The "offical" LXNAV V7 thread
Old February 28th 14, 03:34 AM posted to rec.aviation.soaring
Bastoune
Default The "offical" LXNAV V7 thread
Ted,
I may be misunderstanding your question, but I do not think that you can upload a task "to" the V7. You can upload a task to your GPS Logger (e.g. Nano) by going "through" the V7 (See setup example in section 8.4.2 of the manual). The relevant section on how to perform the upload is 5.1.2. In the "Direct Link" mode, the Oudie communicates directly to the Logger.
Old February 28th 14, 02:28 PM posted to rec.aviation.soaring
ES
Okay, things are starting to make a little more sense. On page 16 (section 5.1.2)there is a turnpoint name ("Line 11") above the course direction indicator. When I saw that, I assumed I there was some task storage and processing in the V7. If the task is not in the V7, where does this turnpoint name come from? (From the Oudie, or from the logger?)
Old February 28th 14, 02:41 PM posted to rec.aviation.soaring
Luke Szczepaniak
The Oudie will have to send the active TP coordinates in an RMB sentence
back to the V7.
Luke
Old February 28th 14, 11:53 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
logger?)
back to the V7.
It must also be getting at least the WPL sentence and possibly is also
getting ROO sentences. I say this because the RMB sentence conveys the TP
coordinates but doesn't contain its name. Both ROO and WPL include the TP
name. WPL contains the name and coordinates of a TP: by comparing
coordinates between RMB and WPL the receiver can work out the RMB's
target TP name. ROO defines the task (in our terminology). All it
contains is a list of TP names in task declaration sequence.
The reception frequency differs depending on the sentence type. An RMC+RMB
pair are received every second with a third sentence appended. This
sentence is either an ROO or a WPL. The ROO and associated WPLs are sent
in a repeating sequence, one each second, so if you have 'n' turnpoints
in the active task, the sequence takes n+1 seconds to be sent.
I researched this some time ago when I wanted to understand why my SDI C4
wouldn't calculate wind unless the GPS it was attached to, a Garmin GPS
II+ at that stage, had at least one active waypoint. I ended up with the
Garmin plugged onto a PC and displaying each sentence as it arrived so I
could work out what was going on.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 1st 14, 04:53 PM posted to rec.aviation.soaring
You need to ensure the baud speed for your logger is the same as the baud speed for the PDA (as the V7 gives the PDA direct access to the logger when declaring a task). This should fix the problem
Chris
On Thursday, 27 February 2014 02:03:11 UTC, ES wrote:
Has anyone had luck uploading tasks from Oudie to V7? This topic isn't discussed in the user guide, and I'm not having any luck repeating the settings in the youtube video on the subject (device = "LXNAV - Nano", interface = "COM4:", speed = "4800bps".
In the video, there is very quick connection and transfer.
When I try it (using the latest V7 firmware and Oudie version), I get "Connecting" on the Oudie, and the communication icon on the V7, but nothing else.
thanks
ted/ES
LXNAV V7 - Reviews? David Reitter Soaring 10 October 21st 14 12:41 AM
New LXNAV LX9000 Overview Video Paul Remde Soaring 0 April 21st 12 01:33 AM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
LXNAV Nano and LX 9000 Overview Videos Available Paul Remde Soaring 3 February 28th 11 01:58 PM
HELP! Need offical Blanik L-13 Canopy Strap John Scott Soaring 4 March 3rd 08 05:03 AM
