Ka6E vs. Ka6CR
Old November 26th 14, 05:25 PM posted to rec.aviation.soaring
Dave Martin[_3_]
Default Ka6E vs. Ka6CR
At 11:15 26 November 2014, Eric Munk wrote:
Schleicher's Technical Note No. 10 covers this conversion.
I'm told that late CR's (like my former ship) have the same Wortman
win
as
the E as they were produced simultaneously.
I have been offered flights in K6-E's but always found the cockpit load
much lower on the E than on the CR. From memory under 200 for the
E and over 220for the CR.
Worth checking before you buy.
I flew several CR's and they are a delight.
Dave M
Old November 25th 14, 07:20 PM posted to rec.aviation.soaring
lynn
On Tuesday, May 8, 2012 8:55:13 AM UTC-5, Jeff Casto wrote:
I'm looking to buy a Ka6E but all of the current owners are being stingy
and won't sell. :-( Can anyone give me a comparison b/t a Ka6E and a
Ka6CR?
Also, are there any comparable ships you might consider in lieu of a Ka6E?
Thanks!
Jeff
I have about 100 hours in a K-6e and found it a delight to fly. Jeff, since I know you, I am sure you would easily fit into any version of the K-6. The e-model is nicer looking and slightly better performance. Be aware, all K-6 models require entire canopy removal to enter so in the normal TSA winds you will need to watch it when it is on the ground.
Old November 25th 14, 07:38 PM posted to rec.aviation.soaring
Ka6CR?
Thanks!
Jeff
It is my understanding, from I'm not sure where, that the E, CR, and ASW15 were all in simultaneous production. I'm making the assumption that most of the performance improvement in the E would have been from the airfoil upgrade, not the tail so if my old ship has the Wortmann wing, I'd probably opt for it.
Has anybody seen the CR mod with the fairing from the vertical stab to top of fuselage???
Thanx
JM
ka6CR manual pdf format Stuart Kinnear Soaring 0 March 9th 07 01:14 PM
KA6E and Foka 4 comparable metal ships - Laister Nugget LP15 Matthieu Soaring 18 June 7th 05 01:20 AM
FS - Schleicher Ka6CR Scott Soaring 0 October 5th 03 02:34 AM
FS - Schleicher Ka6CR Scott Soaring 2 September 17th 03 01:46 PM
Ka6e vs Foka4 Janos Bauer Soaring 19 July 25th 03 03:35 AM
