![]() "Scott Ferrin" wrote in message ... Agreed. I wasn't putting this forward as something that is likely to happen, just what might happen if the Raptor program was terminated. Yeah, I figured as much, which is why I pointed out the big conditional "if" in your post; not sure Scott caught that. Yeah I got it. I think I was overwhelmed by the spots in front of my eyes and the onset of tunnel vision at the thought of "cancelled F-22". I just don't see how we could maintain the degree of superiority we've enjoyed without it. IT probably wouldn't be the disaster that I see it being but it's dismaying to see so many cutting edge programs cancelled and the idea of hoping the F-35 would be far superior to the latest Chinese Flankers. . .well my money wouldn't be on it. Some of the cutting edge programs, like Commanche and Crusader, *deserved* to be cut. Toss the old Navy A-12 Avenger program ionto that same hopper, along with the Seawolf SSN; if the USAF had been successful in killing Have Nap ca couple of years ago when they wanted to, it would have fit in there as well. As to the F-22 (Roche's belated addition of "A" being little more than a sop to congress), yeah, we should produce enough of them to be our silver bullet, but unless it is developed to be a better striker as well, the 200 number look quite sufficient. Are you really worried about Chinese Flankers? With no effective AWACS support for them, and precious little tanking support? Not to mention the questionable quality of pilot training? I suspect you're right that the F/A-22 will be built in limited numbers, though I woudl also not be surprised to see produciton continue after the intial batch is bought. We've bought far more F-15s than originally planned, after all. IIRC the original number for F-15s was 729 and F-16s was 1388 or thereabouts. Both were far exceeded. I think it's just going to depend on how the F-22 does in service. If they can get the kinks worked out it wouldn't surprise me if they found a way to buy more beyond the cost cap. The only way I see that happening is if they optimize a strike version. The potential threats we face today are vastly different from what we faced when we built that fleet of F-15's. I'm not entirely convinced about the FB-22 or other strike-optimized version. It would have to have a lot of range to justify not simply using an F-35 derivative, IMO. Again, a possible variant comes to mind: A hybrid with the F-35A fuselage and the F-35C big wing ought to yield even more range than the 700+nm radius of the C version. ISTR that being discussed here before. I'd have thought the USAF would jump on that too but I guess not. It was discussed before. Again, the only reason I can see for *not* doing that would be a bit less maneuverability with the larger wings. I don't know. I see the FB-22, or something similar, offering a couple of advantages; it provides a solution to the "what do we use to start replacing the Mudhen in 2015-2020" problem, and it could bring down the unit cost for a reduced F/A-22 buy as long as significant commonality remains. Just from what they've shown so far it doesn't see like there would be a significant amount. Maybe the forward fuselage. The FB-22 as they've showed around has different intakes, would use different engines, completely different wing, long weapon bays, different landing gear, etc. etc. I am not sure the FB-22 as originally sketched would be the same as what we could end up buying. In the end we could very well see a "steroidal" version of the existing F/A-22, with larger wings and a fuselage plug to accomodate a larger weapons bay that handles maybe an additional 50% increase in carriage capacity for something like the SDB. Changing to a different engine, while requiring some work, is not truly a major change as far as the overall program would be concerned--witness the past engine changes within both the F-15 and F-16 fleets. And maybe space for a second crewmember...? (gasp!) Brooks |
![]() Some of the cutting edge programs, like Commanche and Crusader, *deserved* to be cut. Toss the old Navy A-12 Avenger program ionto that same hopper, along with the Seawolf SSN; if the USAF had been successful in killing Have Nap ca couple of years ago when they wanted to, it would have fit in there as well. I agree. As to the F-22 (Roche's belated addition of "A" being little more than a sop to congress), yeah, we should produce enough of them to be our silver bullet, but unless it is developed to be a better striker as well, the 200 number look quite sufficient. Are you really worried about Chinese Flankers? With no effective AWACS support for them, and precious little tanking support? Not to mention the questionable quality of pilot training? If all I had was F-35s? Yep. In a China / Taiwan scenario the Flankers wouldn't NEED tanking. As far a pilot quality goes all it would take is for someone over there to determine that they NEED top of the line pilots and in a few years they could have them. Look what the USN did with Top Gun during the Vietnam war. I don't doubt that in the end we'd still win, but at what cost? We want it to stay as close to zero loses as possible. I suspect you're right that the F/A-22 will be built in limited numbers, though I woudl also not be surprised to see produciton continue after the intial batch is bought. We've bought far more F-15s than originally planned, after all. IIRC the original number for F-15s was 729 and F-16s was 1388 or thereabouts. Both were far exceeded. I think it's just going to depend on how