Instructors: is no combat better?
Old March 10th 04, 08:31 AM
Howard Berkowitz
In article , (Peter
Stickney) wrote:
"Kevin Brooks" writes:
"Howard Berkowitz" wrote in message
Seriously, would anyone care to speculate that if aircraft gunner was
still a tactically useful skill, how much virtual reality simulator
time
(e.g., in at least a 3-axis-of-motion device) would a gunner get
before
going to a combat unit? Aggressor simulators only, or perhaps a few
pilots that have flown the aggressor ship manipulating the target?
I suspect temperature, noise, fumes, etc. would all be part of the
simulator.
Heck, they used "simulators" of a sort like that during WWII. My dad,
who
was a gunner on a B-29, remembers standing in the back of a truck that
drove
along while the trainee took shots at model aircraft.
Somebody from the Film Industry (Might have been Disney) developed a
prejection system using a hemispherical dome with a turret inside.
They had some sort of system to measure tracking errors.
And then, there was Operation Pinball, the ultimate simulator. Real
bombers with real turrets, but the .50 cals have been replaced with
.30 cals firing frangible (break up on impact) bullets. The targets
are specially armored P-63s that make passes on the student gunner's
airplane. There are acoustic sensors in the P-63s that can hear the
impact of the bullets on the skin for measuring the number of hits.
That is _very_ realistic. I think, all in all, we could do it more
cheaply with virtual reality. Operation Pinball could do G-forces
better, although a simulation platform with multiple degree of freedom
movement can get awfully close.
Old March 11th 04, 02:48 PM
Peter Stickney
Howard Berkowitz writes:
In article , (Peter
time
before
simulator.
who
drove
For a bomber-type platform, G forces probably weren't all that
relavant. Not only were the G limits fairly low, but G onset was low
as well. What would be more important would be simulating the
environment of the guys firing manually operated guns, such as the
Waist and Radio Compartment guns on a B-17. There you've got a bunch
of factors that change - the force of teh windblast on the gun barrel,
the narrow field of view, the wind blast, and the intense cold of
standing at an open window in -50 degree air while a 140 mph wind
(EAS) blows past. (What they ended up doing was designing enclosed
gun positions, with power boosted gun mounts. Of course, the
computerized Fire COntrol Systems of the B-29 and later airplanes took
all of that away, with the gunner's skills changing more to mastering
the switchology of the system, and learning how to track smoothly in
Az?El and range. (Which is a lot like patting your head while rubbing
your stomach). When the radar systems came out, in the B-36 and later
bombers, gunnery was even more detached. The gunner detected teh
target on radar, locked the radar on, and followed up the automatic
tracking. That became something that could be done easily on the
ground, or practiced while in the air (Injecting synthetic targets
into the radar system using a signal generator) on regular flights.
Pinball actually stuck around for quite a while. The last SAC gunnery
class to use the RP-63s and frangible bullets was in 1948.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old March 10th 04, 08:01 PM
Jeff Crowell
Wooden bullets, if I recall correctly. An old family friend,
now passed on, experienced some of this.
He said the ballistics of the frangible bullets were so far off
from Real Life (tm) that the usefulness was limited.
Jeff
Old March 10th 04, 11:01 PM
Sunny
"ArtKramr" wrote in message
snip
Actually there was an error between regular rounds and tracer rounds as
well.
On a strafing mission you could aim the tracers and see the ground kick up
well
behind the tracers. Big difference in ballistic coefficient between the
two Aim
the tracers and you would shoot over the target unil you corrected..
Art, that's because of the make up of the tracer round :
Each "tracer round" has a firefly, with 5 years food, packed into the rear
of the round.
The firefly goes into a deep sleep and slowly absorbs the food.
When the round is fired, the shock wakes the fly and his/her arse lights up.
After 5 years, if the round is not fired, the fly dies and the round is
re-classified as Ball.
(it's all in the latest manuals) :-)
Old March 11th 04, 02:59 PM
Peter Stickney
"Jeff Crowell" writes:
Lead dust in a Bakelite matrix, actually. There were .30 caliber
rounds with wooden bullets, though. They were used with some models
of Rifle Grenade Dischargers. Later models of Grenade Dischargers
used blank cartridges to propel teh grenade. (That's one of the
reasons that the M1903 Springfield was retained in the Infantry Squad
until late 1944/early 1945. It was real easy to fire grenade from
it. Garands required a whole lot of fiddling (You had to add & remove
parts from the gas system - not something you want to do in combat)
and you didn't get any better rate of fire, since the blank rounds had
to be manually loaded into the rifle.
Yes, the ballistics were different. But if you're not mixing
ammunition types in the same belt, that's really not all that
important. (And I'm sure that the RP-63 pilots would be a lot happier
if that didn't happen) The sights, and the cams & springs in the
lead-computing sights used at the time Late 1944 on) would be
recalibrated to provide the same sight picture that you'd get with
service ammunition in a .50 cal.
Pete Stickney
Female combat pilot is one strong woman Otis Willie Military Aviation 0 January 22nd 04 02:19 AM
Air Force combat search and rescue joins AFSOC team Otis Willie Military Aviation 0 September 30th 03 09:49 PM
Combat Related Special Compensation update for Sept. 8-12 Otis Willie Military Aviation 0 September 17th 03 03:38 AM
Team evaluates combat identification Otis Willie Military Aviation 0 August 18th 03 08:52 PM
