I had a nasty land-out in 2007 on the Caprock west of Hobbs; I was very lucky not to have been hurt (other than my ego, of course), but my iPAQ went flying during the violent roll-out! The iPAQ wasn't 'locked' to its cradle in any way; now everything in my cockpit is 'locked-down!'
Foxtrot2 On Monday, June 11, 2012 12:53:09 PM UTC+2, Dan wrote: Is it possible to post what mount solution was being used (velco, suction, hard-point) so we can re-assess what we are using with ours? Dan |
After a midair (two-seater with towplane) killed three experienced pilots a month ago, the French soaring federation has decided to make Flarm mandatory on every glider and towplane used by clubs and private owners, if they are flying under the federal insurance system (this means: almost every sailplane used in French clubs).
At 13:53 09 June 2012, wrote:
After a midair (two-seater with towplane) killed three experienced pilots a= month ago, the French soaring federation has decided to make Flarm mandato= ry on every glider and towplane used by clubs and private owners, if they a= re flying under the federal insurance system (this means: almost every sail= plane used in French clubs). FLARM can be a very good system. However, there are some issues which I am not sure if FLARM as a company is taking seriously enough. In US PowerFLARM seems to have some advantages over European version. This is a report of a very unfortunate midair, which should have been avoided. Both planes had FLARM systems installed. http://www.turvallisuustutkinta.fi/1302672994222 SUMMARY COLLISION BETWEEN TWO SAILPLANES IN HATTULA ON 12 JUNE 2011 An aircraft accident occurred near lake Renkajärvi in Hattula, southern Finland, on Sunday 12 June 2011 at 15:57 Finnish local time, when two single-seat sailplanes collided in the air. The pilot of the other plane rescued himself with a parachute, and the other pilot was killed. Both sailplanes were destroyed. The sailplanes involved were participating in Finnish Gliding Championships. The collision occurred in gliding flight in good weather conditions between the turnpoints of Forssa and Syrjäntaka, at a height of approximately 1400 m inside Pirkkala Military Control Area (Airspace class D) of which southern part was reserved for the competition. Both pilots were experienced sailplane pilots and competitors. Before the collision, the planes were flying almost the same route and occasionally very close to each other. The collision happened when the lower flying plane increased altitude and reduced speed, finally hitting the bottom of the higher flying plane. From the force of the impact, the rear fuselage and right wing of the lower plane broke off and the canopy was shattered. The plane went into a steep dive, and also the left wing broke off. The fuselage crashed into the ground at high speed. The pilot was found outside the wreckage. He had unfastened the seat belt but not launched the parachute. The bottom of the higher plane was cracked, its steering system was damaged and the canopy was broken. The pilot rescued himself with a parachute. Both planes had two GPS devices, and their recordings were used in the accident investigation. The planes were also equipped with a FLARM system for collision avoidance. According to the rescued pilot, the FLARM did not alert before the collision, which may have been due to the limited capabilities of the system as described in its instructions manual. The accident was caused by pilots’ insufficient situational awareness leading to the situation, where the planes got above each other and their flight paths intersected in the vertical direction. At the same time the pilots could not see each other. Contributing factor was the fact that the collision warning system did not alert. The accident was caused as the planes got above each other in a position where the pilots could not see each other, and their flight paths intersected in the vertical direction. Contributing factors included the pilots’ insufficient situational awareness and the fact that the collision warning system did not alert. Safety Investigation Authority, Finland issued a safety recommendation to the Finnish Aeronautical Association, urging them to hold a safety information session before every gliding contest. In addition, it was proposed that safety issues be addressed in the briefing session for each day of competition. |
On 6/9/2012 1:52 PM, Kimmo Hytoenen wrote:
