On Jun 18, 12:35*pm, wrote:
On Monday, June 18, 2012 2:13:38 PM UTC-4, Ramy wrote: On Monday, June 18, 2012 10:54:30 AM UTC-7, cuflyer wrote: On Monday, June 18, 2012 9:37:03 AM UTC-4, Linwood wrote: Anyone have any knowledge of the three fatality glider crash in Texas? Glider type? Situation? Linwood Kid on his mother's lap - ? *Affecting control - ? This is really ugly. 1FL It was indeed the freaking tail dolly!!! http://blog.chron.com/newswatch/2012...ash-under-inve... Ramy Nope- If the tail dolly was on, glider is still flyable. Most likely speculation on may part-#1 rule broken here which is FLY THE AIRPLANE. I have seen a few tail dolly incidents or the years, and in every case, the pilot had to be told that the tail dolly was still on. Other bad rule broken- NO unrestrained people in the glider- ever. Terribly sad UH Probably true, but I've seen some monster Lark dollies which were so heavy one person could barely lift them. Even with the CG in the allowable range, the Twin Lark demands respect. It might not take much weight on the tail boom for it to turn nasty. This accident has all the earmarks of one which will drive changes to the FAR's. The FAA has been grumbling for years the requirements to get a Commercial-Glider or CFI-G are way too easy to meet. I think fair warning is in order that we may see changes to Part 61. My deepest sympathies go to the family and friends of the mother and daughter. |
Very sad, especially so on Father's Day and with three members of the
same family. Some other links with photos and video. http://www.cbsnews.com/8301-201_162-...-glider-crash/ http://www.khou.com/home/3-family-me...=y&c=y&c=y&c=y In image 2 of 8 at the KHOU site the (orange) tail dolly is clearly visible in a picture taken at what might have been very soon after the accident. - John |
On Monday, June 18, 2012 4:23:39 PM UTC-6, JohnDeRosa wrote:
Very sad, especially so on Father's Day and with three members of the same family. Some other links with photos and video. http://www.cbsnews.com/8301-201_162-...-glider-crash/ http://www.khou.com/home/3-family-me...=y&c=y&c=y&c=y In image 2 of 8 at the KHOU site the (orange) tail dolly is clearly visible in a picture taken at what might have been very soon after the accident. - John Report verifying that the tail dolly was on the glider. http://www.khou.com/news/local/Cause...159501035.html |
If the tail dolly was left on the angle of attack on the ground run would
be less so it wouldnt lift off till a higher speed had been reached. Could this have had any control effects on tow? If the toddler was sitting on his mothers lap his feet would be straight out in an ideal place to interfere with the stick. Bad bad idea. |
On Jun 19, 9:35*am, Nigel Pocock wrote:
If the tail dolly was left on the angle of attack on the ground run would be less so it wouldnt lift off till a higher speed had been reached. Could this have had any control effects on tow? If the toddler was sitting on his mothers lap his feet would be straight out in an ideal place to interfere with the stick. Bad bad idea. The IS28b2 manual calls for +10 degree flap for aero tow takeoff and the normal technique is to lift the tail early so the dolly probably had no effect on liftoff speed. If the dolly was light it very likely didn't shift the CG enough to provide a probable cause or even a contributory factor in this accident - the Twin Lark is a big, heavy and stable bird. Most likely the dolly is significant only in that it provides evidence of carelessness. If you put a small child in the cockpit of a glider, they will almost invariably start yanking, pulling and twisting everything they can reach making them unsafe as passengers. A child in a mother's lap would be able to reach everything except the rudder pedals. |
On Jun 19, 11:35*am, Nigel Pocock wrote:
If the tail dolly was left on the angle of attack on the ground run would be less so it wouldnt lift off till a higher speed had been reached. Could this have had any control effects on tow? If the toddler was sitting on his mothers lap his feet would be straight out in an ideal place to interfere with the stick. Bad bad idea. Are the wing runners trained to check for extra big orange things hanging off the glider before takeoff? I know it is not their fault, but at the critical launch the pilot is helpless to see this mistake. |
On 6/19/2012 11:06 AM, soartech wrote:
On Jun 19, 11:35 am, Nigel wrote: If the tail dolly was left on the angle of attack on the ground run would be less so it wouldnt lift off till a higher speed had been reached. Could this have had any control effects on tow? If the toddler was sitting on his mothers lap his feet would be straight out in an ideal place to interfere with the stick. Bad bad idea. Are the wing runners trained to check for extra big orange things hanging off the glider before takeoff? I know it is not their fault, but at the critical launch the pilot is helpless to see this mistake. Making zero speculation as to root cause(s) of this tragedy, and considering only the presence of the tail dolly at the start of aerotow, it's clear to any informed soaring participant that this item was missed by at least one person (PIC), and presumably two (wing runner). I was "lucky enough" to witness a dolly-on takeoff prior to my solo (Phoebus A; PIC's initial flight in it; it ended well), and the more experienced people around at the time gave me a thorough exposure to all the myriad errors made along the way to such a launch. The lessons were obvious...once they'd been pointed out to me. I've also begun one takeoff roll with my tail dolly attached (haste; inexperienced wing-runner), realized ~when tuggie applied power I couldn't remember having checked for tail dolly removal, listened (no joy one way or the other), tried a tentative rudder input (inconclusive), pulled the plug (listening to that little voice in my skull). There it was, on the fuselage, in all its international orange glory. (What an idiot!) Point being - others having already touched upon likely CG/directional-stability issues associated with its presence - that every reader who's hearing little voices in his/her head about the presence of the tail dolly in this terribly sad instance ought to be actively listening to that voice against the future day it may (will?) need to be acted upon. Clearly, beginning a takeoff roll with the taildolly attached is an avoidable mistake...even if in a very few designs it may be self-correcting (e.g. G-102). Bob W. |
tragedy at Salida, Colorado | David Kinsell | Soaring | 0 | October 28th 07 03:16 PM |
Lessons learned from the Oregon tragedy | john smith | Piloting | 100 | December 12th 06 04:34 AM |
GA _is_ safer than some modes of transport. Was: Tragedy | Jim Logajan | Piloting | 56 | October 27th 05 11:51 AM |
A tragedy - a Minden death today! | David Bingham | Soaring | 25 | October 28th 04 03:49 AM |
The sea may be giving answers to a 64-year-old tragedy | Seppo Sipilä | Military Aviation | 6 | June 9th 04 02:29 AM |
