium/high performance contest instead of just medium/ high i would probably go. only problem is i might be the only one there. |
On Dec 20, 5:12*am, "kirk.stant" wrote:
This whole Sports Class vs Club Class argument is absurd. There are FUNDAMENTAL differences between the intent of the two classes: Sports is meant to be a "beginners" class. *Thus the shorter, simpler (?) tasking, and letting any glider that shows up compete. *OK in theory, except when you end up with a Blanik racing a Nimbus 4DM...but if both pilots are beginners to racing, then it kinda works. Club class is meant to be a serious racing class for pilots who don't have the latest FAI gliders, but still wand serious competition with challenging tasks. There is a need for both; the Arizona Soaring Association addresses this with 3 level of tasks when necessary, so that the task difficulty better matches the glider performance and pilot skill of the competitors. I personally will not compete in a Sports Class contest unless it is held in my back yard. *I will travel to a Club/Modern contest (planning on attending Moriarty again this June - CH are you in?). *I will also go to 15M regionals or even the Nationals if possible, even if my LS6 is not quite as competitive as the latest V2s and 29s, because I enjoy a challenging race. My suggestion? Combine Club/Modern with Std/15 regionals, with slightly shorter tasks for the Club/Modern. *Bigger field, bigger contests, more fun. *Ditto Sports/Club; same venue and contest management, different tasks/scoresheets. Kirk 66 A quick phone call to AVEMCO revealed "they have been getting quite a few calls this morning concernong the 100,000.00 limit. I was told the 1,000,000.00 limit would increase my liability only coverage from $252.00 to $450.00. What is Costello charging for liability only? JJ |
On Dec 20, 8:23*am, JJ Sinclair wrote:
On Dec 20, 5:12*am, "kirk.stant" wrote: This whole Sports Class vs Club Class argument is absurd. There are FUNDAMENTAL differences between the intent of the two classes: Sports is meant to be a "beginners" class. *Thus the shorter, simpler (?) tasking, and letting any glider that shows up compete. *OK in theory, except when you end up with a Blanik racing a Nimbus 4DM...but if both pilots are beginners to racing, then it kinda works. Club class is meant to be a serious racing class for pilots who don't have the latest FAI gliders, but still wand serious competition with challenging tasks. There is a need for both; the Arizona Soaring Association addresses this with 3 level of tasks when necessary, so that the task difficulty better matches the glider performance and pilot skill of the competitors. I personally will not compete in a Sports Class contest unless it is held in my back yard. *I will travel to a Club/Modern contest (planning on attending Moriarty again this June - CH are you in?). *I will also go to 15M regionals or even the Nationals if possible, even if my LS6 is not quite as competitive as the latest V2s and 29s, because I enjoy a challenging race. My suggestion? Combine Club/Modern with Std/15 regionals, with slightly shorter tasks for the Club/Modern. *Bigger field, bigger contests, more fun. *Ditto Sports/Club; same venue and contest management, different tasks/scoresheets. Kirk 66 A quick phone call to AVEMCO revealed "they have been getting quite a few calls this morning concernong the 100,000.00 limit. I was told the 1,000,000.00 limit would increase my liability only coverage from $252.00 to $450.00. What is Costello charging for liability only? JJ- Hide quoted text - - Show quoted text - I didn't see any motor-gliders on the Club Class list. If so, you guys just got my attention. JJ |
Club Class - Class growth - progression - Have we seen any? | hotelalpha | Soaring | 11 | December 18th 11 09:43 PM |
Potential Club Class (US Sports Class) World Team Selection Policy Changes | John Godfrey (QT)[_2_] | Soaring | 84 | September 27th 10 08:03 PM |
Potential Club Class (US Sports Class) World Team SelectionPolicy Changes | JS | Soaring | 4 | September 22nd 10 04:55 PM |
Potential Club Class (US Sports Class) World Team SelectionPolicy Changes | Andy[_10_] | Soaring | 0 | September 19th 10 10:33 PM |
UK Open Class and Club Class Nationals - Lasham | Steve Dutton | Soaring | 0 | August 6th 03 10:07 PM |
