Winscore finish cylinder setup
Old June 19th 12, 07:49 PM posted to rec.aviation.soaring
Brad[_2_]
Default Winscore finish cylinder setup
This is not the moment to
learn to do a fast contest buttonhook.
John Cochrane
is a fast contest button hook a safe maneuver to do at any time?
freeflying OR contest finish.
Thanks,
Brad
Old June 19th 12, 06:50 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
On Tuesday, June 19, 2012 5:07:12 AM UTC-7, kirk.stant wrote:
I'm learning how to setup Winscore for a local club fun contest. So far it makes sense, but setting up the Finish Cylinder is a bit confusing. How do I set it up for a 500' agl min finish height? The finish settings have settings for the Top and Base of the Finish Gate Cylinder, both in ft MSL.
Kirk
66
Kirk
66
Winscore handles the finish penalty correctly and also starts out the top of the cylinder. However, be aware that if the latest start gets a penalty it may be possible to avoid the penalty (at the cost of slower speed) by choosing an earlier start. Winscore helps with this in the "Edit" function.
QT
Old June 19th 12, 07:46 PM posted to rec.aviation.soaring
Ron Gleason
I'm learning how to setup Winscore for a local club fun contest. So far it makes sense, but setting up the Finish Cylinder is a bit confusing. How do I set it up for a 500' agl min finish height? The finish settings have settings for the Top and Base of the Finish Gate Cylinder, both in ft MSL..
Kirk
66
Kirk
66
QT
What John said. WS does handle the finish correctly if the pilot is more than 300 feet below MFH and produces a warning stated that the flight was scored as a rolling finish and the flight is tagged as 'incomplete'
2011 WINSCORE Ron Gleason Soaring 9 April 21st 11 03:11 AM
WinScore help Spam Soaring 2 September 6th 09 04:00 PM
How to add an IGC validation DLL to Winscore ? Dave Nadler Soaring 1 June 18th 09 07:22 PM
How does Winscore calculate finish altitude? kirk.stant Soaring 46 July 31st 07 07:38 PM
Visulalizing the Finish Cylinder [email protected] Soaring 44 March 25th 05 02:10 PM