the F-22 does in service. If they can get the kinks worked out it wouldn't surprise me if they found a way to buy more beyond the cost cap. The only way I see that happening is if they optimize a strike version. The potential threats we face today are vastly different from what we faced when we built that fleet of F-15's. I agree. On the other hand China has close to 300 Flankers and counting, have intriduce the AA-12 into service, and are working on acquiring the J-10. I have no doubts that Russia would offer the KS-172 to China if they asked. I wouldn't want to face a Su-30 with THAT thing in an F-15. Again, I'm not saying it's impossible I'm just saying that the cost in pilots and airframes lost would be higher. This is a rhetorical question but is it worth losing F-15s, F-35s, and their pilots to save a few bucks by not buying the F-22? I'm not entirely convinced about the FB-22 or other strike-optimized version. It would have to have a lot of range to justify not simply using an F-35 derivative, IMO. Again, a possible variant comes to mind: A hybrid with the F-35A fuselage and the F-35C big wing ought to yield even more range than the 700+nm radius of the C version. ISTR that being discussed here before. I'd have thought the USAF would jump on that too but I guess not. It was discussed before. Again, the only reason I can see for *not* doing that would be a bit less maneuverability with the larger wings. I don't know. I see the FB-22, or something similar, offering a couple of advantages; it provides a solution to the "what do we use to start replacing the Mudhen in 2015-2020" problem, and it could bring down the unit cost for a reduced F/A-22 buy as long as significant commonality remains. Just from what they've shown so far it doesn't see like there would be a significant amount. Maybe the forward fuselage. The FB-22 as they've showed around has different intakes, would use different engines, completely different wing, long weapon bays, different landing gear, etc. etc. I am not sure the FB-22 as originally sketched would be the same as what we could end up buying. In the end we could very well see a "steroidal" version of the existing F/A-22, with larger wings and a fuselage plug to accomodate a larger weapons bay that handles maybe an additional 50% increase in carriage capacity for something like the SDB. Something more like what they did with the F-15E than the drastic changes GD offered witht he F-16XL? It would certainly shave $$$ off the proposal, not to mention retain more of it's air-to-air capability. Changing to a different engine, while requiring some work, is not truly a major change as far as the overall program would be concerned--witness the past engine changes within both the F-15 and F-16 fleets. And maybe space for a second crewmember...? (gasp!) Yeah, it had a second seat too. |
![]() "Scott Ferrin" wrote in message ... I agree. On the other hand China has close to 300 Flankers and counting, have intriduce the AA-12 into service, and are working on acquiring the J-10. I have no doubts that Russia would offer the KS-172 to China if they asked. I wouldn't want to face a Su-30 with THAT thing in an F-15. Again, I'm not saying it's impossible I'm just saying that the cost in pilots and airframes lost would be higher. This is a rhetorical question but is it worth losing F-15s, F-35s, and their pilots to save a few bucks by not buying the F-22? You make an excellent case for the reliable airborn weapons platform designated F/A-18E. The USAF could do well by tabbing to USN's application of AFRL's parts and software reliability technology. I wonder if the pirates at China Lake could make the F/A-18x weapons data port USAF compatable rapidly. |
![]() "Scott Ferrin" wrote in message ... ,snip agreeable type stuff As to the F-22 (Roche's belated addition of "A" being little more than a sop to congress), yeah, we should produce enough of them to be our silver bullet, but unless it is developed to be a better striker as well, the 200 number look quite sufficient. Are you really worried about Chinese Flankers? With no effective AWACS support for them, and precious little tanking support? Not to mention the questionable quality of pilot training? If all I had was F-35s? Yep. In a China / Taiwan scenario the Flankers wouldn't NEED tanking. Begging the question of how much value *any* of the landbased tactical fighters would be in such a scenario--I don't see us likely to base fighters on Taiwan proper. That places under the the gun of the complete threat envelope, including TBM's, cruise missiles, SOF attack, etc. IMO the China scenario, as *unlikely* as it is to actually materialize, is a place where the truly long range strike assets, in cooperation with the air wings from the USN CVBG's and Tactical Tomahawks launched from CG's and SSN's, would be the primary players. Plus, your Flankers are still without good C4ISR support from AWACS. As far a pilot quality goes all it would take is for someone over there to determine that they NEED top of the line pilots and in a few years they could have them. I believe you are minimizing the requirements to solve that problem. They would have to finally completely do away with their "mass is the answer" approach (they have admittedly made progress in that direction, but they are not there yet, and won't be in the immediate future), and they have a problem with their basic foundation (i.e., tactics/techniques/procedures, qualified instructors and doctrinal developers, and last but not least, the PLA's historical