I just did this on my LAK. Fidel showed me how he square cuts a tongue
depresser and then sands it to a chisel edge. Use it like a chisel to remove the adhesive residue and it won't harm the finish. "Evan Ludeman" wrote in message ... On May 31, 8:25 am, Geoff Vincent wrote: On 31 May, 14:06, jim wynhoff wrote: On May 30, 8:07 pm, JS wrote: Of course, true STUDs develop power tools to do the job. Removing ancient gelcoat can be fun! Fuzzy, if you've put an S-seal in, you could take your time with the Mylar, but best to just get it done. At least round one, anyway. Jim On Wednesday, May 30, 2012 4:22:47 PM UTC-7, BobW wrote: You're a STUD!!! Regards, Bob W. Thanks all, JJ - Good to know. I thought that might be the case, Concept being a catalyzed paint, but my worry is based on way too many years of using non-catalyzed paints. JS, Yeah, that was quick, but really scary. There was no evidence of an S seal ever being installed, just mylars top and bottom. Believe me, I will be very happy to finish this round of refinishing. I'm going to celebrate by growing fingerprints again, since I've worn mine off. Next year the tips and horizontal, and maybe the fuse in 2014. Bob... uh...thanks? Hi folks, My question is at the other end of the seal's lifespan - how to remove the tape adhesive residue from the wing once the Mylar seal has been removed? My progress, mechanically, is about 300mm per hour and I would really welcome some practical advice on how do this more quickly and less painfully. Recommendations on chemical solvents or proprietary products would be appreciated. The aircraft is a PIK 20B superbly refinished with 2-pack polyurethane about 9 years ago. Regards, Geoff Vincent Grampians Soaring Club Australia If the adhesive still has enough tack that removal is a problem, I don't use chemicals, I use heat. A hair dryer is sufficient (high setting). Heat the adhesive tape to about 50C and peel. If you can put your finger tip on the mylar for a couple of seconds, but not keep it there, that's the right temperature. The right combination of peel angle (roughly 135 degrees), speed and heat will lift off old Tesa bonding tape with little if any residue (clean that up with solvent). This is about 50x faster than solvent. Likewise, heat is your friend when it is time to apply new seals. Sanding is completely unnecessary provided that surfaces are clean and warm (at least 30C). That said, sanding doesn't hurt. If in doubt, go back over the bond line after application with hair dryer and back of a table spoon or wall paper seam roller (while warm). -Evan Ludeman / T8 |
| Thread Tools | |
| Display Modes | |
| Mylar seals for elevator | [email protected] | Soaring | 28 | May 22nd 08 06:57 PM |
| Mylar seals installation | John W | Soaring | 2 | May 5th 04 10:03 PM |
| mylar seals wing to flap/ Aileron | culverflyer | Soaring | 2 | May 5th 04 03:52 PM |
| ZZ Mylar seals | Mike | Soaring | 3 | March 29th 04 04:45 PM |
| mylar seals | D.A.L | Soaring | 1 | February 23rd 04 08:15 PM |
