I probably thermal too slowly and with too much bank. Lately it seems every time I try to open up the turn even a little I blow out the edge of the thermal.
Having an instrument to yell at me might improve my thermalling, or really **** me off! On Tuesday, September 25, 2012 9:29:44 PM UTC-7, kirk.stant wrote: With all the new (and some of the older - SN10 for example) vario-computers having accelerometers and settings for ballast and polars, would it be possible to compute and display the optimum thermalling speed adjusted for wingloading and bank angle (as a function of instantaneous G-loading)? Since we don't (yet) have AOA gauges (which would do a better job of indicating the correct speed to fly in a thermal), I'm curious if a simple "speed to fly" indication would work. Obviously, filtering a constantly varying G-load would have to be employed, but I'm thinking of a 2-3 knot speed band display - using the same fast-slow indicator used for cruise speed control - preferably also with a deadbeat digital readout of the optimum speed to thermal for an average of the past 3 seconds or so of turn/averaged G. Would this work? Probably only once established in a steady, smooth turn - but that would give a good starting point for the next thermal. Kirk 66 |
Last year I became a syndicate partner in a lovely LS7 (without
winglets). Our panel contains an LNAV which has the optional g meter and the climb tone changes in lift if the angle of bank is too great and the glider approaches the stall. Best thermalling speed is just slow enough for the tone not to change. It is even possible to change the ballast setting on the LNAV; works for us. I am always struck by the inability of bloggs to bank at 45 degrees. The screws on the panel trick works and many are quite surprised at how steep this feels. They are then even more surprised by how much the stalling speed goes up! Tally ho! John |
Two thoughts on this:
1) There is no substitute for practice. 2) If you need a computer for everything you might as well let the computer fly the glider. Why have the middleman? At 10:58 28 September 2012, John Roche-Kelly wrote: Last year I became a syndicate partner in a lovely LS7 (without winglets). Our panel contains an LNAV which has the optional g meter and the climb tone changes in lift if the angle of bank is too great and the glider approaches the stall. Best thermalling speed is just slow enough for the tone not to change. It is even possible to change the ballast setting on the LNAV; works for us. I am always struck by the inability of bloggs to bank at 45 degrees. The screws on the panel trick works and many are quite surprised at how steep this feels. They are then even more surprised by how much the stalling speed goes up! Tally ho! John |
On Friday, September 28, 2012 6:30:03 AM UTC-6, Jim White wrote:
Two thoughts on this: 1) There is no substitute for practice. 2) If you need a computer for everything you might as well let the computer fly the glider. Why have the middleman? I'm confused, Jim: Do you have a vario in your glider? Or a glide computer? PNA? How does having real time information on a variable performance value (min sink speed for current conditions) equate to letting the computer fly the glider? Kirk |
On Monday, August 14, 2017 at 8:58:21 PM UTC-4, wrote:
https://www.youtube.com/watch?v=EO9nXPRkWKk Both links above are for part 1. Part 2 is he https://www.youtube.com/results?sear...+thermalling+2 Uli 'AS' |
Optimum CG Range | jcarlyle | Soaring | 38 | December 17th 09 05:50 PM |
Thermalling the D2 | Fox Two | Soaring | 9 | November 2nd 06 10:01 PM |
The new art of thermalling - with a kite... | [email protected] | Soaring | 3 | July 30th 06 04:06 AM |
Uncoordinated thermalling | David Norinsky | Soaring | 2 | July 12th 05 05:07 AM |
Hands off thermalling | John Jones | Soaring | 24 | April 26th 04 03:07 PM |