mistrust of individual initiative). That is a lot to have to contend with before they even *start* developing a world class fighter force. Look what the USN did with Top Gun during the Vietnam war. I don't doubt that in the end we'd still win, but at what cost? We want it to stay as close to zero loses as possible. The USN had one heck of a foundation to start out with--the PLAAF does not. I suspect you're right that the F/A-22 will be built in limited numbers, though I woudl also not be surprised to see produciton continue after the intial batch is bought. We've bought far more F-15s than originally planned, after all. IIRC the original number for F-15s was 729 and F-16s was 1388 or thereabouts. Both were far exceeded. I think it's just going to depend on how the F-22 does in service. If they can get the kinks worked out it wouldn't surprise me if they found a way to buy more beyond the cost cap. The only way I see that happening is if they optimize a strike version. The potential threats we face today are vastly different from what we faced when we built that fleet of F-15's. I agree. On the other hand China has close to 300 Flankers and counting, have intriduce the AA-12 into service, and are working on acquiring the J-10. I have no doubts that Russia would offer the KS-172 to China if they asked. I wouldn't want to face a Su-30 with THAT thing in an F-15. Again, I'm not saying it's impossible I'm just saying that the cost in pilots and airframes lost would be higher. This is a rhetorical question but is it worth losing F-15s, F-35s, and their pilots to save a few bucks by not buying the F-22? Or, is it worth buying *more* F-22's than we really need to ensure against a rather remote threat set, while other critical needs go unfilled? the budget is not completely elastic--and it appears that it is not going to have the largesse we have seen the last couople of years for all that much longer. How many ground troopies are likely to die in *other*, more likely scenarios, because we still lack a decent mounted breaching system for minefields? How many more convoy participants lost to off-route mines because we don't commit enough money to developing countermeasures against that threat? Or, how many strike missions get cancelled because the tanker force continues to decline? Ya gotta rob from Peter to pay Paul, and anything more than the absolute minimal F-22 buy makes a pretty goof Peter IMO. snip I don't know. I see the FB-22, or something similar, offering a couple of advantages; it provides a solution to the "what do we use to start replacing the Mudhen in 2015-2020" problem, and it could bring down the unit cost for a reduced F/A-22 buy as long as significant commonality remains. Just from what they've shown so far it doesn't see like there would be a significant amount. Maybe the forward fuselage. The FB-22 as they've showed around has different intakes, would use different engines, completely different wing, long weapon bays, different landing gear, etc. etc. I am not sure the FB-22 as originally sketched would be the same as what we could end up buying. In the end we could very well see a "steroidal" version of the existing F/A-22, with larger wings and a fuselage plug to accomodate a larger weapons bay that handles maybe an additional 50% increase in carriage capacity for something like the SDB. Something more like what they did with the F-15E than the drastic changes GD offered witht he F-16XL? It would certainly shave $$$ off the proposal, not to mention retain more of it's air-to-air capability. Yeah, good analogy. Brooks Changing to a different engine, while requiring some work, is not truly a major change as far as the overall program would be concerned--witness the past engine changes within both the F-15 and F-16 fleets. And maybe space for a second crewmember...? (gasp!) Yeah, it had a second seat too. |
Scott Ferrin wrote:
If all I had was F-35s? Yep. In a China / Taiwan scenario the Flankers wouldn't NEED tanking. As far a pilot quality goes all it would take is for someone over there to determine that they NEED top of the line pilots and in a few years they could have them. Look what the USN did with Top Gun during the Vietnam war. I don't doubt that in the end we'd still win, but at what cost? We want it to stay as close to zero loses as possible. Can you please list all of the air bases the US Air Force has within 600 miles of Taiwan that they can use without needing a permission slip from a foreign government? What if we had a war and the US Air Force didn't show up because their F/A-22s couldn't reach it? Better yet, what if we didn't have a war because the US Navy deterred it? -HJC |
Hi!
"Kevin Brooks" writes: F/A-22 were cancelled". If you do that, then what are you *left* with as a potential air-to-air fighter to replace the F-15C? F-18E? Best regards, -- Titta gärna på http://www.lysator.liu.se/~redin och kommentera min politiska sida. Magnus Redin, Klockaregården 6, 586 44 LINKöPING, SWEDEN Phone: Sweden (0)70 5160046 |
![]() "Magnus Redin" wrote in message ... Hi! "Kevin Brooks" writes: F/A-22 were cancelled". If you do that, then what are you *left* with as a potential air-to-air fighter to replace the F-15C? F-18E? I seriously doubt that. ISTR it has a bit of a range problem, and in the air-to-air environment, the Eagle could probably still best it. Brooks Best regards, -- Titta gärna på http://www.lysator.liu.se/~redin och kommentera min politiska sida. Magnus Redin, Klockaregården 6, 586 44 LINKöPING, SWEDEN Phone: Sweden (0)70 5160046 |
