Wing-support for Duo one-person assembly
Old September 4th 12, 03:26 PM posted to rec.aviation.soaring
Dave Nadler
Default Wing-support for Duo one-person assembly
On Tuesday, September 4, 2012 6:51:03 AM UTC-4, Ventus_a wrote:
Hi Dave
I bought Paul Cordell's Nimbus 3D a couple of years or so back and it
had a very basic wing rigger with it. I one man rig without any
problems. It uses a mechanical screw height adjustment but once it is
set it hardly needs any fiddling. To get the fine adjustment for pin
alignment I adjust the fuse up or down with the fuse cradle jack(Cobra
trailer). I've seen people with much fancier and more complex gear have
more trouble, you just gotta have the knack
Although the Duo is quite high at the outer end of the inner panel I
wouldn't think you would have too much trouble with a well set up wing
rigger
Weather permitting I'll get you some photos tomorrow and email them to
you
Cheers
Colin
Thanks Colin !
Old September 3rd 12, 01:29 AM posted to rec.aviation.soaring
Barry[_4_]
Dave,
I use a wingrigger on my Arcus and it works fine. Steve strengthened the unit and added larger tires.
Barry (ARC)
Old September 3rd 12, 02:45 AM posted to rec.aviation.soaring
On Sunday, September 2, 2012 8:29:39 PM UTC-4, Barry wrote:
Dave,
Barry (ARC)
So you solo rig your Arcus?
Old February 24th 14, 12:28 PM posted to rec.aviation.soaring
Hi!
Enstroj makes what you are looking for,
http://www.enstroj.si/Glider-product...-assembly.html
I have used this rigging aid and it great.
Mike
Old February 25th 14, 06:17 AM posted to rec.aviation.soaring
We've used an Udo rigger that was made for an ASW-20 on our DG-505 Orion quite successfully simply by making the trailing edge clamp longer to deal with the greater chord. I've got one for my 15b and like it better than the others I've seen. I actually prefer the mechanical jack to the gas spring setup on some riggers. I think what really makes the Udos work well though is how good a job he did making the wing saddle - very substantial and fits nice and snug to the contour of the wing.
Wing assembly dollies Udo Soaring 1 December 2nd 10 02:51 AM
USED One person assembly rig Tim Mara Soaring 0 May 1st 10 03:13 PM
assembly wing dolly Anoucement Udo Rumpf[_2_] Soaring 2 January 13th 09 06:53 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
USAFE commander: 86th Airlift Wing will divide for combat, support operations Otis Willie Military Aviation 0 November 27th 03 11:31 PM