FLARM can be a very good system. However, there are some issues which I am not sure if FLARM as a company is taking seriously enough. In US PowerFLARM seems to have some advantages over European version. This is a report of a very unfortunate midair, which should have been avoided. Both planes had FLARM systems installed. http://www.turvallisuustutkinta.fi/1302672994222 FLARM is an imperfect warning system just as parachutes are an imperfect rescue system. Clearly (and tragically) FLARM failed to prevent the above referenced accident. But also notice that one pilot was saved by his parachute, while the other unfortunately wasn't. Does the above accident imply that parachutes are a bad investment? Obviously the answer is no. Parachutes clearly save lives, even though they are imperfect. Does the above accident imply that FLARM is a bad investment? Same answer as above, same reasoning. Vaughn |
On Jun 9, 11:17*am, Vaughn wrote:
On 6/9/2012 1:52 PM, Kimmo Hytoenen wrote: FLARM can be a very good system. However, there are some issues which I am not sure if FLARM as a company is taking seriously enough. In US PowerFLARM seems to have some advantages over European version. This is a report of a very unfortunate midair, which should have been avoided. Both planes had FLARM systems installed. http://www.turvallisuustutkinta.fi/1302672994222 FLARM is an imperfect warning system just as parachutes are an imperfect rescue system. *Clearly (and tragically) FLARM failed to prevent the above referenced accident. *But also notice that one pilot was saved by his parachute, while the other unfortunately wasn't. Does the above accident imply that parachutes are a bad investment? Obviously the answer is no. *Parachutes clearly save lives, even though they are imperfect. Does the above accident imply that FLARM is a bad investment? Same answer as above, same reasoning. Vaughn Could good "old" PCAS help in this situation assuming both gliders have transponders and are being interrogated. And for that matter the one at AirSailing (hopefully we will find out if they had this equipment). It too is far from perfect but the alert it gives never fails to get my attention and elevates scan to the top priority of my pilot load(or equal with flying the plane). |
On 6/9/2012 11:50 AM, db_sonic wrote:
Vaughn Could good "old" PCAS help in this situation assuming both gliders have transponders and are being interrogated. And for that matter the one at AirSailing (hopefully we will find out if they had this equipment). It too is far from perfect but the alert it gives never fails to get my attention and elevates scan to the top priority of my pilot load(or equal with flying the plane). This situation may be the worst possible: the high glider is behind the low glider, and neither can see the other. Possibly, the upper glider's fuselage blocks the Flarm signals in both directions. PCAS might provide a notification that the other glider was present (if at least one glider had a transponder and the other the PCAS), as the glider positioning would not interfere with transponder signals. Still, a PCAS system would not warn you that a collision was imminent, as it can not detect what appeared to happen: a quick pull up, perhaps triggered by hitting some lift. How often do we do that, without checking behind and above first? I do it a lot as I travel along under a cloud street, and I know others also do it. Maybe we need a mirror positioned to easily see that blind spot. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
At 18:17 09 June 2012, Vaughn wrote:
On 6/9/2012 1:52 PM, Kimmo Hytoenen wrote: FLARM can be a very good system. However, there are some issues which I am not sure if FLARM as a company is taking seriously enough. In US PowerFLARM seems to have some advantages over European version. This is a report of a very unfortunate midair, which should have been avoided. Both planes had FLARM systems installed. http://www.turvallisuustutkinta.fi/1302672994222 FLARM is an imperfect warning system just as parachutes are an imperfect rescue system. Clearly (and tragically) FLARM failed to prevent the above referenced accident. But also notice that one pilot was saved by his parachute, while the other unfortunately wasn't. Does the above accident imply that parachutes are a bad investment? Obviously the answer is no. Parachutes clearly save lives, even though they are imperfect. Does the above accident imply that FLARM is a bad investment? Same answer as above, same reasoning. Vaughn Very good point. What will chute manufacturer do if a chute fails to open? |
This unfortunate accident in Finland brings up 2 issues:
1- sharing the details of such accident is very important. This should be an example why a lower antenna should be strongly recommended. 2- we should never fly directly above or below another aircraft as we have huge blind spots at these directions. Ramy |
Sigh! More SHAW fun.... | Canuck[_5_] | Aviation Photos | 0 | May 30th 09 05:36 AM |
