On Apr 9, 5:11*pm, dbrunone
wrote: Good thought, but the 28300 comes up on the "set altimeter" screen when you first turn it on. Plus, I programmed the local airport into the GPS-NAV already. It would take more than 28,300ft for final glide form NY to Tennessee anyway ;-). -- dbrunone Yep, it needs to go visit Gary. Just for grins, you might try removing the cover, and then carefully slip the boards apart and back together on their connections. Sometimes, they get a little corrosion on them and with the really low currents and voltages, this can cause problems. A little "mechaincal abrasion" sometimes can do the trick. Steve |
Had this happen to my SNav about 2-3 years ago and when I was ready to go
X/c so I was screwed. Another pilot who had previously had the same problem leaned in to the back of the panel, put his hand in near the back of the Snav and give it a thump with the side of his hand. All went back to normal and never had the problem since. Hope this helps. Andy |
I tried this, and it actually worked! Thanks! Hopefully it won't happen again
Quote:
On Apr 7, 6:09*pm, dbrunone
wrote: So I bought a glider with an S-NAV&GPS-NAV not long ago, and I don't really know how to use either. However, when I start up the S-NAV, the unit thinks I am at 28300ft, when actual elevation is 434ft. Obviously, it won't let me adjust the altimeter enough to get the right elevation. On the startup "altimeter" screen, I set the pressure setting to the same as my regular altimeter (29.92 or whatever), but the altitude readout is still way off. Anyone run into this? Is it broken, or am I missing a setting somewhere? -- dbrunone If this is the altitude shown on the initial power up when you see battery voltage, barometric pressure, and altitude, then it needs to go visit Gary at ClearNav. Oh, and you may need to put on your oxygen mask, if you really are that high! ;-) Steve |
Newbie VOR question | Bruce W.1 | Piloting | 15 | April 7th 05 05:15 PM |
newbie question 2 | Billy Who? | Piloting | 9 | December 23rd 04 05:58 AM |
A question only a newbie would ask | Peter Duniho | Piloting | 68 | August 18th 04 11:54 PM |
FS2002 - newbie question | Peter Allison | Simulators | 2 | July 15th 04 05:52 PM |
Newbie question | Bill Gribble | Soaring | 6 | November 6th 03 07:57 PM |
